Old 02-13-2015, 08:34 PM   #1 (permalink)
Default Koby 90, throttle Hold possition
Hi everyone, i need some help on setting my throttle hold possition for my Goblin 380.. Im using Futaba 18mz radio. what is a good starting point and up to what window gap i have to play with before it doesnt hold.. any recommended %... thanks Chris
Christo074 is offline        Reply With Quote Quick reply to this message
Old 02-13-2015, 09:29 PM   #2 (permalink)
After MODE 1 programming it has learned your TX endpoint values, so if you have programmed with a linear TC and endpoints at 100% both sides, then it will HOLD or CUT the throttle at the lowest value of the throttle endpoint. (0%). It does not have auto bailout so there are no "deadband" at the lower throttle setting and it will rotate the motor from about 12% throttle. It will only arm at 0% though.
VControl
Old hand at Planks
Peter
Old 02-13-2015, 10:00 PM   #3 (permalink)
Ok, as a brand new Koby 90 i plugged it in for the very first time and programed Mode 4 for heli.. that all i did. so your saying that setting a percentage value for Throttle Hold is useless...I cant use it as auto bailout, so if i accidentally hit Throttle Hold in mid flight im out of luck..? also id did not program mode 1 i thought thats how it come from factory.. Thanks Chris
Old 02-14-2015, 02:19 AM   #4 (permalink)
From the factory, the Koby is expecting to be taught end-points - this is your first collective throw from 0 to 100% aka programming mode 1. It's important that this be done deliberately and listening to the feedback beeps for confirmation.
The Kontronik remembers that (if done right) and uses that as a calibration for throttle input. If at a later stage you want to redo it - this is called programming mode 1, which resets it back to the factory expectation of throw calibration on first programming startup.
I'd suggest that if you are unsure if it was done right, just do it again.
So 0 throttle on your hold switch is going to keep the motor off.
The Koby doesn't have auto bailout.
| SAB Goblin 770 Competition Carbon | SAB Goblin 570 Carbon | SAB Goblin 380 | Mikado Vbar 6 PRO on all + Mikado VControl |
NLTRex is offline        Reply With Quote Quick reply to this message
Old 02-14-2015, 06:28 AM   #5 (permalink)
Ok i did not do or program mode 1 but I did mode 4.. i tested it on the bench after and it holds Does this mean it's fine or should I still go back and program mode 1 any way..
Old 02-14-2015, 10:30 AM   #6 (permalink)
Always program mode 1 first on a new setup!!
Magneto is offline        Reply With Quote Quick reply to this message
