Old 10-05-2012, 12:01 AM   #1 (permalink)
Exclamation SBUS Issue
Hi Folks
I have worked all night long and could not get R7008SB to run. I have the SK SBUS wire contented. I have all the servo wires attached to the SK. I have the BEC contected to the SK at the IO B port it lights up the SK system. I have up load that it is a SBUS receiver. What else do I have to do to make it work.
filtr is offline        Reply With Quote Quick reply to this message
Old 10-05-2012, 02:45 AM   #2 (permalink)
what do you mean it's not working? Please explain in a bit more detail.
thefrog is offline        Reply With Quote Quick reply to this message
Old 10-05-2012, 03:38 AM   #3 (permalink)
If this is a 720 you have the Rx attached to the 720 with special lead? Try the other port next door.
If this is 540 then this should be connected to IO-B! with ordinary servo lead.
Is there power to the Rx? is the light on?
Have you bound the Rx to your radio?
SimStream wireless from your transmitter to simulator
http://www.modelguard.com
ModelGuard is offline        Reply With Quote Quick reply to this message
Old 10-05-2012, 03:51 AM   #4 (permalink)
You have the sbus lead connected like the one on the left in the picture?
Old 10-05-2012, 04:27 AM   #5 (permalink)
Don't forget to use a power lead from the Rx to the SK (a servo lead with only + and -, no signal).
Old 10-05-2012, 04:56 AM   #6 (permalink)
Yeah. As Frog just said you will need to run a lead like the Sk ones that go from Sk to power bus and take out the signal wire. This will now give enough power to the rx.
Sent from my iPhone 4s using tapatalk
Oxy 3 SK540 Minijazz 20 / WARP 360 SK540 Koby 55 / Goblin 500 SK540 jive 100 / 6HV ultimate Helijive120 SK540 / 7HV SK540 Kosmik200 / Futaba18mz / Skookum support rep
heathy is offline        Reply With Quote Quick reply to this message
Old 10-05-2012, 05:28 AM   #7 (permalink)
that wont stop the system working on the bench though, it just prevents brownouts
Old 10-05-2012, 06:44 AM   #8 (permalink)
Mine did, when using the 720 with the s-bus adapter cable the rx wouldn't get a green light, instead i got a red/green flashing power warning. Used the lead without signal and all was well
Old 10-05-2012, 07:01 AM   #9 (permalink)
I take my comment back then!
Old 10-05-2012, 08:15 AM   #10 (permalink)
It was something to do with the output voltage through the s-bus adapter lead being just under the futaba's required voltage. It was just under. Lucky the futaba Rx's are high voltage as i'm pumping 8.4v into mine..
Old 10-05-2012, 10:28 AM   #11 (permalink)
Hi Folks
I have the SBUS going to the SK unit the way the photo shows. I have the power from BEC going the SK unit only. How should the power be getting to the RX. I have the SK power connected to the IO-B port only.
Thnaks
Old 10-05-2012, 11:32 AM   #12 (permalink)
Originally Posted by filtr View Post
Hi Folks
Thnaks
Take servo lead, remove the signal wire (white/orange) and plug one side of the remaining lead (with a + and - wire) an open port on the SK and the other into an open port/ power port in the Rx.
Old 10-05-2012, 11:39 AM   #13 (permalink)
Thanks for the info I will give it a try.
Old 10-05-2012, 11:50 AM   #14 (permalink)
=] yes an open port, but not the ex-led!
Old 10-05-2012, 07:32 PM   #15 (permalink)
This thread has got me concerned. I've got an SK-540 connected to a 6208 SBUS rx. I've only got one cable going to that RX: the SBUS lead to IO-B. I'm running a 2S lipo into the SK540. No problems so far, 7 flights in.
How much power does the RX need? Why isn't one servo lead good enough? I'm missing something here...
* Goblin 700C, iKON, Torq 9180/9188, Quantum 4530-500, Edge HV160, Cyclone 695
* Outrage Fusion 50, SK-540, Torq 9180/9188, Quantum 4135-530, Edge HV80, SAB 630 Blk 3D
* Align T-Rex 500E DFC, SK-540, ICE 75
* Futaba 14SG
Arcturus97 is offline        Reply With Quote Quick reply to this message
Old 10-05-2012, 09:14 PM   #16 (permalink)
As you can see the power is contented to the receiver. Then I contented a cable from the receiver to the SK unit for power. Then I contented the SBUS wire. When plug the power in the receiver works. Then I contented the power to the SK the red light stays on till i move the throttle up to full then it turns green but dose not pump
The servo start to chatter. When I move the sk unit it tries to move the servos that are contented.
What is the problem.
ID:	355309   Click image for larger version
ID:	355310   Click image for larger version
ID:	355311   Click image for larger version
Old 10-06-2012, 02:02 AM   #17 (permalink)
You only need to worry if you are using the sk special sbus lead .you are using a servo lead you are fine
Sent from my GT-I9300 using Tapatalk 2
Old 10-06-2012, 03:52 AM   #18 (permalink)
=] throttle reversed in the Tx?
Old 10-06-2012, 04:21 AM   #19 (permalink)
Georgi got there 1st!
Ps. The lead that you've used to take power from a spare port to the rx should be plugged in all the time. It's only when you make your normal connection that it all becomes live.
Old 10-06-2012, 04:42 AM   #20 (permalink)
Got it, thanks
* Futaba 14SG
