Go Back   HeliFreak > R/C Electronics Support > Futaba Radios and Electronics > Futaba 14MZ - 12Z
Futaba 14MZ - 12Z Futaba 14MZ and 12Z Help and features Support Forum
Old 10-05-2009, 09:43 PM   #1 (permalink)
Unhappy 14MZ Spartan
Trying to set up my spartan for the first time on my 14 cant get the servo configuring thing to work? Do i use gyro mode with switch d or atv? I'm at a total loss? PLEASE HELP!!!
n8rloves2fly is offline        Reply With Quote Quick reply to this message
Old 10-06-2009, 07:00 AM   #2 (permalink)
Default WOW
WOW no help ? I have it so it will blink once but not store?
Old 10-06-2009, 12:16 PM   #3 (permalink)
The following worked for me.
To be able to get into the configuration modes of the gyro go into the Gyro settings and activate the two first lines, set both to Type GY, one to NOR 50% and the other to AVCS 50%. The percentages are not critical at this time as long as they aren't to close to 0% for any of the two. Now configure your switch preference so that one switch position selects the first line and another switch position selects the second.
Flipping the switch between the selected positions should now show in the first column of the Gyro settings with toggling the two activated lines alternately between ON in green and OFF in red depending on the switch position. Looking in the Servo Monitor display should show the GYR channel changing when you flip the switch (with the column height depending on what percentages you selected).
Note: If you configure your gyro switch to only select between different AVCS gains you may not be able to get the gyro into configuration mode. The gyro channel needs to change between Rate and AVCS output levels for this to work.
Hope this helps.
Tomas Ahl is offline        Reply With Quote Quick reply to this message
Old 10-06-2009, 12:33 PM   #4 (permalink)
You need to toggle the switch once more until the LED is steady on. Only then the changes are stored.
-Angelos
SPARTANRC - R&D
Angelos is offline        Reply With Quote Quick reply to this message
Old 10-06-2009, 01:51 PM   #5 (permalink)
i put the normal to normal 0% and the idle 1 to normal 100% and i start toggling...
Also on the conditions tou must have and the idle 2...!
MaSt0RaS is offline        Reply With Quote Quick reply to this message
Old 10-06-2009, 07:39 PM   #6 (permalink)
Smile SWEEETTTTT!!!!
Thank you thank you thank you 49% GY off 100% gy on worked great!!!
What should my gains be? K3D 600e
Old 08-21-2011, 10:57 AM   #7 (permalink)
Is there any compability issues with the Spartan Quark wit the 14MZ?
Kasama Srimok 90: JR8917HV all round | YS91SR | Hatori 946 | Spartan Quark | BLS251
http://nitro-magic.blogspot.com
TmMugen is offline        Reply With Quote Quick reply to this message
