Old 08-16-2013, 06:52 AM   #1 (permalink)
Default Anyone using 24 VDC 55A 1320W Power Station?
Hi,
I will buy a power supply for a PL8. I am considering this power supply. I haven't seen a review about it so I want to ask here. How are your thoughts about it? BTW I am also considering Chargery S1200 Power supply.
http://www.store.revolectrix.com/24-...-Station?ext=F
Thanks,
Burak
LOGO 600 SX [ Pyro 700-52M | Scorp. Commander V 130A OPTO | VBar Neo | BLS255HV & BLS256HV ]
LOGO 600 SX
[ HKII-4225-500KV | Scorp. Commander V 130A OPTO | VBar Neo | BLS255HV & BLS256HV ]
bavci_0655 is offline        Quick reply to this message
Old 08-16-2013, 06:57 AM   #2 (permalink)
Haven't used it, but keep in mind the PL8 manual states you may need up to 1700 watts of capacity in your PS to charge at 40A (maximum on the PL8).
Oxy 3 - MSH Mini Protos - MSH Protos Max 700 - Taranis
Thanks to Oxy Heli and MSH-Direct.com
Former Username: Code3Medic
Russell Harding is offline        Quick reply to this message
Old 08-16-2013, 11:43 AM   #3 (permalink)
This also depends on the pack cell count you are charging. For instance you can max the Powerlab8 out with 6s packs with a 1150 watt supply. For 3s it only takes 575 watts. If you are never going to charge 7s or 8s packs, then a smaller supply is all that is required.
If you want to size the supply to max out 8s just in case, that's OK too. 14s is gaining in popularity, so you never know what the future holds.
Gregor99 is offline        Quick reply to this message
Old 08-17-2013, 05:44 PM   #4 (permalink)
1300W is good overhead for charging up to 6S voltages but anything over that and you are really maxing out the supply. I personally like the idea of building my own supply since it's even more powerful, easy to do, and over 10X cheaper than buying a ready-made one. Even if you put it into a carrying case it's still a lot less than just the supply alone; but that's just me.
If FMA carries a supply I doubt it's any bit of a slouch. They have to honor the warranty so they're at least backed up for a year worth of use.
Tim
KBDD TEAM PILOT
--Si vis pacem, para bellum--
skunkworx is offline        Quick reply to this message
Old 09-05-2013, 11:34 AM   #5 (permalink)
Given that perhaps the most common packs above micro flyer size are 6S and 3S and given the buck/boost discussion, why did revolectrix choose 24/12 volt output for this charger?
megawhacker is offline        Quick reply to this message
Old 09-05-2013, 11:36 AM   #6 (permalink)
By building your own referred to above do you mean repurposing a previously built server power supply, purchasing the components and building, or something else?
Old 11-27-2015, 10:46 AM   #7 (permalink)
Do the fans on this supply run all the time? Or are they temperature controlled?
Thanks,
Kevin
KevinB is offline        Quick reply to this message
Old 11-27-2015, 01:59 PM   #8 (permalink)
Depending on the supply, variable fan mode is possible.
Here is a link for the HP DPS 600PB supplies:
http://www.ultimaterc.com/forums/sho...d.php?t=174225
Old 11-27-2015, 05:38 PM   #9 (permalink)
I meant on the specific model quoted above.
( http://www.store.revolectrix.com/24-...-Station?ext=F )
Thanks,
Kevin
Old 11-29-2015, 06:31 AM   #10 (permalink)
Guess I missed this a while back, but yes. I repurpose server power supplies. They're really simple to modify and you can get them for really cheap on Ebay if you know how to search for them. After that it's adding a pull up/down resistor and soldering on your output leads.
Tim
KBDD TEAM PILOT
Old 11-29-2015, 11:55 AM   #11 (permalink)
The revolectrix power supply appears to be a pair of server power supplies anyhow. I once asked if they were, and if they were new or reconditioned or just used, but never got an answer. I doubt your getting two new server power supplies for ~$200.
The DSW (Helifreak user) ones look like the best pre-modded server ps to me.
I inquired about raising the voltage from one of his power supplies- got a response that can be raised to about 25.5, right above the buck-boost for 6s , as long as the voltage doesn't drop under load, which it really shouldn't.
minatrix is offline        Quick reply to this message
Old 11-29-2015, 03:02 PM   #12 (permalink)
They are new supplies, not used. The fans are on all the time and Revolectrix has not published a fan mod.
To avoid buck boost transitions the loaded supply must be at least .8v above the pack voltage. I tried this with a pair of DPS-600PB. I maxed out the supplies about 13.5v each. Any higher, they would trip the over voltage protection. Resting at 27v, the supplies easily dipped into the 25v range under load. This is still BB range. All it did was move the transitions to later in the charge cycle.
Old 12-04-2015, 08:18 PM   #13 (permalink)
the OP is in turkey. I bet he has 220-240V at the wall outlets.
DX8, Trex 700 dfc, Trex 550 dfc, Oxy3, Rifle 1M (plank!) PL8, PL6
atkin is offline        Quick reply to this message
Old 12-07-2015, 09:22 AM   #14 (permalink)
Yes, we have 220V.
BTW, I am using Mean Well 3000W 24V power supply for 2 PL8's. I found this supply cheaper in our country, so I bought this instead of Revolectrix Power Station. I am very pleased with my setup.
LOGO 600 SX
