Like Tree2Likes
Old 05-20-2013, 11:00 PM   #541 (permalink)
Have you tried swapping servos 1 and 2
Thinking is difficult, that's why most people judge. - Carl Young.
Felix the cat is offline        Reply With Quote Quick reply to this message
Old 05-20-2013, 11:29 PM   #542 (permalink)
I just did it didnt help
knight2000 is offline        Reply With Quote Quick reply to this message
Old 05-21-2013, 05:21 AM   #543 (permalink)
Originally Posted by knight2000 View Post
its moving faster now that i reduced the tail gyro, when i tilt the heli left the swash plate tilts left. i dont think its suppose to do that. Any ideas?
I don't see how reducing tail gyro gain can effect swash plate movement, I think you should check you have it wired correctly.
If the swash is moveing in the wrong direction then follow the sticky and correct it thats what the programme and hand held controller are for.
Ivor Hill is offline        Reply With Quote Quick reply to this message
Old 07-09-2013, 07:36 AM   #544 (permalink)
Thumbs up Good job.
Thank you for your "manual" for flymentor. Very good discriptions, work fine..
leo450 is offline        Reply With Quote Quick reply to this message
Old 07-09-2013, 05:18 PM   #545 (permalink)
Happy it helped and welcome to HeliFreak.
Old 07-10-2013, 05:27 PM   #546 (permalink)
Default flymenter tail help!!
Hey, when i bring my heli up the tail just spins out of control, i try to tail input but it doesn't help, any suggestions?
Old 07-10-2013, 05:37 PM   #547 (permalink)
Tail gyro seems to be correcting the wrong way
Change your gyro correction.
Old 07-10-2013, 05:58 PM   #548 (permalink)
change gyro correction on the flymenter or my dx6i, if on the flymenter where do i go to do that?
Old 07-10-2013, 06:52 PM   #549 (permalink)
On the tabs of Helibal software.
It's being a while for me but think is under the control tab - Yaw norm or rev.
Old 07-11-2013, 04:36 AM   #550 (permalink)
does anyone know where the gyro correction is on the flymentor handheld?
Old 07-11-2013, 09:46 AM   #551 (permalink)
It depends on how you are controlling the gyro, if the green wire is plugged in FM has no control over the tail gyro so you reverse the gyro on the TX.
If the green wire is not connected then FM is controlling the gyro so you use the hand held controller you will find it under servo reverse. If you then find the gyro correction is correct but stick control in not then reverse the stick under stick reverse.
Old 07-11-2013, 06:51 PM   #552 (permalink)
Thanks!
Old 07-11-2013, 06:54 PM   #553 (permalink)
i have the blue wire connected!
Old 07-12-2013, 04:52 PM   #554 (permalink)
The blue wire controls stabilization gain from the Tx when connected, it has nothing to do with the tail gyro.
Old 07-29-2013, 08:15 PM   #555 (permalink)
Hey Ivor and everyone, thanks for all yall help, but im still having problems, could be the way i have the flymenter gyro install on the heli wrong. So i made a video of the position of the gyro and the KDS flymentor 3d headheld setup. let me know if anything is wrong. http://www.youtube.com/watch?v=nxLtwGIQn_Q
Old 08-03-2013, 05:23 AM   #556 (permalink)
Sorry for the late reply. Please explain exactly what your problems are.
Old 08-03-2013, 02:14 PM   #557 (permalink)
i thought no one could understand me, I just want to know if the KDS flymentor handheld is setup right, cause when i bring the helicopter up the flymentor doesnt activate
Old 08-06-2013, 02:24 PM   #558 (permalink)
Is FM switched on ?. What colour is the LED ?.
If it is red FM is switched off. If it is red and green it is in balance mode. If it is flashing green then it is in positional mode.
If it is solid red the usual reason for this is that the blue wire is connected and the TX is set to turn FM off.
FM should first be set up and test flown with the blue wire disconnected and all settings on the advance pages should be at the factory defaults. If this is done then the LED should be flashing green.
Old 08-07-2013, 06:29 PM   #559 (permalink)
It is flashing Green, what is the different in the two modes?
Old 08-08-2013, 03:40 PM   #560 (permalink)
In balance mode the heli will level if the stick is centred. In position mode the camera is operational and the heli will hold position up to about 9 feet. Above this height it will revert to balance mode.
When the heli is on the ground the green light will be flashing because there is not enough contrast so it will in fact be in balance mode. A few inches off the ground and the LED will change to solid green, position mode, if the heli is set up correctly, balancer gain is set high enough and there is not to much wind the heli will hold position. Keep gaining height and at about 9 feet the camera cannot work so FM changes to balance mode it will stay level but will not hold position Loose height and FM will change back to position mode.
That's how it works provided the heli and FM are set up correctly and balancer gain is set high enough.
If the blue wire is plugged in then the balancer gain set in FM will be disabled and the gain will be set on the TX.
If the blue wire is not plugged in then the balancer gain set in FM will be used.
