Go Back   HeliFreak > R/C Helicopter Support > Gas Powered Thoughts
Gas Powered Thoughts Advice for Gas Helicopter Success from Carey Shurley
Old 05-02-2014, 09:35 PM   #1 (permalink)
Default Build - OS Max Trex 600 Conversion for GT15-600
GT15-600
Overview
Recently I presented the OS Max GT15-600 engine. I also noted that there were not very many models available that it could be installed in
One of the available models is a conversion for a Trex 600 nitro model. Its distributed by OS Max. Lets go over what it consists of
The conversion is packaged as shown
Conversion Kit Box
Here's what you find in side.
  • new frames (graphite)
  • bottom plate (graphite)
  • engine mounts
  • pinion gear
  • bearings
  • bolts
The graphite parts are cut cleanly and the machining on the metal parts is well done
Conversion Contents
Here you can see the two engine mounts as well as the new pinion gear
Engine Related parts
The conversion comes with a pretty simple conversion guide, its four pages hardcopy. Here are the instructions
Click image to see Instruction Manual
Donor Parts Needed
Its a conversion, so you need a donor model to convert. In this case its a Trex 600 nitro model. In basic terms this conversion isn't that different from using the original glow motor, its just larger so you're going to need most of the original model
you will not need the original side frames or bottom plate, the cooling fan or the fan shroud
Trex 600 Donor Parts
Also like most conversions you need some additional parts but much fewer than is normal for these things. You need a fan shroud from a Trex 700 DFC and an aftermarket high volume T600 fan. You'll also need gasoline proof tubing and the standard fuel clunk. I tried to use a felt clunk but the pump doesn't pull fuel consistently through it.
Its important to note, the fan shroud HAS to be from the DFC kit because its more narrow. Part number is H7NB011XX
Additional Parts
Although the fan shroud for the Trex 700 comes with a cooling fan, its recommended by OS to replace it with a high volume fan. Obviously this is a gasoline engine which runs much hotter than any glow engine so making the cooling system as effective as possible is important. Here you can see the std Trex fan on the left and the G-Force fan on the right. It will bolt directly onto the original Trex 600 fan hub
you can also use the Align CNC fan part number HN6060
Trex 700 Fans compared
you'll also need the OS Max GT15-600 engine. If you have the original GT15-HZ it will not work out of the box because the crank size is different and won't fit the Trex 600 fan hub.
OS Max GT15-600
you'll also need a properly designed exhaust for the engine, OS Max produces the Powerboost pipe, this is the same pipe used on the GT15-HZ engine
GT15 Powerboost pipe
the engine includes both an ignition system
GT15 Ignition system
as well as a special fuel pump. The GT15-HZ engine used a carburetor with a built in fuel pump. The GT15-600 uses a different carburetor that does not include a pump. So OS includes this fuel pump that is driven by case pressure
GT15-600 fuel pump
Whats unique about these last two items is that the conversion frames have specific mount points included for both.
Next Step
Frame Conversion
carey shurley is offline        Reply With Quote Quick reply to this message
Old 06-14-2014, 09:55 PM   #2 (permalink)
Default Build - OS Max Trex 600 Conversion for GT15-600 - Frame Conversion
The bulk of the conversion will be done in this step. You'll see that its pretty simple and well thought out
Converting The Chassis
If you follow my build threads you know that I rarely follow the assembly order in the manuals, I tend to pre-build assemblies which speeds the assembly process quite a bit. This will be no different.
