Go Back   HeliFreak > R/C Helicopter Support > 800 Class Helicopters
800 Class Helicopters 800 Class Helicopters
Old 08-27-2013, 07:07 AM   #41 (permalink)
The 2 6s packs are fine for the 800 you not reading what I said or reading into it to much
I was trying to brake the heli and didn't let up for 4 min with packs that only had 4 to 6 easy flights on them
The packs i used after this flight where hotter then i like, which after a charge needed 3800 back in i need to brake them I feel i need to due at least 10 flights for brake, After that i will due a few normal 3d flights and like to see how much i put back in at a 1960 head speed, what i was trying to due was not normal keeping the heli loaded with 14* pitch and 8* cyclic never letting up.
The 780 blades are fine. No issues there for the setup.
hope this clears up what i was trying to say
Dino
Dino Spadaccini Team Capt Align Factory Team USA / Team Futaba
Dino Spadaccini is offline        Reply With Quote Quick reply to this message
Old 08-27-2013, 10:40 AM   #42 (permalink)
OK.
Will 7s 5000 packs fit and how will they affect CoG if its designed for 6s 5200? as the 7s 5000's I use are just shy of 1kg each.
Or is that just due to the limitations of the supplied equipment?
Thanks for the info so far
The difference between knowing your s**t and knowing you're s**t!
Optipower - Kontronik Drives
jamin_00 is offline        Reply With Quote Quick reply to this message
Old 08-27-2013, 10:48 AM   #43 (permalink)
you get long packs, you get thick short packs, so actual dimensions are far more usefull than saying XX random fitment.
honey bee king II
andersn is offline        Reply With Quote Quick reply to this message
Old 08-27-2013, 10:54 AM   #44 (permalink)
Of course
158mmx44mmx58mm. 939g each.
Old 08-27-2013, 02:40 PM   #45 (permalink)
i just measured mine, and there is plenty of room. 85mm height, and 49mm wide, but that is the max..
hobaoe is offline        Reply With Quote Quick reply to this message
Old 08-27-2013, 05:36 PM   #46 (permalink)
Default Re: New 800 DFC coming build time
Thanks.
Sent from my GT-I9505 using Tapatalk 2
Old 08-27-2013, 06:12 PM   #47 (permalink)
Originally Posted by jamin_00 View Post
Of course
Jamin,
I've taken a few pics for you of the 700 and 800 side by side with my 700 Turnigy 5000's in (12S). As you'll see, there is a heap more room below the packs in the 800, due to to the taller frames, obviously.
Hope this helps
ID:	446582   Click image for larger version
ID:	446583   Click image for larger version
Bonkievan is offline        Reply With Quote Quick reply to this message
Old 08-27-2013, 09:14 PM   #48 (permalink)
If I run two Turnigy 6s 5000mAh 40C packs should I be setting around 1600-1700rpm? Is 1850rpm too high? Will it bog down? Or make the batts puff out
I know some people aren't too fond of Turnigy packs, but they are half the price...
I'm not doing crazy 3d but do like to toss it around a bit
Opinions welcome
Rcbous is offline        Reply With Quote Quick reply to this message
Old 08-28-2013, 02:00 AM   #49 (permalink)
Originally Posted by Bonkievan View Post
Jamin,
Hope this helps
Excellent, thank you for that
I notice there is a frame brace at the back there, how close do those 6s packs get to that as I imagine I will have to push the 7s pack back to get the CoG correct?
I have found a dealer that will do me a kit to
Old 08-28-2013, 03:23 AM   #50 (permalink)
No probs', Jamin,
From the back of the rear pack (as it is in my photos) to the frame brace, is 3.5inches. With that in mind, you should have plenty of scope to get the CoG right with 7S packs.
Good news regarding the bare bones kit.
BTW, there should be a couple of 7S Logos at a fly-in I'm going to on the weekend. If I'm able, I'll try to borrow a couple of 7S packs and a get some pics and measurements of them installed if you like??
Old 08-28-2013, 04:07 AM   #51 (permalink)
No probs', Jamin,
That would be excellent. I would just like to know that there is enough room to move the packs forwards and backwards for CoG and then I think Im done with the enquiring A team pilot of mine over here is about to order one also so there could be a few of them flying around
Old 08-28-2013, 04:48 AM   #52 (permalink)
Ok, all good. I look forward to hearing of developments going the 7S route.
Old 08-28-2013, 04:58 AM   #53 (permalink)
Opinions welcome
I think your best option would be to just try the Turnigy;s, if you already have them of course, and see how they perform with your setup. As you know, there are quite a few variables between setups so quite hard to give a definitive answer.
But yes, generally a higher quality/C pack should yield better results imo
Old 09-01-2013, 05:56 PM   #54 (permalink)
Sorry Jamin,
The guy with the 7s batts didn't bring that particular Heli to the field on the weekend, so couldn't get to try in the 800, obviously.
Old 09-02-2013, 01:20 PM   #55 (permalink)
No probs.
One of my fellow team pilots is gonna get one so I'll be hopefully seeing him the weekend so will be able to check for myself
Old 09-02-2013, 09:20 PM   #56 (permalink)
4.0 3gx
Just out of camera view sorry about that i do more vids this week 4.0 is a vast improvement in the 3gx Jamie did a great job with version
there are few spots where i am in frame but you can hear a 4.15 flight always loaded [ame]http://youtu.be/xtJOp5nSNnY[/ame]
Old 09-03-2013, 11:32 AM   #57 (permalink)
hunch is offline        Reply With Quote Quick reply to this message
Old 09-13-2013, 04:42 AM   #58 (permalink)
I just orderd one...
what pinions are avaible? for 490KV I guess I need to drop 1 tooth to run 14s.
honestly the only 12s packs I have, are 4000 and 4400... so well either very very light 12 on this, or we will see
my first eletric align in ages!
I allready own a logo 800 and 770 goblin, and getting protos 800... so definetly decked for a shootout!
honey bee king II
Old 09-19-2013, 09:45 AM   #59 (permalink)
i am going to try the 13/110
stock is a 12/112
Old 10-01-2013, 07:17 PM   #60 (permalink)
Thanks to forums and very nice people, i hope my new trex800 build goes well. Glad this thread is here. Heli should arrive thursday. I ordered some 5000mah 60c but do you guys think i can get some test flights with some gensace 3300 mah 60c?? Maybe 2 minute flights? Low head speed? Mild 3d??
TREX 800 DFC PRO HV , TREXIKON 600 EFL PRO , LEAP 3D QUADCOPTER
Heli biggie is offline        Reply With Quote Quick reply to this message
