Go Back   HeliFreak > R/C Electronics Support > Hitec Radios > Hitec Gyro/Servos
Hitec Gyro/Servos Hitec Gyro and Servo Support
Old 07-23-2009, 11:27 PM   #1 (permalink)
Default HS-65HB vs. HS-65MG
I am about to buy new servos for my Blade 400. I hear a lot of folks saying that they are going to or already use the HS-65MG servos. However, if you read the specs, the 65HB looks better. Well, to me anyway. What would be the difference and is the 65MG really better?
Flying wise, I don't really try any 3D stuff. Mostly FF, FFF, or just general horsing around.
CL2-MrZero is offline        Reply With Quote Quick reply to this message
Old 07-23-2009, 11:30 PM   #2 (permalink)
What 'specs' are you referring to? As far as I'm aware, the 65HB and 65MG are exactly the same other than the material the gears are made out of (and the sticker on the case).
I am partial to the HB's because I prefer the less slop of plastic gears vs. the crashworthiness of metal gears. Plus, when and if I do crash, I'd rather replace servo gears (or just a cheap $25 servo) than have something else bend ...
Old 07-24-2009, 12:10 AM   #3 (permalink)
The specs that I am referring too are, if I read it right, the HB appears to be faster, but has less torque. Now, this was reading from a sales catalog. Am I confused possibly?
Old 07-24-2009, 12:27 AM   #4 (permalink)
According to www.hitecrcd.com the only difference is that the MG is .7g heavier.
Old 07-24-2009, 03:09 PM   #5 (permalink)
That's is exactly why I posted here. I knew that someone could help me. For that I truly thank you. Of course, most of the time when I am not certain of something it is because I have confused myself or someting of that sort. Again, thanks.
Old 07-24-2009, 04:06 PM   #6 (permalink)
No problem. Have fun!
Old 07-26-2009, 05:53 AM   #7 (permalink)
The MG versions last through crashes, and do NOT cause more damage. If you hit hard, the links just pop off.
IMO, the whole metal just makes other things break is a falacy. When guys flying plastic parts break, they break/bend exactly the same parts as the metal part helis, PLUS they break some of the plastic parts.
Yes, if you hit hard enough with metal parts, you will bend/break parts, which do cost more to replace, but with a plastic part heli you will have 1) Totally rekitted the heli with that crash and 2) spent a LOT more money replacing plastic parts every crash up to the big one.
Terry
AMA#47402, IRCHA # 3395
Old 07-26-2009, 09:34 AM   #8 (permalink)
Member
+1 on everything Pinecone said. My MG's have lasted through four crashes, two of them were ugly.
Old 07-27-2009, 08:48 AM   #9 (permalink)
I have no idea how many crashes mine have been through.
Terry
Old 07-27-2009, 02:47 PM   #10 (permalink)
How are you guys mounting the 65mg to the trex 450. The frame has only 1 hole per tab but it looks like the mg65 has 2 holes per tab. I would like to replace my ds285 with mg65 but i noticed in the picture the servo tabs have 2 holes on the mg65.
Joe
Radikal 30 SE with Generator,BLS Servos.
T-Rex 450 Sport, HS 65mg Servos
Futaba 14SGH
Joey.S is offline        Reply With Quote Quick reply to this message
Old 07-27-2009, 03:28 PM   #11 (permalink)
The 65HB and 65MGs have 3 mounting holes.
Old 07-27-2009, 04:37 PM   #12 (permalink)
3 Holse per tab right? so I can use the center hole to mount the servo just like the Ds285.
Thanks for the info.
Joe
Futaba 14SGH
Old 07-27-2009, 05:03 PM   #13 (permalink)
Correct. I've never had a problem mounting the servos to my 450 or G5.
Old 07-27-2009, 06:11 PM   #14 (permalink)
Thanks You for the info.
Futaba 14SGH
Old 07-27-2009, 06:42 PM   #15 (permalink)
You do have to square up the holes in the frame. The Trex frame holes tend to be too rounded at the corners. Just file ehough so that the servo case does NOT touch the frame at any point.
Terry
Old 07-27-2009, 07:02 PM   #16 (permalink)
Hmm, I've never had to do that on any of my three 450s I've built over the past 2 years.
Although you do have to center the servos in the frame, despite having only one hole on each ear.
Old 12-20-2009, 08:03 AM   #17 (permalink)
Default Hitec servo chatter
What will cause a servo to chatter when you let it go back to center? I can move the
stick little and it will quit chattering back and forth. What can I do to stop this or is the
servo bad? It is a HS-65HB servo.
recobrian is offline        Reply With Quote Quick reply to this message
Old 07-28-2011, 05:55 PM   #18 (permalink)
Banned User
Post
Crashed my B400 with the HBs half a dozen times and only had to replace one set of gears. Not sure about the servo chatter recobrian, mine do that too, but only a little bit. You should be ok.
kavic5150 is offline        Reply With Quote Quick reply to this message
Old 07-29-2011, 12:22 AM   #19 (permalink)
I have 65MG's on my 450 clone, and 65HB's on my plane. The 65MG's have survived for several years and many crashes. The plane and the 65HB's are brand new so I cannot say anything about reliability of those.
- It could be that it struggles to find the exact spot that the Rx is asking it to go to. These are analog servos and require a potensiometer to give it a value that should correspond with where the servo is supposed to go. Try to use subtrim or trim to bump it one notch in either direction and see if it helps.
- It could be the type of pulse that the Rx is sending out, make sure to set it to analog servo output if programmable.
- It could be that for this Rx/Tx combo (if you use modules), that you need to reverse the shift phase (e.g. when using my FrSky modules, (with digital servos) they work both with positive and negative shift, however they chatter alot more on negative than positive
- I have seen several combinations that will chatter alot when "idle" or not supplied by load. This chatter normally goes away as soon as they are loaded (flying)
The price of getting what you want;
is getting what you once wanted...
takilara is offline        Reply With Quote Quick reply to this message
Old 07-29-2011, 01:44 AM   #20 (permalink)
Holy 2-year old thread, batman!