Pre-Assembly
If you're converting an existing model then all of these components will already be built. If you're building from a kit then all of these components can be pre-assembled according to the original manual
Components to complete
Because this conversion uses gasoline, some of the parts in the fuel tank will have to be changed to gasoline resistant parts
I always suggest using a felt clunk, this is a Stens clunk which will fit into the tank without enlarging the hole. The inlet line also either needs to be viton or neoprene. Everybody seems to have their own preference as to what length they like to run these so cut to your own preference
Fuel tank Parts
Assemble the parts like this, slip the felt filter up onto the line, you'll see why
Assemble fuel inlet
The assembled clunk will be very hard to get through the tank hole but if you slip the filter up on the line its very easy to push the parts through. Then seat the grommet in the tank
Install Fuel Inlet
now gently pull the fuel line out until the filter reseats on the clunk. Don't pull so hard the tubing comes off of the clunk though
Seat Fuel Filter
Now just seat the fuel outlet into the grommet and the tank is done. You might use some oil on the fuel tubing or fittings to make the assembly more smooth
Fuel Tank Completed
Also, the entire tail boom assembly can be assembled if you're building from a kit, otherwise you'll need the entire tail boom
Frame Asssembly
These are the parts you need to build the first frame half, which in this case will be the left frame
Parts to complete Chassis
The conversion includes two flange bearings for the elevator bearings. The frame halves are identical but must be assembled in opposites. So Install the two bearings from the "outside" of each frame half. Use CA to hold the bearings in place
Install Elevator Bearings
The conversion kit includes a 22T pinion gear. If you a converting a built kit, then disassemble the clutch. Locate this bearing and nut and install it on the new pinon
Prepare Pinion
Then assemble/reassemble the clutch stack in the normal fashion
Assemble Clutch
when done, the new clutch assembly will be ready to install in the conversion frames
Completed Clutch
Select what will be the left frame. The flange on the elevator bearing should be on the outside and the letters HZ at the bottom should appear backwards. Locate one of the engine mounts from the conversion and install on the left frame as shown
Install Left Engine Mount
Now install all of the frame parts onto the left frame using the original fasteners. Use the mainshaft to align the bearing blocks. Fully tighten with thread lock where appropriate. This is how it looks when done from the inside
Completed Left Frame - Inside
and this is what you should see when looking at the left frame from the outside
Completed Left Frame - Outside
Now find the right frame and prepare it for installation. Install the remaining engine mount, the tank isolator and the landing gear mounts. Also install the fuel tank. Here's what you should see when viewing from the outside of the frame
Prepared Right Frame - Outside
and here's what you should see when looking at the inside of the frame
Prepared Right Frame - Inside
Now assemble the frame halves using all the original fasteners. Use thread lock where appropriate. Heres how it looks from the right side
Assembled Frames - Right Side
and the assembled frames from the left side
Assembled Frames - Left Side
With the frames combined, the frame bottom can be installed. The conversion includes a special plate and you'll need the original landing gear
Frame Bottom Parts
Install the bottom plate to the assembled frames using the M3 bolts included with the conversion. Note the position of the mount for the GT15 fuel pump. It will be installed in the next step
Bottom Plate Installed
With the bottom plate in place, install the landing gear in its original position
Landing Gear Installed
Partially completed chassis
Basic Chassis converted
Install the elevator/ail/pitch bellcranks. These will install through the bearings installed into the frames. You'll have to adjust the spacing using the washers originally provided with the donor kit
Install Swashplate Control components
Now the rest of the rotor head parts can be installed/connected
Install Rotor head components
Finally the complete tail boom can be installed
Install Complete tail boom
At this point, the "conversion" is really done, the only thing left is to install the engine itself
Next Step
Install Engine
Old 06-23-2014, 05:46 PM   #3 (permalink)
Default Build - OS Max Trex 600 Conversion for GT15-600 - Install Engine
Install Engine
With the chassis completed now the engine can be installed. Really the engine, EI system and fuel pump will be installed.
The std Trex 600 fan hub and clutch will be used however you must use a high volume fan. Align offers one as do other manufacturers
Hub/Fan/Shroud
Here you can see the difference between the stock Trex fan and the Align metal fan. The fins are much larger
High volume fan vs std fan
Assuming you want to run a governor or an RPM telemetry sensor, you'll need to install the magnets in the fan using an adhesive. Here you can see them installed. This is actually the top of the fan
Install sensor magnets
With the fan mounted on the hub you can see which side is "up"
Assemble fan hub
To mount the fan hub, the crank on the engine needs to be locked. Remove the backplate from the engine and use something small and non metallic (like a toothbrush) block the rod as shown
Lock crank
Push the fan hub over the crankshaft end and tighten down the crank nut until the hub seats on the top of the timing ring on the engine. Once this is done you can re-install the engine backplate
Tighten fan hub
The Trex 600 clutch can be installed as well
Install clutch
The conversion specifies that the fan shroud from a 700 DFC must be used. The reason is the width of the mounts. The DFC frame is more narrow. A std 700N fan shroud won't fit between the conversion frames because its too wide
DFC vs 700N Shroud
In order to install the shroud, some adjustments need to be made as the GT15-600 engine is slightly different than a std OS91. This regulator will interfere with the fan shroud and the shroud must be adjusted for it to fit
Shroud interference
