Old 01-05-2014, 05:26 AM   #1 (permalink)
Default Is my motor dieing? Whats the noise?
Hey guys,
My motor has started 'blipping' when spooling up and hovering, at first I thought it was gov gain but it still does it with governor off. Whats it sound like to you?
[ame]http://youtu.be/iCCnQb7MRiQ[/ame]
SAB Goblin 500- Quantum 4120-1200KV, YGE 120 LVK, SK540, BK HV servos
Mini Prôtos
-Scorpion 2580KV, YGE 60, SK540, KDS N300, MKS DS95i
Futaba 8FG Super
Dogga is offline        Reply With Quote Quick reply to this message
Old 01-05-2014, 06:01 AM   #2 (permalink)
Replace bearings.
ZeXx86 is offline        Reply With Quote Quick reply to this message
Old 01-05-2014, 06:13 AM   #3 (permalink)
I don't think it's bearings. After watching the video I can hear how u think it might be but that's just the tail rotor and my iPhones bad sound recording lol. If you listen closely at the start you can hear a kind of high pitch glitching, that's the one I'm trying to sort out
Mini Prôtos
Futaba 8FG Super
Old 01-05-2014, 06:47 AM   #4 (permalink)
if its definitely not bearings, then have you played with the timing of the motor? having it too high can damage it from what I understand, if it gets too hot the magnets can come unstuck from the side of the can
Anthony
raw 500, xl power nimbus 550,Tron 5.8 heritage, Tron Dnamic, cgy760-r, futaba
anthony1 is offline        Reply With Quote Quick reply to this message
Old 01-05-2014, 07:02 AM   #5 (permalink)
Dogga,
Over time the motor, ESC, batteries and wiring "wear" in an electronic sense. Small changes in the system may lead to these symptoms. Usually the change are so small that we never notice them over the life of our equipment. Sometimes though we find them if we happen to be operating near the "edge" of the motor/esc sweet spot.
The first test is to try a run up with a known fresh battery.
If the blipping happens only at certain RPMs and not others, then it may be that the ESC is "losing sync" with the motor. Sometimes you can get it to run smoother by changing the PWM and motor timing values in the ESC.
Try increasing the PWM rate by a small amount and do a test run up. If it stays the same or gets worse, try reducing the PWM. If there is still no improevement put it back to the value where you started. Then try changing the timing value that same way.
Good luck.
Paul
flyingw is offline        Reply With Quote Quick reply to this message
Old 01-06-2014, 12:23 AM   #6 (permalink)
Thanks guys,
I checked all ESC settings and all were correct. I tried playing with timing and PWM but it's still the same strange!
Mini Prôtos
Futaba 8FG Super
Old 01-07-2014, 12:16 PM   #7 (permalink)
What esc do you have? I've heard of stuttering and uneven speed at startup with certain ESCs and the front belt tension too tight.
Russell Harding is offline        Reply With Quote Quick reply to this message
Old 01-07-2014, 02:39 PM   #8 (permalink)
The stock YGE/MSH 60a. The weird thing is it started happening out if nowhere
Mini Prôtos
Futaba 8FG Super
Old 01-07-2014, 02:40 PM   #9 (permalink)
With no load my motor also hesitates a bit. I also tried various settings in the esc and it did help with the spool up. Very smooth spool up with blades though (no matter what) and no signs of blipping in flight. Does it the blipping for a whole pack or just initially?
2x MCPX I Gaui »X1« I 2x Mini Protos I Protos I DX8
dr dremel is offline        Reply With Quote Quick reply to this message
Old 01-07-2014, 03:27 PM   #10 (permalink)
I dont hear the blipping your talking about. If its the intermittent rattling your talking about, i think its a bearing somewhere, Both my mini's onlygive a "Whooosh" sound from the geartrain.
If you remove the belt from the pinion, how does it sound then?
MSH miniPRÔTOS & PRÔTOS 500 a better way to fly
GAUI
Hurricane 425 night rig & 550 the monster
sp00fman is offline        Reply With Quote Quick reply to this message
Old 01-07-2014, 03:39 PM   #11 (permalink)
Default Re: Is my motor dieing? Whats the noise?
Definitely the y motor shaft support bearing.
Dylan ~ www.AstroidDesigns.com
Old 01-07-2014, 04:46 PM   #12 (permalink)
Thanks guys I'll try replacing the motor shaft bearing. If that doesn't work I'll take the belt off and see if it still sounds the same. Will post the results. Fingers crossed
Mini Prôtos
Futaba 8FG Super
Old 01-07-2014, 07:26 PM   #13 (permalink)
Thanks to all of you who suggested bearings, even though I was adamant it wasn't a bearing. I tried spinning motor by hand and heard nothing out of the ordinary (bearing making any noise etc). But I pulled out the Y support and replaced that beating as well as pulled off the pinion and replaced the 2 bearings in there. The old bearings all looked fine and made no crunching noises etc. anyway with the new bearings I spoiled up and it's as smooth as silk now!
Thanks heaps guys. This forum yet again helped me out
Mini Prôtos
Futaba 8FG Super
Old 01-08-2014, 03:18 AM   #14 (permalink)
The forums are great indeed. Posting a video helps loads. I enjoy troubleshooting a lot.
i only wish somene could find the fault on my basterd Gaui hurricane.
GAUI
