Go Back   HeliFreak > R/C Batteries and Charging Support > A123
A123 A123 Battery Support
Old 03-08-2014, 10:22 AM   #1 (permalink)
Default LiFe for the first time
I use my small 80w charger to charge LiPos. Do LiFe batteries charge just like LiPos, but with a final voltage of 3.3 instead of 3.7?
Blade 550x // 450x // 450-3D // mCPX-BL // mCPX2 // DX9 // DX6i // Phoenix 5 // Thunder AC680
k450 is offline        Reply With Quote Quick reply to this message
Old 03-13-2014, 07:19 PM   #2 (permalink)
No, LiFe or A123 will charge up to 3.6V/cell. 3.3V is just nominal voltage.
Where do the Du-Bro 1/4 scale hinges go on a helicopter???
chris-fry is offline        Reply With Quote Quick reply to this message
Old 03-16-2014, 11:25 AM   #3 (permalink)
The Bantam lists 3 choices for lithium 3.3, 3.6, 3.7. These are the nominal voltages of LiFe, LiIon, LiPo and not the terminal charge voltage. Your user interface may be confusing.
Four Stroker is offline        Reply With Quote Quick reply to this message
Old 04-10-2014, 08:54 PM   #4 (permalink)
I have a similar question. I just picked up a LiFe 2S 2100 pack for my transmitter.
I've got the nominal (or low voltage figured out, I think). At 3.3V/cell it read was at 28% if I recall correctly from this morning
I wanted to charge it. I'm using a PL8.
I used the A123 1100 Accurate Charge preset. The charge voltage is preset to 3.6 I believe.
When I charged the battery ANC checked it with a Futaba cell check set to LiFe it read like 95% when the PL8 said it was finished.
So now I'm wondering should I build a custom fuel table for the battery?
Do increase the chargefvoltage; if so, what to?
Or do I do both?
Stumped…
Align: Trex 550 Pro DFC, Trex 500 Pro DFC, Trex 450 Pro DFC, Trex 250 Pro DFC, Trex 150 DFC, Blade: CX2, mSR X, 120 SR, Nano QX, 300X. Spektrum: DX6i, DX8, DX9
DWill is offline        Reply With Quote Quick reply to this message
Old 04-11-2014, 01:23 PM   #5 (permalink)
Could it be because LiFe is supposed to be 3.3v/cell. Doesn't your battery show 6.6v on it?
Old 11-15-2014, 06:54 PM   #6 (permalink)
After 5 flights today on a 2100mAh LiFe I charged 511mA back into it to make it full. At this rate how many flights should I go between LiFe recharges?
Old 11-16-2014, 07:12 PM   #7 (permalink)
Thats roughly 100mAh per flight. 10-13 flights.
Old 11-17-2014, 11:13 AM   #8 (permalink)
Can I use a cell voltage checker to know when the LiFe is low or go by mA? What voltage level should I quit flying and recharge? Should I continue to monitor how many mA goes back into this battery during each recharge?
Old 12-08-2014, 07:32 PM   #9 (permalink)
This fellow helifreaker has a fuel gauge mounted on his heli.
https://www.helifreak.com/showthread.php?t=200363
He built this one but apparently Voltmagic sells one similar. http://www.voltmagic.com/
I don't have a fuel gauge but always watch the Mahs I put back into my 2S 1100 Mah Lifepo4 Rx pack on my Trex 550.
I chose smaller ones to keep weight down.
I use about 100 to 125 Mahs per flight and charge every 4 flights or change the pack for a fresh one. I might could get a few more flights in but hate to risk it.
I assume I'm safe to us at least 550 Mahs of the 1100.
If its fixed don't break it!
Bladecpnitro is offline        Reply With Quote Quick reply to this message