Trial fit the shroud until you can determine the exact position that needs to be relieved and remove this small section of the shroud
Relieve fan shroud
You also need to open up the "glow plug" hole so that the larger EI plug cap will fit through it
Open Shroud for plug cap
I would HIGHLY recommend installing a telemetry temperature sensor. This engine runs much hotter than a std glow engine so its helpful to understand running temperature. I'd suggest putting a "loop" sensor here
Install temp sensor
and route the sensor lead like this
Temp sensor installed
If you intend to run a governor or telemetry RPM sensor, you need to mount the sensor. On the Trex 600 it installs here. I tried every conceivable way to use the Stator Gator but I couldn't get any of them to work
RPM sensor installed
If you are using a std RPM sensor, you need to relieve the fan shroud so that the sensor can align with the fan magnets. Trial fit the shroud until you can determine the right position to cut the fan shroud as shown
Relieve shroud for RPM sensor
Now go ahead and put the fan shroud over the fan
Fan shroud installed on engine
The conversion includes bolts for mounting the engine as well as some small shroud spacers. The DFC shroud is slightly too thin for the Trex 600 frame so they must be used properly mount the shroud
Engine mount parts
it will be VERY difficult to access the shroud spacers on the right side of the fan shroud, especially on the rear position. I suggest attaching them in advance using adhesive. You CAN install all four of them this way but the ones on the right are the most important. If you do all four, be careful not to get adhesive in the spacer/shroud or you may not be able to ever remove it again
Attach shroud spacers
Before the engine can be installed, the EI system has to be installed in the frames. The frames have specific cutouts sized for the EI box. Slide the system in through the back of the frames as shown
Position EI components
Route the EI plug lead between the tank and the lower main shaft bearing block and pull the EI system forward until it can be seated in the hole in the frame
Route EI wiring
The EI system "sits" in the frames and is held in place/centered using tie wraps. There are small holes in the frames to allow wrapping them around the EI box and holding it in position as shown
Install EI system
Once in place, if you look at the EI system from the back of the frame it should look roughly like this
Rear view of EI system
NOW you can insert the engine. It WILL go in with the bottom plate/landing gear installed but it is much easier if they are not on the model. You will NOT be able to get the engine back out without removing the lower plate/landing gear
It will align normally with the clutch slipping into the bell and over the start shaft
Insert engine
Position the engine as shown, making sure the shroud aligns with the mount holes. Be careful to make sure the shroud spacers don't get knocked off
Engine positioned
Use the supplied M4 bolts to mount the engine to the engine mount. At this point leave them just slightly loose so the engine can be moved with slight pressure
Attach engine
Looking from the side, make sure the clutch is fully seated in the clutch bell
Seat clutch in bell
Hold the engine from the back and using a spin starter, spin the engine over. This will self align the engine in the frames
Tighten two of the engine mount bolts and then go back and tighten all four using thread lock
Align engine
Install the M3 bolts that secure the fan shroud. Install any shroud spacers that have not already been installed. Position the shroud so that it does not interfere with the fan. Slowly rotate the engine and listen/feel for interfererence. Move the shroud slightly to eliminate any interference
Also if you are using an RPM sensor, you might want to set its position now for proper operation with your telemetry system/governor
Install fan spacers
With the engine installed, now you can install the OS Max fuel pump. The GT15-HZ engine has a large carburetor that contains a pump. The GT15-600 uses a smaller carburetor with an external pump.
Fuel pump parts
This conversion kit includes a specific mount point for the fuel pump, it goes here
Pump is installed here
Use the hardware supplied with the engine to install the fuel pump as shown
Pump installed
The fuel pump vacuum tubing must be cut to size. Cut it at about 10cm (100mm)
Size fuel pump feed tubing
Install the fuel pump tubing as shown. It installes on the nipple on the engine back plate and the small nipple in the center/back of the fuel pump as shown. You may need to lubricate the tubing as it fits tightly
Plumb fuel pump
and with that, the engine is installed. Here is how it should look from the left side
Engine Installed - Left view
and from the right side
Engine installed - Right View
After the electronics are installed, the fuel system will be plumbed and the muffler installed
Next Step
install electronics
Old 06-24-2014, 09:23 PM   #4 (permalink)
Default Build - OS Max Trex 600 Conversion for GT15-600 - Install Electronics
Install Electronics
Now install the electronics. With the exception of the EI system this is no different than the original Trex layout. Same servos. All the original linkages should work although the throttle rod may need to be adjusted
I'm using the GY750 FBL system which has a separate sensor/controller. So I mounted the sensor in the usual gyro position. You can see the Aileron servo installed as well
FBL Sensor/Aileron Servo
I mounted the FBL controller on the outside of the right frame and the receiver inside the radio "tray"
FBL Controller
Throttle servo installs from inside the frames
Throttle Servo
Here you can see the elevator/pitch servos. OS has added holes along the frame that make it easy to route the wiring and secure it with tie wraps
Elevator/Pitch servos
Std rudder servo and linkages
Rudder servo
Here's the difference, the EI system needs to be connected. The black sensor wire from the engine connects to the black trigger wire on the EI system. The red wire must go to a power supply. You can use a separate battery or you can just run it off the same battery as everything else
I use a Fromeco battery adapter which has an EC3 connector on one side and two std Rx connectors on the other. I plug one into the Rx and the other into the EI system.
