Mikado Logo Helicopters Mikado Logo Helicopters Discussion |
11-30-2012, 08:35 PM | #81 (permalink) |
Um, I wonder why Mikado didn't call it a 750 like the Rush 750 that is sold in a 700 configuration? I just checked and the L700 'combo' is a 713 blade 12s....OK answered my own question....
Synergy E7, Vbar 5 Pro, BLS255 & 256HV, Hacker Turnado 530 Edition, Rail 716, CC120, WR Sup BEC, Scorp BUG | Trex 450L, Vbar Pro, MKS 8910A+ on tail, Talon 35 | Futaba 18mz |
11-30-2012, 08:41 PM | #82 (permalink) |
Guess it was not obvious in my posts that I do not have a L700. I'm just one those speculative peeps in this thread hanging out and chatting.
11-30-2012, 09:11 PM | #83 (permalink) | |
Logo 600 will swing up to 640mm, 690mm on the se. It's just how those crazy germans roll... they build for the future, not just today. |
11-30-2012, 09:26 PM | #84 (permalink) | ||
Quote, "Um, I wonder why Mikado didn't call it a 750..."
Most guys who've followed the evolution of the Logo 700 from the Logo 800, know this (but for those fresh into the conversation since the release of the 700): The drive train starting from the motor mount through the pinion and CB, main gear, 14mm main shaft, swash plate, rods and ball links, all three M/S bearing blocks and servo mounts, tail drive system, TT and tail gear box etc., all the way back to the T/R blade grips, is directly off the Logo 800. So although the frames, head, tail boom length, fin size and canopy have been downsized to 700 class (although the head is still huge for a 700 class heli), the rest of the machine is an 800, which can handle a steady diet of 14S abuse with a larger disc as seen in the below vid. Keep in mind the vid is of a 15 pound Logo 800, which digests a 14S 5000mah pack in 3 minutes. Essentially the same heli can EASILY handle 700 class power systems with a RTF weight of 12.5 pounds (average) swinging by comparison little small 713's.
Oh BTW, check the move @ 2:40. It still amazes me the heli doesn't explode or boom strike when doing that. And the dampening in the 700's head is stiffer than on the 800. (-: Dave |
11-30-2012, 10:44 PM | #86 (permalink) |
The Capi
hehehe Well Shawn you managed to talk Santino in getting a 700, I look forward to fly it
Spreading capibara awareness since 2006 |
11-30-2012, 10:48 PM | #87 (permalink) |
The goblin is easier to see than even my heli because of the boom and it is a bit smaller, but saying it is around 12 pounds means 11.8-12.2, not 12.5+ and No im not getting one, but im just discussing it, and put 713s SE on your heli jh and see if it doesn't heat up a bit and slow it down.
The logo 600 has a stick pack and rolls as good as any other 600 and is the best to me in the 600 class but the 630 is not in the same class, the l700 is in the 700 class...anyway when the hot summer comes around and stuff is cooking and packs are heating up then 14s will be a must for this heli for the most of us non collective management flyers .....like my self. And this designed for the future, Synergy, Whiplash, Compass, Goblin and other helis can take big power setups also even bigger than there recommended and 14s, the more power you put into a heavy 12s 700 the less good you do until you change the voltage. The truth is there probably hinting towards a plastic frame with all this future talk, just say it |
11-30-2012, 11:04 PM | #88 (permalink) |
he helped me make my mind up for a logo 600sx
------------------------------------------------------------------------------------ http://www.alignrccdn.com/ |
11-30-2012, 11:11 PM | #89 (permalink) |
There's not much weight in the frames though, negligible weight savings there with a molded frame.
The head is hugely overbuilt, as is the torque tube assembly. That's where the weight is. 750mm blades at 2100rpm wouldn't be scary at all. And would be fun |
11-30-2012, 11:59 PM | #90 (permalink) |
As said they being mikado can call it a 700 if they want to, as Dave pointed out Mikado 101 its nothing new typically there as 500 can take 560mm mains, 600 can take up to 640mm mains and so on...
I have relayed things without comparisons. I purposely did that to avoid telling what other helis had for issues and to avoid arguements. For those nitpicking with speculation I'd appreciate leaving that out unless you own one or have flown one with genuine complaints or comments that is far more constructive. I could make a whole other thread off topic to talk about other helis that are so called on par and speak fact of real existing issues as well... But I will not. Discussions are good but arguing what model number is written is well ridiculous no? And if you are saying you are not buying one that's perfectly fine but what do you fly or who do you fly for? As far as myself, Dave or anyone associated to mikado telling or speaking of what mikado does or may do in future will not happen and can't. As is mikado is very private on such matters and that is fine. Hope everyone has a great evening and weekend.
