Go Back   HeliFreak > R/C Helicopter Support > Other Makes and Models Helicopters
Other Makes and Models Helicopters Other makes and model Helicopters
Old 02-28-2013, 08:41 AM   #21 (permalink)
Default Tail Boom Holders (Bag 2)
Next, the tail boom holders. Its important to use the M3x4mm Allen screws because anything longer would block the holes that that the bolts used to tighten the clamp on the boom would be blocked.
Logo 480 XXtreme, Logo 550SX, Logo 690SX, Logo 800 XXtreme, TDR, Minicopter Diabolo 550, Minicopter Triabolo, Goblin 500, Goblin 700, Goblin 770, KDS Agile 5.5, Voodoo 600, Voodoo 400, HD Cell 500, Thunder Tiger E700
taosgraveyard is offline        Reply With Quote Quick reply to this message
Old 02-28-2013, 08:43 AM   #22 (permalink)
Default FBL Plate
Using M3x4mm Allen screws, the FBL plate is installed.
Old 02-28-2013, 08:46 AM   #23 (permalink)
Default Diagonal Mounting Bracket (Bag 1)
Now, the Diagonal Mounting Bracket is mounted using M3x6mm Allen screws
Old 02-28-2013, 03:55 PM   #24 (permalink)
Default Lower Bearing Plates
Next the main shaft and lower intermediate shaft bearing plates are installed using M3x6mm socket head allen screws
[IMG]http://i592.photobucket.com/albums/tt3/ravenpath/voodoo/done/4%20LOWER%20MAIN%20AND%20CENTER%20BEARING%20PLATE/IMG_0830.jpg[/IMG
Old 02-28-2013, 04:02 PM   #25 (permalink)
Default Belt Tensioner
As I noted before, I am building a 600 from a 700 kit. The 700 uses a belt tensioner, which i will retrin in the 600 build. The 600 has a simpler set of rollers, but I like the fact that the 700 tensioner will tell you how much tension the belt is under. More on that later
the preassembled tensioner is in bag one (700 Kit)
Old 02-28-2013, 04:19 PM   #26 (permalink)
Default Re: Acrobat Voodoo 600 build thread
Please note Plöchinger isn't a fan of the tensioner on the 600. I had it but now fly without again. I like it better.
-TT E700 V2-vbar-mks950-980-Kosmik 160HV-Pyro 700 rewound by PD / Voodoo 600 -PD-MX700-470kv--BLS255hv-VBAR 5.3+- Gaui X3+Spirit Pro
velocity90 is offline        Reply With Quote Quick reply to this message
Old 02-28-2013, 06:17 PM   #27 (permalink)
Thanks for the info
And Why do you like it better?
It looks like the 600 tensioner can be made from the 700. Is that right?
Glad to learn... He really did not mention any reason not to use the 700 tensioner. But then I didn't ask. He did say it was ok to use but did not elaborate beyond that
Old 02-28-2013, 07:01 PM   #28 (permalink)
Didn't like the extra belt tension that is needed. Just hanging it by the tailboom with lipo and canopy installed suits me more.
Also the black rubber band can get off and lost easily.
Old 02-28-2013, 11:43 PM   #29 (permalink)
Good to know.
Losing the black rubber band would be a drag
Will look into changing this to 600. Need to look at the 600 to 700 conversion docs, I think the 700 one is made from the parts of the 600 one. If so, ill be able to make it into the 600 one.
Old 03-02-2013, 11:45 AM   #30 (permalink)
Default ESC Mounting Plate
Now, the ESC Plates goes in. This can also be mounted in a different way than I chose (for now anyway) . I have the plate in the front, but you can also have it
this is the alternative way to mount it, facing down, below the main bearing plate
Old 03-02-2013, 11:48 AM   #31 (permalink)
Default Chassis Spacers and Battery O-Ring Studs
The chassis spacers are in bag one, the silicon tubing is in bag 8
For mounting them, the o-ring studs have threaded studs screwed into them with locktite
done
Old 03-02-2013, 11:51 AM   #32 (permalink)
Default Assembly of Main Gear
Care must be taken not to over tighten the screws. That might warp the gear, and that will be detected becuase it will then be noisy. The manual says to just tighten 'until the screws clamp straight' and to use medium strength locktite
Old 03-02-2013, 11:58 AM   #33 (permalink)
Default Slight delay while waiting on a 600 size tail belt from Germany
As i wrote earlier, mine is a 700 but i am building it to be a 600. Had to get a belt for the 600, so until that comes, this build is on hold
Old 03-02-2013, 12:22 PM   #34 (permalink)
The front is the way to mount the esc in my opinion, more cooling. For other than jive you can also turn it around. I did this for my yge to fit.
ID:	399616   Click image for larger version
Old 03-02-2013, 03:11 PM   #35 (permalink)
Yes, I am going with it in the front - using a helijive
Old 03-04-2013, 08:19 AM   #36 (permalink)
Thanks so much for the photos although some are not showing up for some reason. Mine and Marcos are ready to ship so both can't wait . I am planning on running mine using the pyro 600-12, Jive 100 LV on 6S 5000mah battery, pinion will be the 17. I will be getting 2000 rpm at 73% throttle which is sweet. I have seen videos of the 600 fly great on this setup so i have to try and see. If i don't like i got the 23 pinion for 10S setup as well.
_____________
abanihani is offline        Reply With Quote Quick reply to this message
Old 03-04-2013, 09:42 AM   #37 (permalink)
i had moved the picts, so fixed the posts, thanks
Got my 600 belt today, will post more build pictures this afternoon.
Yes, Marcos had PM'd me about two 600s coming! We will have to stay in touch. Maybe we can get the forum to add an Acrobat Helicopter section
During my building this morning I discovered the Scorpion Scorpion HKII 4225-610 LE I am going to use does not work with the counter bearing. Emailed Stephan and as predicted he replied that this is true, and also as predicted, the Scorpion does not need it. On the TDR, Jan also says its not needed, and even says it will add unnecessary heat. Scorb mearings are bigger than Pyro bearings, and the shaft inside the motor is a larger diameter
picts to follow.
Old 03-04-2013, 10:08 AM   #38 (permalink)
I did run the 4225 without bearing and no problem. You will also have to take a little off the c-clip or better, get rid of the little edge in the plate with a dremel.
Old 03-04-2013, 10:19 AM   #39 (permalink)
thanks for the tip. i'll modify the plate
Old 03-04-2013, 10:44 AM   #40 (permalink)
welcome to VooDoo world
https://www.helifreak.com/showthread.php?t=485564
here are a lot of pics of two voodoo 700 i assembled with my friend
maybe can help you during the mount
my Prôtos twins & Acrobat Shark
urgno is offline        Reply With Quote Quick reply to this message
