Old 07-09-2008, 09:51 AM   #21 (permalink)
Team Taco VP
Yes I will continue to use my 1010 as well as the BC6 for all my types of packs and of course for 10S the 1010...
Bob
Old 07-09-2008, 02:40 PM   #22 (permalink)
Excellent videos as always. Any chance of a run down on software and how to interpret it correctly and how it can be of help?
Rgds
Aidi
Akulla is offline        Reply With Quote Quick reply to this message
Old 07-09-2008, 03:13 PM   #23 (permalink)
Team Taco VP
Yes I plan to do an update using the software.... First I gotta learn it
Bob
Old 07-09-2008, 03:14 PM   #24 (permalink)
Lol Good on ya mate.
Rgds
Aidi
Old 07-10-2008, 02:13 PM   #25 (permalink)
The Capi
Nice looking charger. Wonder how it will compare to the cheaper TP-610C.
Old 07-10-2008, 02:33 PM   #26 (permalink)
The BC6-10 has considerably more power, 200 watts compared to 80 watts of power. It supports all the major battey taps on the market as well, the TP does not.
RC Accessory is offline        Reply With Quote Quick reply to this message
Old 07-10-2008, 02:37 PM   #27 (permalink)
The Capi
Okey. Iam not a fan of charging at 2C so didn't consider that as part of the cost difference.
Old 07-20-2008, 02:06 AM   #28 (permalink)
I bought the BC-610 several months ago and its now my favorite charger (other charger is the Astroflight 109 which is way too loud in comparison). Even got the series adapter for charging my 3S batteries together. The other nice feature is the cycle charge mode for NiMH which I use to run out the TX battery and then fully charge afterward.
Once I started playing with the charger I purchased balance extension cables for the series adapter and regular 6S adapter since it makes it easier to plug in the taps to the extension instead of the adapter board. Also, it helps that this is a 200W charger when working with 6S 5350mAh batteries being charged at 7A.
Logo 500 3D /Scorpion HK4020-1100KV (16T)/Jazz80/BLS451/Spartan DS760/BLS251/RT 560mm/AR9000
TRex 450SE
/Scorpion HK-2221-8 (13T)/ AlignESC35(X)/ HS65MG/Spartan DS760/S9650/AR6100
Spektrum DX7
BruceW is offline        Reply With Quote Quick reply to this message
Old 07-21-2008, 06:45 AM   #29 (permalink)
Registered User
This looks like a nice charger thanks for reviewing it Bob!!
William James
Old 07-21-2008, 10:32 PM   #30 (permalink)
Hope this is a good place for this question...
So I have a Thunder Power 5S 3300mAh battery with approx 25 flights that whenever I try to balance charge with a BC6-10 it gets to the last stage (well, what I am assuming is the last stage - charging @ 0.1ma) and never finishes... it will sit there til the time limit trying to balance the last few tenths of a volt.
Watching the cell voltages doesn't help much - they all fluctuate between 4.19 and 4.2 - so I can't tell if one of the cells can't make it that last 100th of a volt or what.
You think this means my battery is hosed? It has never been through a crash.
T-Rex 500ESP + T-Rex 550 vbar + T-Rex 600NSP + T-Rex 700n
MrWindupBird is offline        Reply With Quote Quick reply to this message
Old 07-22-2008, 07:41 AM   #31 (permalink)
I hope someone has an answer. I have the same problem with an XCite 6S 5000 battery that is virtually brand new. I have a MaxAmps 6S 5000 that charges just as expected.
flymustangs is offline        Reply With Quote Quick reply to this message
Old 07-22-2008, 01:50 PM   #32 (permalink)
Team Taco VP
Yep the battery is having a hard time balancing. That means it is basically on its way out. You can extend the timer as see if it eventually balances but long term it's only going to get worse.
Bob
Old 07-22-2008, 01:56 PM   #33 (permalink)
I was hoping these would be moved to the Bantam Support forum. There could be another reason. If the EAC connection board is worn for example, the increase in resistance can cause the same symptoms.
The TP/FP boards, the TP taps are very hard on the sockets. Most people do not properly remove the tap and wiggle it out of the socket. This strains the socket on the PCB board. If the socket becomes loose for example, it can cause the same symptom.
Many people recommend removing the latch off the TP tap. Much easier to insert and remove from the socket.
Old 07-22-2008, 01:59 PM   #34 (permalink)
Team Taco VP
Very true and good point! I ruined one of my TP 1010 balancers because the socket broke off from the strain of unplugging over time.
I now remove the tabs on all my packs!
Bob
Old 07-22-2008, 03:00 PM   #35 (permalink)
That's why I purchased the tap extension cables.
TRex 450SE
Spektrum DX7
Old 07-24-2008, 07:38 PM   #36 (permalink)
Default BC6
Hi !
Ok I’m have one (e-Station BC6)
I have the cable connected to computer and a temperature sensor.
Where I connect it? (Temp. Sensor) I need an Y cable!
Can i use for that?
If we have the charger connected to computer we can’t use the temperature sensor?
Why in the software we have temperature sensor monitoring?
I’m confused
Nuno
Wirestealth is offline        Reply With Quote Quick reply to this message
Old 07-24-2008, 08:43 PM   #37 (permalink)
Originally Posted by canizes View Post
Hi !
Can i use for that?
I’m confused
Nuno
On the BC-6 only (not BC6-10 or BC-8) you can only use the temp sensor or the USB connection at a time. In the User Setup you select which one you want. They share the port.
The software works on numerous Bantam chargers so it can display the temp if used on other Bantam Chargers.
Old 07-25-2008, 11:58 AM   #38 (permalink)
Thanks for the fast replay ! ok i think i will buy the bC6-10 im loving this charger very much !
I have an OLD - Schulze Isl 6-330d its a great charger but .....
Thanks for the great suport
Nuno from Portugal
Old 08-05-2008, 04:37 PM   #39 (permalink)
Default Video on software ?
There was a promise of a video for the software that can be run with this unit ???
Any progress ???
Ha.kan is offline        Reply With Quote Quick reply to this message
Old 08-05-2008, 04:55 PM   #40 (permalink)
Team Taco VP
It's on my list to do! Stay tuned as I will do it sometime after IRCHA...
Bob
