Go Back   HeliFreak > R/C Helicopter Support > Gas Powered Thoughts
Gas Powered Thoughts Advice for Gas Helicopter Success from Carey Shurley
Old 01-05-2017, 12:59 AM   #21 (permalink)
Originally Posted by Sowa View Post
Hard to believe but I flew this model in 15HZ trim for a whole season. Just decided to dable in Nitro again. My 15HZ is still healthy and on the shelf.
In gas trim it's close to a 50 class nitro. Makes flying cheap.
In Nitro trim it basically feels like an electric that smokes.
I honestly think that this airframe, is the most flexible IC design on the market right now. It can carry anywhere from 4 to 20oz of fuel, swing a 550 to 620mm blade with a decent selection in gear ratios, in either gas or nitro trim.
If only it was available to us mere mortals...
How do you make a small fortune in this hobby?
Start with a large one!
HelisRock is offline        Reply With Quote Quick reply to this message
Old 03-07-2017, 07:52 AM   #22 (permalink)
Default price and release
Hello everybody,
This kit looks very interesting for me. Now I have two or three questions.
- Is it possible to use as YS91 ST engine ?
- how high will be the price for that kit?
- When will be the release date? Because on the HP says available in fall 2016.
Thank you for your feedbacks
Pascal
paschgu is offline        Reply With Quote Quick reply to this message
Old 03-07-2017, 05:58 PM   #23 (permalink)
  • there are both glow and gas versions
  • technically you can use any glow engine that has a .9x format crankcase however I don't recommend you use anything larger than a .96 as you may have issues with vibration
  • $479 for either version
  • I have a small number of kits packed, I'd like to get them in the store next week.
  • I'll also have a couple of Sports editions GT15-600 engines
Carey Shurley
Proprietor - Gas Powered Helicopters
carey shurley is offline        Reply With Quote Quick reply to this message
Old 03-09-2017, 11:30 AM   #24 (permalink)
I have had good luck with an OS105 running a Dubro 14oz tank and getting 7+ minutes of flight time. Very little load on the OS105 with this size of heli and it is "Very" powerful as you would expect..
doug
TRM Power - RC Racing Engines - - Blackout Mods Conversions - - VP Racing / Powermaster Fuels - - Gas-Powered-Helicopters.com
Doug Darby is offline        Reply With Quote Quick reply to this message
Old 06-01-2020, 04:33 PM   #25 (permalink)
Since I can't create a new thread, I'll post on this one:
How do I recreate the nose down stance after this upgrade?
As you may (or may not) know, the racked stance on the ground is done in the Goblin 570's frame - not the landing gear struts. There is no "front" or "back" strut - they are both the same.
Since the nitro conversion kit uses the bottom plate to mount the engine, the side-frames are designed such that the bottom plate is "true" / "square" to the top-deck.
And, that eliminates the nose-down rack when resting on the landing gear.
"Who cares?" right?
Well, in my case, the tail squats down as the rear strut flexes as the weight settles - and the tailrotor blades dig into the dirt.
I've changed from the old style CF skids to the "Sport" style skid-pipes and because the struts are the same type of plastic, it is still a problem.
If I wrap a Velcro battery strap around the two skid-pipes behind the rear skid, I can cinch the strap tight and draw the skid-pipes closer. That will raise the tail about 1" and they don't flex under the helis weight.
If this was a Trex 700N, I would just add a 2nd set of rear skids.
Any suggestions?
By replacing your morning coffee with green tea, you can lose up to 87% of what little joy you still have left in your life.
... You can increase it by replacing said coffee with beer.
Old 11-04-2021, 12:02 AM   #26 (permalink)
Default G570 gear ratio
Is there a smaller drive pulley available than the stock 34 tooth that comes with the conversion kit? Id like to make a little more torque swinging rail 606s.
ChrisMatthews is offline        Reply With Quote Quick reply to this message
Old 11-04-2021, 11:18 AM   #27 (permalink)
32 or 36 tooth pulleys can be special ordered, also requires a different belt to adapt the different setups
Carey Shurley
