mCP X Brushless Mods Blade Micro CPx Brushless Mods and Conversions |
08-01-2011, 04:28 PM | #1 (permalink) |
please help: DX4e for BL mCPX?
Is it possible to use DX4e on brushless mCP X?
I assume that high revs on rotor are a problem. Can I reduce them by putting resistor (or optimally potentiomerer) on brushed signal from 3in1? I am happy with brushed setup with DX4e. Is there any way to avoid buing DX6? Throttle curves and throtle curves are built in 3in1... Any thoughts? |
08-01-2011, 04:44 PM | #2 (permalink) |
Im flying brushless with the Dx4e, its not a problem, it would be nice to have curves to play with but it works ok for me. I fly 3d, and to be honest 100% max on everything is what I normally fly anyway.
Warning this hobby is very addictive and may damage your wealth. |
08-03-2011, 06:10 PM | #3 (permalink) |
I DO CONFIRM
DX4e works great with ADH50 motor with 1mm mainshaft!!!
I use Solo Pro tail motor which is suposed to be weaker than E-flite. Tail holds GREAT I Do recommend extension of tail to 17cm and usage of those cheap (at HobbyKing around 4$) tail motors and Solo Pro tail rotors. |
10-24-2014, 12:49 AM | #4 (permalink) |
Dx4e + mCPx BL
Bought a BL version and tried the dx4e but won't confirm its bound to a non-computer radio. Main blades will change pitch momentarily...
What's the trick? I would like to use the dx4e if at all possible. Thank you for your assistance. |
