Spartan RC Spartan RC - Quark, DS760 Gyros and other Spartan RC Electronics Factory Support |
08-15-2015, 05:26 PM | #1 (permalink) |
vortexVX1n futaba 7c receiver r617fs
Totally lost about the connections here. I saw guys confused with s-bus but how its possible to connect all the wires to gyro from receiver .
Its ok about the servos but how i connect the rest of the cables from receiver and my second power cable from kosmik ? I had beastx and i had more ports there and its clear where to connect but here i don't know what to do and i don't want to burn something so any help will be great. |
08-16-2015, 01:56 AM | #2 (permalink) |
As you run through the setup steps in the windows software it guides you through connecting the receiver and servos. Does that help, or do you have other connections you're asking about?
I always use a USB connection and the windows software for setup as I find it easiest, but you can also just launch the software in demo mode and run through setup and use it like a manual. If you have a second power cable from your ESC, you can connect that to any of the top row of ports next to the servos. Just be aware that you can't connect it to the two horizontal ports at the bottom. One is just for signal connections, and I believe the RPM sensor runs at a lower voltage.
Helis: Oxy 4 Max (day + night), Gaui X3 380, Oxy2 FE 215, Oxy2 Sport 190 Radio & FBL: Spartan Vortex, MSH Brain, Jeti DS-14, Spektrum DX8G2 Sims: RealFlight & AccuRC |
08-16-2015, 04:43 AM | #3 (permalink) |
thanks for reply , the aux 3 is connected to the lower port ?
08-16-2015, 09:34 AM | #4 (permalink) |
i managed to connect all cables but my pitch is not working , all servos working fine tail and swash but when i put possitive and negative pitch nothing happens
08-16-2015, 04:31 PM | #5 (permalink) |
I'm away from my computer so can't show you a diagram, but the aux port on the Vortex is one of the two horizontal ports and has three pins, which are all signal, and are Aux 1, 2 and 3.