EI wiring
I don't use switches, before/after each flight I simply plug/unplug the main battery into the Fromeco adapter
Electronics - Left view
Now you can connect all the linkages, power up the system and set up your controls. I set the initial throttle curve to: 13%, 27%, 37%, 47%, 100% and will adjust from there
Initial pitch is set to a max of 10 degrees and will adjust as the engine breaks in
I'll repeat an earlier note, I wouldn't try to run this engine without a telemetry sensor for temperature that you can set alarms for. This engine will not tolerate extreme overheating.
Next Step
complete model
Old 06-24-2014, 09:38 PM   #5 (permalink)
Default Build - OS Max Trex 600 Conversion for GT15-600 - Complete Model
Tank Plumbing, Muffer. Spark Plug, Blades
There are just a few steps left to complete the model
The fuel system needs to be completed. Use gasoline proof tubing like Tygon or Viton. I don't recommend neoprene as I've had issues with it splitting
You need to connect the fuel tank to the pump. The "inlet" is marked on the pump so run a line from the pump inlet to the fuel outlet on the tank. I'd suggest installing a T fitting here for filling/emptying the tank
Now run a line from the pump outlet to the inlet nipple on the carburetor. Finally make up a vent for the tank vent. You need to put a couple of loops in this or fuel will run out if you flip the model. You can also use a one way valve on this if you want although they tend to need more maintenance
Plumb fuel tank
The GT15 engine includes this spark plug made by RCxL. Be careful with it, it is fragile
Spark plug
The spark plug installs just like a glow plug, just tighten it until it seats fully
Install Spark plug
Now the plug cap goes over the plug. This needs to be pressed on hard to seat. This used to be a major source of problems as if the cap wasn't seated it would arc or back flow through the electronics and cause issues. OS added a spring that extends below the cap and contacts the cylinder head regardless. This should eliminate most of the electronic issues
Seat plug cap
This engine came with the OS Max Powerboost pipe. Especially designed for this engine, it provides the right amount of back pressure to prevent overheating but remains generally quiet
OS Powerboost Pipe
The muffler comes with a metal gasket, make sure its in place between the muffler and the cylinder before you install the muffler
Install muffler gasket
Here you can see the muffler installed. It mounts just like the normal OS max muffler with bolts that go through lugs on the cylinder from the intake side of the engine
Muffler installed
Wrap up the model by installing the rotor blades. I'd suggest no longer than 600mm main blades
Install rotor blades
And thats it for the conversion, its done!
Model completed
Next Step
Summary
Old 06-24-2014, 09:41 PM   #6 (permalink)
Default Build - OS Max Trex 600 Conversion for GT15-600 - Summary
Summary
When completed the converted model looks only slightly different than the original Trex 600
But the flight times will be completely different now
Next Step
Flying
Old 06-24-2014, 09:42 PM   #7 (permalink)
Default Build - OS Max Trex 600 Conversion for GT15-600 - Flying
coming soon
Old 06-24-2014, 11:40 PM   #8 (permalink)
How hard would it be to convert a 600 E to a 600G?? I so want to do this to one of my 600Es.
Ted
Ted Schubert
I always have fun. Some times are more fun than others.
I can't remember half the crap I forgot.
strat1960s is offline        Reply With Quote Quick reply to this message
Old 06-25-2014, 06:49 AM   #9 (permalink)
Hey Ted
well for sure you'd need the fan hub, clutch, clutch bell and bearing block and a main gear (170T).
