Old 09-01-2014, 01:37 PM   #1 (permalink)
Default When you go from V4 to V5?
Going to update my 3gx from v.4 to v.5 and I know you need to do the setup again. How do you guys do that? Do you clear the model in your radio and start from scratch? Would it be okay if I switched into TH so that I have a linear pitch curve and switch to 100% on my D/R (Since I run D/R), and then do the update?. Any advice would be appreciated! Thanks!
D-Rock is offline        Reply With Quote Quick reply to this message
Old 09-02-2014, 07:51 AM   #2 (permalink)
You shouldn't need to clear the model out and start over. I always program a linear pitch and throttle curve in normal mode (I assume you know to disconnect the motor). After loading new version on 3GX, go to DIR mode and check mechanical setup. Complete DIR setup at 50% pitch. Do the tail setup menu next. Then power down, hook the motor back up and do the throttle calibration. After that quick test to recheck movement directions and go maiden it.
dja2424
dja2424 is offline        Reply With Quote Quick reply to this message
Old 09-02-2014, 07:57 AM   #3 (permalink)
I guess one thing to add would be to make any flight mode/software changes you need/want after the throttle calibration. Sorry about that.
dja2424
Old 09-02-2014, 08:54 PM   #4 (permalink)
Thanks!
Old 09-07-2014, 03:44 AM   #5 (permalink)
Default better to start off with a new model in TX
Some of us had little issues with V5, and the general consensus is to start afresh with a new model in the TX, otherwise some little bugs may creap in. And make sure before you bind that both pots on the 3GX are at 12o'clock.
Allan
TREX 250 PRO,Talon15, GPRO, Zeal ----TREX 500 EFL PRO, GPRO, RAILS ----2x TREX 450PRO V2, 1xGPRO&1xBRAIN, Talon35, RAIL , Zeal ---- SAVOX powered TREX500 EFL in Roban scale UH1-N ---- TREX 600 EFL PRO, GPRO, RAILS ---- DX9 ----
TR450ZS is offline        Reply With Quote Quick reply to this message
