Go Back   HeliFreak > R/C Helicopter Support > Gasser Helicopters
Gasser Helicopters Gasser Specific Discussion
Like Tree58Likes
Old 01-25-2015, 03:32 AM   #101 (permalink)
You are jumping to a conclusion now. The same is true for all kind self mixed fuel. Some love a particular brand of oil, other hate it. By the way, most of the time you read that something didn't work out for somebody. That many people had no problems at all you don't read.
PPJHEN is offline        Reply With Quote Quick reply to this message
Old 01-25-2015, 05:47 AM   #102 (permalink)
I'm not gonna argue anymore about this, I use Aspen 4T with the best oils available and recommended by the engine builders, nothing else.. you use premixed Aspen 2T or whatever rocks your boat. Everybody's happy.
Peace!
Gas Goblin 700 - Goblin 380
VBar Control - VBar NEO
Rubin RC - Gas Powered Helicopters - TRM Power
Matwes is offline        Reply With Quote Quick reply to this message
Old 01-25-2015, 08:15 AM   #103 (permalink)
No offence meant. I am sure your mixture will work ok. I did some additional research and it seems that Aspen 4T is the same as the Aspen 2T but without the premixed synthetic oil. I am thinking to get some additioanal Aspen synthetic oil and get the mixture to 1:30 or 1:40 for the new engine. I don't know if you can mix two different kind of synthetic oils.
Old 01-25-2015, 12:20 PM   #104 (permalink)
Hi,
I also use Aspen fuel, but the 2T version. it is odorless and will not go bad for years. Is there a reason you prefer the 4T?
Paul
Hi Paul, The reason I'm going to get the Aspen 4 is because I have two bottles of Amsoil Saber oil. The 4 is the same fuel as the 2 just without the oil premixed so it should still last a long time and be fairly oderless etc.
In the past I have just used regular petrol but wanted to try the Aspen fuel, only it was not as widely distributed a few years ago and now there's a shop that stocks it fairly close.
HD Cell 750, RJX Vector, TDR, TDSF, Kasama Dune and Faifa, Minicopter Triabolo 700, Beam Avantgarde, JR E8 leggero, Suzi Laos, Shape 9, Shape S8, Rave 450, TRex 500, Raptor E700, Compass Warp, Steam 700, Spirit, Spartan, Jeti.
trillian is online now        Reply With Quote Quick reply to this message
Old 01-25-2015, 12:51 PM   #105 (permalink)
Non taken!
I have professional experience with Aspen Fuels. Their 2T fuel is not made for the extreme engine speeds we are using in our helicopters. That fuel is made for engines that are running at significantly lower rpms = less stress on the parts. There is a difference!
If you're going to add oil to the 2T mix, why not go the whole way and use 4T mixed with the best oils suited for high power, high rpm, high temperature engines? I'm using Motul Synth 2T outboard oil. This oil is keeping my engines clean inside and the engines are running very well with no heat problems. Mix ratio 1:32.
Old 01-25-2015, 04:52 PM   #106 (permalink)
As you already have seen, I started an new thread about this theme. I got a fresh can of 2T for a very good priice. Also I am not going into the very high rpm's (no modified engine) and I had good experince in the past ( als other people I know). I will surely try the 4T with recommended oil in the future.
Old 04-18-2015, 09:21 PM   #107 (permalink)
My Leviathan Goblin Gasser 630
Chris Reibert is offline        Reply With Quote Quick reply to this message
Old 04-29-2015, 08:18 AM   #108 (permalink)
Old 05-05-2015, 09:33 PM   #109 (permalink)
From the field today
This thing freaking rocks!!
Unfortunately, I killed an almost new pair of edge tail blades
Keith
Goblin 700C Gasser -- Goblin 700C -- Goblin 570 -- Gaui NX4
#29
gcac399 is offline        Reply With Quote Quick reply to this message
Old 05-08-2015, 02:51 PM   #110 (permalink)
I have to say, those Goblins are very sexy beasts! I didn't really have much interest in the electric Goblins but the gasser conversions are seriously cool.
Old 05-08-2015, 10:15 PM   #111 (permalink)
Seriously!
