Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > Master CP
Master CP Walkera Master CP Helicopter Support
Old 03-03-2013, 04:12 AM   #1 (permalink)
Default Master CP not lifting off
Hi, Can someone verify my settings for my Master CP with Devo-7.
The Heli is not lifting off with the Training Gear on.
My settings are as follows :-
MODEL
TYPE - Heli
OUTPUT GEAR GEAR ACT AUX2 AUX2 GYRO
SWASH 1- NRM
FUNCTION
REVSW - All Normal
TRVAD
ELEV U 100% D 100%
AILE L 100% R 100%
THRO H 100% L 100%
RUDD L 100% R 100%
GEAR +100% -100%
PITCH H 100% L 100%
GYRO +100% -100%
SUBTR ALL 0%
DREXP
CHANN ELEV POSIT POS 0 D/R 100% EXP +35%
CHANN AILE POSIT POS 0 D/R 100% EXP +35%
CHANN RUDD POSIT POS 0 D/R 100% EXP +25%
THHOLD
POSIT 0.0%
THCRV
EXP - OFF
P-L 0.0%
P-1 INH
P-2 INH
P-M 50%
P-3 INH
P-4 INH
P-H 100%
GYRO MODE MANU SWITC MIX POS 0 90% POS 1 80.0%
PTCRV
EXP -OFF
P-L +15%
P-1 +25%
P-2 +35%
P-M +50%
P-3 +70%
P-4 +70%
P-H +85%
Are these good settings ?
Why am I getting no lift-off. My Swashplate is level and blades are 0 degree pitch at Mid Stick. I have Digital Pitch Gauge.
Also I am using the Emax ES-MD08 Digital servos for Aileron / Elevator and Pitch.
Kevin
kevtucker is offline        Reply With Quote Quick reply to this message
Old 03-03-2013, 09:46 AM   #2 (permalink)
What does your digital gauge say for deg of pitch at low, middle and high stick ?
5488fletcher is offline        Reply With Quote Quick reply to this message
Old 03-03-2013, 10:15 AM   #3 (permalink)
Default Pitch travel
disconnect tail and motor, put battery in and turn on radio, then plug in battery ...the raise pitch travel as high as you can.......(oh put throttle all the way up)........then back off on pitch to stop binding.....or lifting main gear........i got mine at 136.....but i have a 7e....
BE SAFE>>>>ITS JUST HOW MINE WORKS......AND MAKE SURE YOU UNPLUG BOTH MOTORS>>>>>>
cruzroy is offline        Reply With Quote Quick reply to this message
Old 03-03-2013, 12:55 PM   #4 (permalink)
Hi thanks for reply.
Im not sure I get what you mean. When you say raise Pitch Travel is that in the Function menu under TRAVAD ? If so that goes up to 150% and I can see the blades move when I adjust this. Then you say back off on pitch to stop binding ? Could you explain.
Sorry i'm a bit new at this.
Kevin
Old 03-03-2013, 04:27 PM   #5 (permalink)
Use your pitch gauge and adjust travel adjust untill you have 12 or 13 deg of pitch at full throttle stick position . I have my travel adjust at 50 percent and run a linear pitch curve in all flight modes .
Old 03-04-2013, 07:41 AM   #6 (permalink)
Well i've just managed to get the Heli in the air after all this time.
Bit scary at first but got it about 1ft off the ground and controls were ok.
About 3 mins of going up and down on Grass with the Training Gear on, the battery has now gone
Will try again after Battery charged.
Kevin
Old 03-04-2013, 07:59 AM   #7 (permalink)
Glad to here you got it .
Old 03-04-2013, 08:06 AM   #8 (permalink)
Thanks.
Still would like to get a guide from you on setting Pitch properly from you if possible.
Just that I wont be around tonight as I work Night Shift through the week.
Think I got about 0 degree at 50% mid-stick and 10degree at Full and Low Stick.
I set the DEVO-7 to :
THCRV
P1 0%
P2- INH
PM +50%
P3- INH
P4- INH
PH +100%
PTCRV
PL +20%
P1 +30%
P2 +40%
PM +50%
P3 +65%
P4 +75%
PH +100%
GYRO 75%
Kevin
Old 03-04-2013, 08:20 AM   #9 (permalink)
Originally Posted by kevtucker View Post
Thanks.
THCRV
P1 0%
P2- INH
PM +60%
P3- INH
P4- INH
PH +100%
PTCRV
PL -100
P1 inhibit
P2 inhibit
PM 0 %
P3 inhibit
P4 inhibit
PH +100%
GYRO 75%
Kevin
these are the settings in my radio also i checked travel adjust for pitch and im set at 50 percent both up and down . Main problem i see is your p3 is 50 percent and should be 0 percent and every thing below p3 -pL should be a negative percent .
