Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger Electric Helis > Titan X50E
Titan X50E Thunder Tiger Titan X50E Helicopters
Old 11-18-2012, 08:03 PM   #1 (permalink)
Default Small problems; CF Gyro Tray mounting bolts and swashdriver arm play
Bought a nice new CF Gyro tray; http://www3.towerhobbies.com/cgi-bin...?&I=LXBYDX&P=Z
Looks great and probably stiffens up the frames a tiny bit.
Only one small problem, the countersunk bolts included to attach the plate to the cnc spacers are 2.5M bolts and the threaded holes on the spacers are smaller, 2M. I did not have any coutersunk 2M bolts in stock so I just drilled and tapped them out to 2.5M no problem, but they should have been right to begin with.
Also, I noticed a little side-play on both my swashdriver arms, where they bolt onto the head block. The play is pretty small so it might not really be that important? The arms themselves move very freely even when I hold them over to each end-of-play. The play seems to caused by the bearings being a little smaller than the arm driver bearing mounts. Anyone else noticed this?
Cheers,
TomC
Blade nQX,mCPX-BL,450x,500x Bell 222(bd3sx),550x(bd3sx)
TT X50E, 10s, bd3sx
Ion-x, Actro 32-3, SS, 10:1, PJazz esc, 10s
Now also a FPV addict; Quads and Planes (soon to try heli's!)
TomC is offline        Reply With Quote Quick reply to this message
Old 12-05-2012, 03:52 PM   #2 (permalink)
Also, needed to use a dremel tool to widen the countersink hole on the CF gyro plate so the screws would fit flush to the top of it. No big deal, just a small pita.
First maiden flight yesterday went very well btw. Very smooth and surprisingly quiet. Think I'm going to love this heli!
10s 4000 (2x5s)
Turnigy HeliDrive SK3 Competition Series - 4962-560kv (700mx clone),
15t pinion
HK YEP 120a esc (yge clone), gov'd at 1950, 2050, 2150 HS
fut9252 cyclics on 6v reg
fut9254 on tail (with align stepdown reg)
Gryphon QUASAR BEC (GSR-7075 LMT) @ 6v output (wired to esc battery leads)
ar7200bx (soon to replace with a new hc3sx + sats)
Edge 603 fbl main blades, Radix 92 tail blades.
Cheers,
TomC
TT X50E, 10s, bd3sx
Old 12-06-2012, 11:08 AM   #3 (permalink)
I agree this heli is sweet!! I love mine and it is only setup on 8s! Very quiet and smooth...only gripe I have is the play in the main blade grips drives me nuts!!!
raptorz499 is offline        Reply With Quote Quick reply to this message
Old 12-06-2012, 04:00 PM   #4 (permalink)
My grips do not have any play right now. If they develop some I'd probably just add shims.
Cheers,
TomC
TT X50E, 10s, bd3sx
Old 03-05-2013, 05:31 PM   #5 (permalink)
Just a quick update.
I removed the swash driver arms from the headblock, ground down the bearing sleeve/insert a tiny bit with a dremel, applied a tiny bit of locktite to the inner bearings, slipped the sleeve back in, applied a little locktite to the inside of the sleeve and headblock screwhole, and tightened it all up. Now there is zero side-slop, yet the arms are still nice and loose (fall on their own weight).
I also did this same proceedure with my front right pitch lever that also had a bit of side-slop and this has fixed that as well.
Now I just need to remove the slight up/down maingrip slop (caused by the main grip bearing holes being a little oversized imho) by either adding a shim or gluing in the main grip bearings with a bit of locktite or ca.
Still loving this heli but I really think that TT needs to improve some of their tolerances.
Cheers,
TomC
TT X50E, 10s, bd3sx
Old 03-06-2013, 02:39 AM   #6 (permalink)
Another quick update.
Used a tiny bit of med CA to glue the main grip bearings to the grips. After letting this set the up/down maingrip slop is gone! No add'n shims were required btw.
Cheers,
TomC
Old 03-07-2013, 05:01 AM   #7 (permalink)
Where does the cf gyro tray mount? I wish that it was not on top where the normal mount is.....
WessCo is offline        Reply With Quote Quick reply to this message
Old 03-07-2013, 04:00 PM   #8 (permalink)
Ya, designed to be mounted in stock top/back position. Works ok for me. If you want to mount it elsewhere, within the frames, you would need to grind the cf tray edges down a few mm's in order to fit (30mm total, and be careful that you take the same mm's off both sides).
Cheers,
TomC
