Old 08-14-2014, 07:59 PM   #21 (permalink)
Check all bearings. They are cheap and make a difference if not smooth.
Actually Assault NMB bearings are very good.
In the past I was not impressed with bearings Align put to their kits. Especially 600 OWB.
I think Align 700 has good bearings. At least Align 700 sounds cool in flight.
utrinque is offline        Reply With Quote Quick reply to this message
Old 08-15-2014, 05:12 AM   #22 (permalink)
Originally Posted by Mike A. View Post
Man....now I'm tempted to get an Assault! Can you post the specifics on the motor and servos?
You can put motor and servos you choose. I recommend those:
http://www.hobbyking.com/hobbyking/s...ter_motor.html
http://www.hobbyking.com/hobbyking/s...07sec_68g.html
http://www.hobbyking.com/hobbyking/s...39sec_68g.html
Old 08-15-2014, 03:16 PM   #23 (permalink)
As I posted before the tail is not to my liking. The longer tail blades and adjustments in the Vbar did help. The tail servo is just not up to the task I guess. Although I did try to keep the overall cost down, the tail is not a place to cut corners. Not sure what servo is going on the tail yet but at least the one on there now can be used as a spare.
LOGO 200, DIABOLO 550, DIABOLO 800, SOXOS 7.1
VCONTROL*NEO*TRIBUNUS*MKS*VTX*DPL8 W/BUMP CONTROL*MEANWELL
Corvette & Copter Guy is online now        Reply With Quote Quick reply to this message
Old 08-15-2014, 10:11 PM   #24 (permalink)
Please check mechanic part of your tail including bearings in tail grips. I would look for excessive vibrations, friction and play. It is strange that my and my friends Benji Assault tails work fine with 815 BLS servo but you have a problem.
My point is that disappointing tail performance can be ralated to many factors other than servo.
Anyway replacing servo for test is good idea to check if it is the main reason.
Once I had strange tail wag in my 600. Replacing tail grips helped. Later I used the same tail grips in anothe heli and did not have any problems. Sometimes tail behavior is mystery. I assume harmonics can ruin our efforts sometimes. I also noticed that some play does not affect tail performance in bad way. I do not try to eliminate all imperfections of mechanic part at all price. For me it just works.
Keep in mind Jan Henseleit decided to use plastic tail grips instead of aluminium to reduce vibrations of stiff CB blades in TDR. Maybe you should just try plastic tail blades.provided in a kit just to check how they perform. I do not like those plastic blades because they seem heavy buy I used them for a while and everything was OK.
Good luck.
Old 08-16-2014, 03:49 AM   #25 (permalink)
I have a TDR. The grips are not plastic.
Greg
MSH USA Heli Flight Team
Mikado V Team
Lynx
el guapo is offline        Reply With Quote Quick reply to this message
Old 08-16-2014, 04:10 AM   #26 (permalink)
What year is your TDR?
From Henseleit webpage:
"The tail gear that has proved its worth in the predecessor was not modified and used again. The only difference is that the tail blade holders now consist of plastic material instead of aluminium. The main reason for this slight modification is that almost only carbon blades are used because of their better performance. These blades often produce slight and aggressive vibrations in connection with the too stiff aluminium blade holders. The plastic blade holders allow a better damping"
Old 08-16-2014, 11:20 AM   #27 (permalink)
a completely updated TDR..
this is the final manual
http://www.henseleit-helicopters.de/...anual-2011.pdf
Greg
Mikado V Team
Lynx
Old 08-16-2014, 11:26 AM   #28 (permalink)
All four of the servo's are Turnigy 1266 HV. I forgot I have pro on my Vbar so I will check there for any issues. I never put the stock plastic tail blades on. I have tried Align CF 105's and a cheap set of CF 115's.
Old 08-17-2014, 02:10 AM   #29 (permalink)
Greg I was reading last TDR manual few times in the past. Great source of information.
My quote is still on Henseleit website:
http://www.henseleit-helicopters.de/index_e.html
This is not the point. I just tried to help our coleague. Actually I fly many 800, 700, 600, 500, 450 helis. Only one has plastic tail grips.
My point was to show the way to find solution. Now I see that 1266 TGY servo is not dedicated for tail. It is great for cyclics. I have few helis with those rebranded Power HD servos. I would not put 1266 servo on the tail. TGY 805 is perfect:
https://www.helifreak.com/showpost.p...5&postcount=13