Old 03-04-2013, 08:28 AM   #10 (permalink)
Hi,
So I should have it at :
THCRV
P1 0%
P2- INH
PM +50%
P3- INH
P4- INH
PH +100%
PTCRV
PL +20%
P1 +30%
P2 +40%
PM +0%
P3 +65%
P4 +75%
PH +100%
Is that correct ?
Kevin
Old 03-04-2013, 08:37 AM   #11 (permalink)
MODEL
TYPE - Heli
SWASH 1- NRM
FUNCTION
REVSW - All Normal
TRVAD
ELEV U 75% D 75%
AILE L 75% R 75%
THRO H 100% L 100%
RUDD L 100% R 100%
GEAR +100% -100%
PITCH H 50% L 50%
GYRO +100% -100%
SUBTR ALL 0%
DREXP
CHANN ELEV POSIT switch D/R 100% EXP 0%
CHANN AILE POSIT switch D/R 100% EXP 0%
CHANN RUDD POSIT switch D/R 100% EXP 0%
THHOLD
POSIT -5%
THCRV
EXP - OFF
P-L 0.0%
P-1 INH
P-2 INH
P-M 60%
P-3 INH
P-4 INH
P-H 100%
GYRO MODE automatic
PTCRV
EXP -OFF
P-L -100
P-1 inhibit
P-2 inhibit
P-M 0%
P-3 inhibit
P-4 inhibit
P-H +100%
barry
Old 03-04-2013, 08:40 AM   #12 (permalink)
Hi,
THCRV
P1 0%
P2- INH
PM +50%
P3- INH
P4- INH
PH +100%
PTCRV
PL +20%
P1 +30%
P2 +40%
PM +0%
P3 +65%
P4 +75%
PH +100%
Is that correct ?
Kevin
NO pl = -100 p1= inhibit p2 =inhibit pm =0 p3 = inhibit p4 = inhibit ph= +100
Old 03-04-2013, 08:49 AM   #13 (permalink)
I'll try them settings after the Battery has charged and see how I go.
Kevin
Old 03-04-2013, 08:49 AM   #14 (permalink)
When you set up the heli you want a linear pitch curve -100 to +100 , Next you move throttle stick to middle position on transmitter . Next install servo horns as close to leven as posible and use subtrim to get them as close as you can . Next level swash and set blades a 0 degrees with throttle stick still in the middle . Next use pitch gauge to see how many deg you have at low mid high stick . Use travel adjust menu to raise or lower to reach desired pitch percent . 10 deg is a goodnumber for learning .
Old 03-04-2013, 08:53 AM   #15 (permalink)
Because you had +50 percent as pm, i believe your servo horns are in the wrong position . Before you fly with these settings use pitch guage to see where your at . At mid stick servo arms should be level, swash level and blades reading 0 deg with pitch gauge . Make sure you change pitch travel adjust to 50 percent or you will bind the head !
Old 03-04-2013, 09:20 AM   #17 (permalink)
Hi Barry.
That is the Video I used to set my Servos before.
They are level at Mid Stick. The Values for the Throttle Curve and Pitch curve are what I copied from his later video explaining Throttle and Pitch curves.
This is a picture of my Swashplate at Mid-stick
Kevin
Old 03-04-2013, 10:17 AM   #18 (permalink)
Hi Barry,
I've just put your settings into a slot on my Devo-7 and that throws my arms down looking like the photo.
So should I leave these settings in and reset my Servo arms to level 90 Degrees and level the Swashplate again at Mid Stick ?
With these settings I have 60% Throttle showing at Mid-Stick is this correct ? That is because of the 60% Throttle setting in the THCRV am I right ?
Kevin
ID:	400347   Click image for larger version
Old 03-04-2013, 12:09 PM   #19 (permalink)
Hi Barry,
Kevin
(So should I leave these settings in and reset my Servo arms to level 90 Degrees and level the Swashplate again at Mid Stick ?)YES
(With these settings I have 60% Throttle showing at Mid-Stick is this correct ? That is because of the 60% Throttle setting in the THCRV am I right ?) YES
Old 03-04-2013, 02:28 PM   #20 (permalink)
Ok I put the exact settings in my Devo-7 and have levelled off the servo arms and Swashplate.
So next step is to get both Blades at 0 Degrees on my pitch gauge at Mid-Stick by altering the Ball links ?
Cannot do this now as I'm at work but will try when I'm home.
Thanks for your help
Kevin
Tags
master cp take off