What I don't know is are the frames the same width between the nitro and electric. If not you'd have to buy a lot of parts
the conversion kit states specifically it will convert:
T-Rex 600 Nitro Pro
T-Rex 600 Nitro V2 (limited edition)
T-Rex 600 Nitro DFC
Old 06-25-2014, 09:55 AM   #10 (permalink)
Carey, after hearing all the problem's with this engine, I'm still waiting to hear from some people that have gotten 5 or 10 gals of fuel through this engine with out eating it's self.
We had a great country once. You know what made it great? “I can.” Then the weak came along, “the I cant’s” and destroyed it.
Rudy is offline        Reply With Quote Quick reply to this message
Old 06-25-2014, 09:18 PM   #11 (permalink)
Carey what temperature do you set your alarms at for telemetry? I believe OS states an operating temp of 130c - 266f, but I wasn't able to find a overheating temp.
XL Power 700v2 Nitro NME - OS 105HZR - Power Tune - Rail 716/106 - Brain2 HD
Sowa is offline        Reply With Quote Quick reply to this message
Old 06-26-2014, 07:48 AM   #12 (permalink)
on my Zenoah motors I set mine for 365F with the tuned pipe.
Gasser Mike
Team KDE Direct, TRM Power, Byron Fuels, MKS Servos
LoveToFly1 is offline        Reply With Quote Quick reply to this message
Old 06-26-2014, 02:22 PM   #13 (permalink)
I've just started running this one, I have about a gallon through each of the original HZ engines without any issues
af far as the temps I think it depends on where you measure, right now I'm seeing 140ish temps but its 100 degrees outside here
I have learned that a felt clunk won't work with this fuel pump, need to go back and change a couple of steps
Carey Shurley
Proprietor - Gas Powered Helicopters
Old 06-27-2014, 10:02 AM   #14 (permalink)
Carey, how did you notice that? Because I use this felt clunk as well on my GT15HZ with the walbro carb. I don`t have any issues with it so far. But maybe I am just not sensible enough to notice it. Is the external pump weaker than the internal?
regards
Dennis
SAB Kraken 580, Pyro 600, HOBBYWING Platinum Pro 100A, Brain2
Miniature Aircraft Interceptor 600, OS MAX GT15HZ 2, Brain2,
Lynx OXY2, Micro Brain2
Bell 222 with T-Rex 600E chassis, V-Bar
breakout is offline        Reply With Quote Quick reply to this message
Old 06-27-2014, 04:53 PM   #15 (permalink)
That is interesting about the felt clunk. I was using the supplied felt clunk with the fourtitude tank, and didn't seem to have any issues with fuel delivery.
What clunk will you be using?
Old 06-27-2014, 05:50 PM   #16 (permalink)
I noticed because the pump kept pulling bubbles even with the tank full
So I plumbed a second tank with no clunk............no bubbles
replaced the felt clunk with one from a JR GSR model, it worked
I'll have to plumb in some sort of filter.............which I hate
On the original GT15HZ which had a similar carburetor and NO pump, I saw similar behavior. The current GT15HZ with the walbro doesn't care
Once I get the mixture and setup sorted I might try one more time just to make sure but all I changed was the clunk and the behavior changed immediately
Carey Shurley
Old 06-27-2014, 11:20 PM   #17 (permalink)
That's very interesting. I read your post right before I was about to begin the break in process on the rebuild from OS. I was a little worried as I too have a felt clunk in my tank.
Luckily, I'm at a fun fly and had Mr. Darby look over my helicopter and fired it up on the bench. We didn't notice any bubbles coming out of the pump, so I went ahead and put my 1st tank through the motor. I kept an eye and constantly kept checking for bubbles but I did not notice anything.
What is very odd about the situation is I too noticed bubbles coming out of the pump on my first go around with this engine. But I am also running a new pump as my original was lost in shipping.
Old 06-29-2014, 11:30 AM   #18 (permalink)
Great info on the build! Hope to do this early next year.
Blade MCP-X Brushless, 300CFX, , Trex 450 Pro v2, Trex 600 ESP 6s 3GX v.3.1 and KDE head, Rotormast V-22, Futaba 12Z controle!!
Stevendavis is offline        Reply With Quote Quick reply to this message
Old 07-16-2014, 08:39 PM   #19 (permalink)
Carey, I'm curious how many flights you have put on this setup? Any insight on the 600 version of the gt15hz and tuning?
Old 07-17-2014, 09:15 AM   #20 (permalink)
only a couple at this point, I'll have more detailed information in a bit when I can spend more time with it
Carey Shurley
