Old 06-04-2011, 10:44 AM   #1 (permalink)
Default Pyro 700-52
I'm currently running the Scorpion 4535-500kv on 12T with the Jive 80HV at 2250rpm, if I switch to the Pyro 700-52 on 11T (same headspeed) will I notice a difference in flight time or power? and will the Jive 80HV run wamer (it was never hot)
all on 12S btw
brian94066 is offline        Reply With Quote Quick reply to this message
Old 06-05-2011, 02:06 AM   #2 (permalink)
I've run both motors, what i can tell your for sure is that on 12s the pyro kicks the scorpions butt, 40 love, however on 10s not really a difference. Follow NTM's posts on the subject since he's done a lot of comparisons on these motors as well.
If youre on a 10 s setup the only benefit you may reap is a much cooler running motor if u swiitch to the pyro.
Stolla is offline        Reply With Quote Quick reply to this message
Old 06-05-2011, 02:20 AM   #3 (permalink)
How much more gain are we talking about here? 15-20% or 50%?
kouasupra is offline        Reply With Quote Quick reply to this message
Old 06-05-2011, 03:37 AM   #4 (permalink)
i'm staying on 12S, i have no interest of switching to 10S
will the Jive 80HV be enough?
Old 06-05-2011, 01:02 PM   #5 (permalink)
Sorry i did not see in your first post youre on 12s, jive 80 with heatsink for sure will be enough if it handled the scorpion, what i've found is that the scorpion has very good initial torque due to heavy flywheel efect but the pyro is stronger under sustained load, this was on 600 Se with 690's, as well as some other 90 size machines on 710's cantsay on 600s or 623's if you'll experience the same improvement
@kousupra cant put a percentage on it can only say the scorpion ran extremely hot and would bog under sustained load such as a manouvre i do what could best be described as an aggressive nose down rolling funnel where i give full sustained aileron input with the pitch and tail input associated with the manouvre. pyro uses a substantial thicker guage of wire which makes it more suitable at higher voltage.
Old 06-05-2011, 03:18 PM   #6 (permalink)
The heat index here has been over a 100 degrees everyday I've flown my 600. Keep in mind I don’t fly 3D. Just FFF with some flips, loops and rolls. My Pyro comes down between 130-136 degrees. My Jive comes down around 112-118 degrees. Those numbers could increase if I was flying harder maybe. Not sure if those numbers would be considered hot though.
Logo 600 12S- HKIII 4035-500, Jive 80HV, BLS451's, BLS251, Edge 623's, Edge 105's, Mini VBar
Futaba 8FG
Sean212 is offline        Reply With Quote Quick reply to this message
Old 06-05-2011, 10:31 PM   #7 (permalink)
The pyro will run cooler, however it is not as noisy as the scorpion and kinda makes the heli boring LOL.
Power i found about the same but under heavy load pulls a little stronger.
helicraze is offline        Reply With Quote Quick reply to this message
