Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Warp 360
Old 10-16-2014, 10:41 AM   #1 (permalink)
Default Mushy Collective
This is my first 450 size heli, so I am not sure what it is suppose to be like, but the collective feels very mushy, or slow to respond. I have a stock Warp, RJX blades, 12 deg, and 3000 head speed.
Do I need more head speed? More pitch?
Lets share some setups.
It was suppose to do that.
kineticheli is offline        Reply With Quote Quick reply to this message
Old 10-16-2014, 04:03 PM   #2 (permalink)
What's you're cyclic pitch? ( elevator / aileron range )
It should be around 8 degrees.
Put you're blades at 0 degrees and move you're right stick forward and measure with a gauge what's you're cyclic pitch.
And witch FBL unit you're using.
sven75 is offline        Reply With Quote Quick reply to this message
Old 10-16-2014, 05:44 PM   #3 (permalink)
The cyclic is fine, it is just a mushy collective.
It is a VX1e.
I did find a collective pitch boost function that I will play around with.
Old 10-16-2014, 07:32 PM   #4 (permalink)
I run about 13.5. Collective is ver poppy.
maarset is offline        Reply With Quote Quick reply to this message
Old 10-17-2014, 07:34 AM   #5 (permalink)
Could also be the blades... Somehow I felt the need to reduce expo on my Tx when I was setting up my X3. I am using RJX main blades and I felt the cyclic response especially at lower headspeeds was somewhat delayed.
XLP Specter NME | Oxy 5 550, 5 HF 560, 5 HF 610 | Compass Chronos, 7HVU, 550U, Atom | Gaui X3
cyclo is online now        Reply With Quote Quick reply to this message
Old 10-17-2014, 11:42 AM   #6 (permalink)
I have read other people saying the RJX blades are soft also. The Warp went in this morning, so I get to try new blades. I have heard good thing about Zeal, but is there something else I should be considering?
Old 10-17-2014, 02:09 PM   #7 (permalink)
Make sure all the linkages are sized correctly.
I'm very close to your setup and I don't have collective issues. I prefer the RJX blades myself. It makes moves like piroflips and zero pitch maneuvers a bit more forgiving around center stick. But once I dig into the collective, the heli responds sharply.
GravityJunkie is offline        Reply With Quote Quick reply to this message
Old 10-17-2014, 02:35 PM   #8 (permalink)
in my MSH Brain fbl unit i can program 3 different flight conditions.
Beginner / Sport / 3d / Hard 3d
I've linked the beginner / sport / 3d modus under channel 7 on my futaba transmitter and receiver under a switch. So i can switch between those conditions during flight and on the field.
The main difference between those conditions is the agility of the cyclic respons.
Beginner is very slow, and 3d much faster and directly
I think you have also something like this in you're system.
Old 10-17-2014, 03:36 PM   #9 (permalink)
I bought the heli used and all links where smooth. I will relink the whole heli when doing the rebuild.
Yes I have it too, but since this is my first VX1e, I wanted to keep it simple.
And again the cyclic feels great, fast and crisp. It is just the collective that feels mushy.
Old 10-18-2014, 12:01 AM   #10 (permalink)
I would, as others have mentioned above, different main rotor blades.
I have used the stock ones and two different variations of the KBDD's and the collective was nice and sharp.
You might find this thread interesting, as the O.P. had exactly the opposite issue-machine was too sensitive on collective. I went back and found it when I saw your thread:
https://www.helifreak.com/showthread.php?t=651194
Old 10-18-2014, 12:56 PM   #11 (permalink)
The warp is very aggressive on pitch, very weird (align blades +stock motor)
-TT E700 V2-vbar-mks950-980-Kosmik 160HV-Pyro 700 rewound by PD / Voodoo 600 -PD-MX700-470kv--BLS255hv-VBAR 5.3+- Gaui X3+Spirit Pro
velocity90 is offline        Reply With Quote Quick reply to this message
Old 10-19-2014, 07:40 AM   #12 (permalink)
Yep mines very aggressive with rjx 360. Blades are pumping
Rapid Helis Australia
Lighty is offline        Reply With Quote Quick reply to this message
Old 10-19-2014, 05:25 PM   #13 (permalink)
It is a VX1e.
With the Collective Boost at 0% the Vortex does not manipulate the collective in any way; if it feels mushy either you don't have enough collective range or the servos need to torque.
SPARTANRC - R&D
Angelos is offline        Reply With Quote Quick reply to this message
Old 10-28-2014, 11:54 AM   #14 (permalink)
So when rebuilding the Warp after a crash, I found that I had installed the lower bearing block upside down. The bearing had started coming out, introducing vertical play. This play was making the collective slow to respond, This is now fixed and should be all good now.
Old 10-28-2014, 12:49 PM   #15 (permalink)
good find
Anthony
raw 500, xl power nimbus 550,Tron 5.8 heritage, Tron Dnamic, cgy760-r, futaba
anthony1 is offline        Reply With Quote Quick reply to this message
Old 10-28-2014, 02:39 PM   #16 (permalink)
XL Power 520(soon to become a 480), Warp 360 , Tarot 360Sport, Logo480 LowRpm , Logo 500
T500 AP
Luigi_tuga is offline        Reply With Quote Quick reply to this message