Matwes, your 700 with the 3 blade and QD is SICK!
How do you make a small fortune in this hobby?
Start with a large one!
HelisRock is offline        Reply With Quote Quick reply to this message
Old 06-04-2015, 07:37 PM   #112 (permalink)
Default Resurrection of a RAPTOR 30 V2
i took my old Raptor and installed a go engine GH-56 gasser, im just in the breaking in stage, but i think it was a cool idea
ID:	589422   Click image for larger version
ID:	589423   Click image for larger version
ID:	589424   Click image for larger version
ID:	589425   Click image for larger version
ID:	589427   Click image for larger version
ID:	589428   Click image for larger version
ID:	589429   Click image for larger version
ID:	589430   Click image for larger version
ID:	589432   Click image for larger version
ID:	589433   Click image for larger version
ID:	589434   Click image for larger version
ID:	589435   Click image for larger version
ID:	589437   Click image for larger version
ID:	589438   Click image for larger version
ID:	589439   Click image for larger version
ID:	589440   Click image for larger version
ID:	589442   Click image for larger version
ID:	589443   Click image for larger version
ID:	589444   Click image for larger version
ID:	589445   Click image for larger version
ID:	589447   Click image for larger version
cruzroy is offline        Reply With Quote Quick reply to this message
Old 06-06-2015, 07:02 AM   #113 (permalink)
Nice! What size blades 550 or 600? Did it take a lot of work to get the motor mounted?
Too many Heli's to fit in my sig, current favorites: Whiplash 700 Gasser, Gaui X2, X380 and X480, Trex600e-dfc
Hexperience is offline        Reply With Quote Quick reply to this message
Old 06-07-2015, 03:58 PM   #114 (permalink)
Default Helix 700
My slightly stretched Helix 700maiden flight today (well it had flown before but it's new to me and I also made a few minor changes).
This is with NHP 742mm mains and 110 tails but they felt a bit sluggish to me so next time I'll try some 710s.
Old 06-07-2015, 04:11 PM   #115 (permalink)
Received my new Canomod "Red Eyes" canopy and boom set
Old 06-08-2015, 02:51 PM   #116 (permalink)
Default 550 blades
trying to keep it small
and the GO- Engine guai t-10 and rotostar gasser engines are drop in with 50 raptor mount
take a look https://www.helifreak.com/showthread.php?t=693167
Old 06-24-2015, 12:26 AM   #117 (permalink)
Default Leviathan Gas Goblin 630
Heres my GG630.
Goblin 630
Leviathan conversion kit
TRM VX300 SE motor RJX pipe
BK servos cyclics tail and throttle
Ikon flybarless unit with twin DSMX sat's
Align magnetic governor sensor mounted to use flywheel magnets on the TRM300
_________________________________________________
Goblin Tri-Blade 630 gasser , Goblin Speed , Blade 360CFX , T-Rex 450L , DX8
Pingletonme is offline        Reply With Quote Quick reply to this message
Old 06-24-2015, 06:22 AM   #118 (permalink)
BadAss Gasser 630
Old 07-11-2015, 06:33 PM   #119 (permalink)
Serious lack of bling :-), very stock Helix 700. I think I now have it all pretty close to dialed-in on the SK540. It just seems a little down on power but maybe that's all I can expect from a stock G260. With a little luck I should have a modded 290 arriving soon. Anyway, got in some good flights today although quite windy.
ID:	596107   Click image for larger version
Old 09-10-2015, 10:23 PM   #120 (permalink)
Default 8.2 HP?
Originally Posted by raptor90se View Post
Hi all,
I post somes pictures of my WHIPLASH GAS.
The setup:
Motor:
-OBR reed case full modified 8.2hp.
-18 tooth pignon gear.
Servos:
- KST DD2509MG for the cylique.
- KST DS715MG for the tail.
Fbl:
Cgy750.
Blades:
Align 3g 690mm.
Gov:
Statorgator.
Idl1:
1950 rpm.
Idl2:
2100 rpm.
Pipe:
Quickdraw tuned pipe.
Kind regards
Joël
690s with 8.2 HP I don't get it?
n8rloves2fly is offline        Reply With Quote Quick reply to this message
