Go Back   HeliFreak > R/C Electronics Support > Futaba Radios and Electronics > Futaba CGY750 FBL System
Futaba CGY750 FBL System Futaba CGY750 Help and features Support Forum
Old 10-23-2011, 05:13 PM   #1 (permalink)
Default Align gov sensor with CGY750
Hi all,
I installed the Align gov sensor as the diagram below.
Added a 1K resistor between de red and white wire.
Only 97% reading on the display.
Whats wrong with this ? maybe red and black wire change ?
| mCPX BL@DX6i | Trex700N-LE@BX | TDR@BX || FunJet 2W20@4S | SwiffieII || FF10 || 720i DUO3 | ALC8500
Z900 is offline        Reply With Quote Quick reply to this message
Old 10-23-2011, 06:46 PM   #2 (permalink)
97% is fine. I get 96% using the Futaba sensor.
bobloblaw is offline        Reply With Quote Quick reply to this message
Old 10-24-2011, 02:20 PM   #3 (permalink)
I know 97% is fine, but when you turn the head there must be something like 1% reading
(thats the case with the org. futaba sensor).
Thats not the case, always 97% reading.
So my question is, what should be changed to use the Align
gov sensor with the CGY750 ?
Old 10-24-2011, 03:20 PM   #4 (permalink)
I had the same problem. Put your starter on the heli and crank it over. You'll see on the display where it will read 0-1%. It just needs to see a few turns of the starter...
aliosha323 is offline        Reply With Quote Quick reply to this message
Old 10-24-2011, 05:43 PM   #5 (permalink)
OK, but is the schematic RIGHT shown above ?
Old 10-26-2011, 12:13 PM   #6 (permalink)
I would assume so... Just setup your throttle curves incase it doesn't read from the sensor. A good way to tell if your gov. Is active is by spooling up then switching to idle up 1 while still on the ground. Apply negative pitch and if the head speed remains constant and doesnt bog down, then you know the gov is working... Also at the end of the flight, there's an option on the cgy750 to view the max head speed recorded. Double check that to verify it works.
Old 10-26-2011, 04:04 PM   #7 (permalink)
OK Aliosha, thanks for your input.
Do you use the align sensor ? (thats a bit unclear to me)
If so, then you know how you did connect it to the CGY750 though ?
Old 10-26-2011, 09:14 PM   #8 (permalink)
I'm using the Spektrum backplate sensor on my 700n. I did the 2.2k resistor mod and hooked it up as normal to the cgy750. Worked like a charm
Old 10-27-2011, 07:57 AM   #9 (permalink)
Yeah damn...I was just asking especially for the Align sensor.
But if the Spektrum backplate sensor is 100% PIN compatible with the Align,
this must be the way to go.
Anyone can confirm ?
Old 11-11-2011, 11:56 AM   #10 (permalink)
I'm having a similar problem with my governor and the 750. I'm using the throttle jockey sensor and get a very low reading(15%) in the 750 governor sens menu. Should I try the resistor mod? Thanks
flyboynellor is offline        Reply With Quote Quick reply to this message
Old 11-19-2011, 11:51 AM   #11 (permalink)
did you checked distance between sensor and magnet it must be 1-2mm if its not its reading low. acordıng to manual %60 and more its good
Logo 700Xxtreme
Gaui x5 FES
salvedor is offline        Reply With Quote Quick reply to this message
Old 01-25-2014, 11:45 AM   #12 (permalink)
Hi
Did this get resolved? I am using an align sensor, have crossed the red and black wires but no reading. I crossed the wires as this is what is needed to be done to make it work with a vbar, but the futaba sensor plugs into a vbar unchanged, hence the conclusion that's I needed to swp wires.
Keith
Cheers
Keith
TREX700N DFC (Helibug Gasser), FUTABA 8J, and lots of broken spare bits.....
kljw is offline        Reply With Quote Quick reply to this message
Old 02-08-2014, 07:47 PM   #13 (permalink)
Originally Posted by kljw View Post
Hi
Keith
I don't know how dead set on the align sensor you are but look up the thread on the spektrum RPM sensor modification. http://rc.runryder.com/helicopter/t641686p1/ I have used it and made them for a couple other people.
WV_Medic is offline        Reply With Quote Quick reply to this message