...Once upon a time there were Nitros, flybars & frequency pins...Shawn Last edited by OICU812; 12-01-2012 at 01:56 AM.. |
12-01-2012, 12:21 AM | #91 (permalink) | |
...Once upon a time there were Nitros, flybars & frequency pins...Shawn |
12-01-2012, 10:17 AM | #92 (permalink) | |
FYI, I fly whats in my sig line and I don't rep for anyone...
12-01-2012, 12:36 PM | #93 (permalink) |
Alright fair enough but no one can truly says how it will fly for them till they fly it, that's reality. Whether you or anyone gets or does not get one makes no difference to me at all really. I truly like way it flies and I've owned all that's in everyone's sig line so ill say that if you do get a chance to try one please do and see how you like it. I was NOT 100% on board on the Logo 700 and its sheer size etc..and had same thoughts and mentality and I changed those feelings and worries after only a few flights.
See what ya think if you do get that opportunity. Meanwhile ill try some assortments of power systems and settings etc see where things go. Cold as heck here so no flying for this guy for awhile!
12-02-2012, 02:33 AM | #94 (permalink) |
My viewpoint is this, for mikado to make just another 700 weight and size from marketing strategy doesnt make sense, to argue this heavy flies like a lighter machine is physically impossible, apples with apples gentlemen please. That it flies awesome and That Kyle can prove it, sure, for some more than others. In the end yes its big and yes its heavy, some like it some dont, i like it, more than my raptor e 720, no i dont, i like em both, they are 2 different machines, my e720 has much better power to weight and it shows, the logo more presence....and it shows, which is why i said many moons..eh sorry posts ago, why i think theres room for other 700's in your arsenal, disagree if you want as much as you want, this is my opinion, trying to convince me otherwise, dont hold your breath!.
Tdr quantum 4530 1.4 yy h/ jive120 beastx, Vibe e 8 12s mx 700 1.32yy vbargov fusionhawk, Banshee nr 36 kosmik 200 pyro 800 1.4yy 455kv 14s beastx, xtreme 700 pyro 850 1.5yy 14s kosmik 200 |
12-02-2012, 03:16 AM | #95 (permalink) | |
Sorry for the OT but what Rpm and what blades was on this 800 , Dave? Sent from my iApfel using Tapatalk
.....happy flying.... Regards Janis |
12-02-2012, 02:46 PM | #96 (permalink) |
Stolla no ones telling you to ditch e720 at all. If folks want to own all they can but I choose to not. I can't afford to either both in money and time. I never said it would fly like a 10lb TDR or much lighter heli of course it is not. But it surely does not show many oddities that some other helis show and regardless of weight and power I can not keep a heli with a crap tail, one that has phasing issues, poor quality bearings etc etc etc...
All that said e720 was one of the better I tried for sure.
12-02-2012, 04:06 PM | #97 (permalink) |
The Capi
Since I am already involved in this thread I thought I would ask a question I've had for awhile. With the release of the Logomobo 800 and 700 we have seen what appears to be a radical departure from the traditional Mikado design. Past logo designs had a very light blade loading due to a very light machine. The 700 and 800 are the exact opposite with a design towards rigidity and robustness, with perhaps a heavier blade loading (I don't want to start an argument).
My question is has Mikado designer/s changed their approach to heli design ? Is this the road we can expect future Mikado products to drift towards or is the design change only due to the size and class they are in ?
12-02-2012, 04:16 PM | #98 (permalink) |
@ Vom Feinsten,
Q: "...what Rpm and what blades was on this 800 , Dave?" That video was made mid to late 2011, so that would be the time when Kyle as using Edge 753's on the 800 (same chord as on the 813's, just a shorted blade). Head speed was 2000 and the set-up used more collective pitch than when flying the 813's. (-: Dave |
12-02-2012, 11:44 PM | #99 (permalink) | |
Many moons ago, when I flew pattern, there was a pattern plank called the "EU-1A" And it immediately gained the moniker of the "U812"..... So when a pilot showed up at the contest with a "U812", he was told...."OICU812" Did you ever fly pattern.....with a "U812".......? |
12-03-2012, 09:28 AM | #100 (permalink) |
L700 looks like a nice bird for sure, robust, looks like it will hold up well to a beating for hundreds of flights. Can't wait to see one in person.
"If you think you can or you can not you are right" Goblin Xera 4530, YGE 160,VBar Diablo, HJive, 4525 Ultimate,VBar Synergy N5C sitting in Box... |
