Old 06-18-2015, 10:47 PM   #1 (permalink)
Default New motor for the Nano CPX
Hey guys,
I made a motor for the Nano CP X.
Its similar in performance to the brushless motor, and it costs 2/3 of the stock replacement.
To good to be true?
Wait for it..
Im giving away the first 100 of them!
Note:
- You might have to muck around with the plug/wiring. Maybe my double-plug solution creates too much resistance.
- You will have to fit your own pinion.
chief scientist @ micro-motor-warehouse.com
benedikt is offline        Reply With Quote Quick reply to this message
Old 06-18-2015, 10:57 PM   #2 (permalink)
I ordered two...pinions and wiring is no problem
Edit: 31 minutes from time of order to receipt of shipping info with tracking number - Outstanding !
Old 06-18-2015, 11:32 PM   #3 (permalink)
Thanks for jumping on that so quickly, Jon!
We process orders as soon as we can, and make at least one shipping every 24 hours on business days. You will get another notification once it gets moving
Old 06-18-2015, 11:39 PM   #4 (permalink)
No problem...
I am assuming that the motor shaft is .10, correct? So the stock motor pinion will fit?
Old 06-18-2015, 11:48 PM   #5 (permalink)
The shaft diameter is 1mm. I just added that to the description
Old 06-18-2015, 11:50 PM   #6 (permalink)
That'll work...
I've got 1mm pinions in 7-8-9 and 11 tooth varieties...stock is 8, so I might just try a 9 and see what happens
Old 06-19-2015, 02:29 AM   #7 (permalink)
I am on the verge of retiring my nano due to motor frustrations! If I wasnt going away and unable to fly for few weeks, I would have ordered! I will keep a close eye on this!
|Black Thunder 700| Black Nitro 700 (building) | Logo 550SX | SAB G380 | Oxy 3 |
V-Control
QF-Servo | Lynx/OXY Heli & FPV field rep
Theunisjr is offline        Reply With Quote Quick reply to this message
Old 06-19-2015, 03:17 AM   #8 (permalink)
Got mine ordered. Nice one ...thanks.
Only problem is I now regret throwing away all my old motors...with pinions
If anyone has any burned out motors and wants to sell me their pinions pls drop me a pm.
Cheerz
Nick
Flying your heli the world is still out there, but at least for the time it hasn't got you by the throat.
Mini Titan E325 FBL, Blade Nano Cpx
nickyd is offline        Reply With Quote Quick reply to this message
Old 06-19-2015, 04:22 AM   #9 (permalink)
What size do you plan to use?
Old 06-19-2015, 04:27 AM   #10 (permalink)
I've only had experience with the stock 7t pinion.
I actually just found one in my bits box so am good to go.
Another thought...
I just stacked my FETs on my pjacq mild brushless ESC setup. It made a big improvement to torque performance.
Has anyone tried stacking the mainboard fet for the main brushed motor? If so, any difference??
I'm tempted to try this for the new motor tests
Cheers..
Nick
Old 06-19-2015, 04:29 AM   #11 (permalink)
Ordered, thx!
Micro: OMP Hobby M1
Big: SAB Goblin 500
Radio: Spektrum DX8 Gen 1
Old 06-19-2015, 04:31 AM   #12 (permalink)
Opps I guess you are right about the stock being a 7t...I was thinking of the mCPX @ 8t I guess...
I wonder what an 8t or 9t would do?
Old 06-19-2015, 06:24 AM   #13 (permalink)
This was long awaited day... Ordered.
Me_How is offline        Reply With Quote Quick reply to this message
Old 06-19-2015, 06:35 AM   #14 (permalink)
Been thinking....
I can't see how the gear mesh would work if we increased the number of teeth.
Is this possible? I have no experience in this, so just asking.
Nick
Old 06-19-2015, 06:45 AM   #15 (permalink)
It seemed to work ok...I put an 8t on a stock motor and did a test flight...mmm not bad...so I took it off to try a 9t...and popped the motor cap off
Hopefully the MMW motors will have better caps
Old 06-19-2015, 07:04 AM   #16 (permalink)
So I guess a 9t should have a higher headspeed but less torque??
Nick
Old 06-19-2015, 07:27 AM   #17 (permalink)
That would be My guess...
Old 06-19-2015, 05:38 PM   #18 (permalink)
End caps popping off is a common problem on these motors. We crimp them as hard as possible without breaking cap or deforming the housing, but it still makes sense to apply as little force as possible and support the cap while pushing.
I have bulk loads of 9T pinions: http://micro-motor-warehouse.com/pro...-for-1mm-shaft
Our motors tend to have more torque than other motors with similar coil speed. If someone of you can get the 9T pinions to work, I would include them with the motors in the future. But I assume the mesh will be too tight.
I did not find a wholesale source for pinions smaller than 9T with 1mm shaft, and reducing the shaft diameter didn't work out either..
Old 06-19-2015, 05:46 PM   #19 (permalink)
From what I can tell, the 9t pinions will NOT work...adding 2 teeth from the stock 7t configuration makes the mesh too tight and the motor binds
I've tried an 8t and it seemed to work as well or better than the stock 7t
Old 06-20-2015, 02:35 PM   #20 (permalink)
I ordered 3 .
The last stock motor on the shelf at my LHS has a price tag of 19.99 CAD. So these are a pretty sweet deal for me, especially getting one of them for free!
I have a couple 7t and 8t pinions to muck around with. I had alright results with an 8t using the 8.5mm motors.
As of right now I'm using an HH BL 'upgrade' so I'll be updating my thread soon, although Benedikt just solved all of my previous issues for me!
Thanks Benedikt for making these!
Heli's that I currently fly: Lynx Oxy3+ {Build In Progress!}, JR Forza 450 {hangar queen}, Blade 180CFX, Blade mCPX BL {work horse}, Blade NanoCPX - Blade Nano QX, Blade NanoQX3D - Phoenix 5.5 - Spektrum DX6 - - HeliFreak is great! -
Canadian_Jesus is offline        Reply With Quote Quick reply to this message
