Go Back   HeliFreak > R/C Helicopter Support > Lynx Heli Innovations
Lynx Heli Innovations Lynx Heli Innovations - Heli Upgrades - Factory Support Forum
Old 08-24-2015, 01:46 AM   #61 (permalink)
Originally Posted by RichKnapp View Post
Heard today. 380 landing gear, very shortly.
Nice. Looking forward to the swashplate. Any ETA on that?
critical is offline        Reply With Quote Quick reply to this message
Old 08-24-2015, 12:52 PM   #62 (permalink)
On site now.
Should be in stock within a week.
http://www.lynxheli.com/index.php?cPath=128_254
RichKnapp is offline        Reply With Quote Quick reply to this message
Old 08-24-2015, 02:05 PM   #63 (permalink)
On site now.
thanks will be getting that for my G380
| Kraken 700 : Neo | Atom 6HV : Evo | Raw 580 : Neo | vbct |
ragge1 is offline        Reply With Quote Quick reply to this message
Old 08-24-2015, 03:05 PM   #64 (permalink)
It looks to me that all the Lynx upgrades that are about to be released already exist. I would be interested in (1) a longer FBL unit support and (2) a more reliable quick release canopy support since the SAB magnetic canopy mounts have met with mixed experiences with the magnets falling off.
14S Specter 700 V2 NME/Tron 7/Kraken; 8S Tron Dnamic; 7S Kraken 580; 6S Buddy 380 KSE
VBCE/Neo/EVO, Jeti/Spirit, YGE "T" ESCs; LiFePO4 field charging batteries
Sims on Mac: Heli-X, neXt, AccuRC, Phoenix, AeroFly RC7 Ultimate
Amain Team Pilot
jhamel is offline        Reply With Quote Quick reply to this message
Old 08-26-2015, 06:16 PM   #65 (permalink)
Landing gear out.. swash and dfc conversion under production
Luca Invernizzi
OXY HELI
ininverno is offline        Reply With Quote Quick reply to this message
Old 08-28-2015, 10:22 PM   #66 (permalink)
Your making me really think about a G-380 myself. Thanks a lot.
Old 08-31-2015, 10:39 AM   #67 (permalink)
got mine , better quality than SAB's once
ID:	605963   Click image for larger version
ID:	605964   Click image for larger version
Old 09-02-2015, 11:26 PM   #68 (permalink)
Default Goblin 380 additions
Nice ragge1 love my 380 its not as pretty as yours as mine has been through allot !
Vbar Cont/Dx9 Align 600XN my first Nitro ! Original Goblin 500 stretched/Lynxed out Oxy2 now stretched and a few micros
Lynx Heli/Team pilot
thanasi is offline        Reply With Quote Quick reply to this message
Old 09-03-2015, 04:03 AM   #69 (permalink)
Seems to keep the tail higher off the ground compared to the SAB carbon skids.
Correct?
Tail looks to sit as high as with the flippers.
NICE!
Pard is offline        Reply With Quote Quick reply to this message
Old 09-03-2015, 12:56 PM   #70 (permalink)
Correct?
NICE!
like my tail high so had made a spacer from a 2,5mm ( x2 ) carbon plate to go with the the SAB landing gear raising the tail to 5mm , I kept them om with the Lynx upgrade so my tailfin is @ 8.3 cm , thats about 3 cm higher than with the SAB gear
all my helis have a forward tilt , have made abit of mode also on my 6HV and the HD500 just to raise the tail , my landing spot is full of gravel so its nice with a raised tail
https://www.helifreak.com/showpost.p...5&postcount=35
Old 09-05-2015, 10:10 PM   #71 (permalink)
Here is Junior with the Lynx skids on him.
ID:	607142   Click image for larger version
Old 09-07-2015, 07:45 PM   #72 (permalink)
Junior will be all LYNX'ed out.
I'll share pic of the parts installed.
Old 09-07-2015, 11:50 PM   #73 (permalink)
hei Rick , just wondering how high is your tail fin from the ground , I'm lazy to remove the mode I made to measure on mine
Old 09-08-2015, 12:12 AM   #74 (permalink)
I'll measure when I put it back on.
Took it back off to do wiring and finishing up.
Old 09-11-2015, 10:17 PM   #75 (permalink)
ragge1
2 and 1/2 inch's.
Lynx skids, pitch slider and bell crank. Much more Lynx parts will be coming/added.
MSH Brain FBL
DSMX sats
Castle Creations Light 75 ESC
Castle Creations 10A BEC set to 7V
BK DS-5005HV tail servo
Servo King DS-995 Cyclic servos
X-Nova 2820-890KV 10P motor
Zeal Red 70mm Tail blades
(Zeal Energy Red 380's coming yet.)
Name:	all done with first set up..jpg
Old 09-12-2015, 02:22 AM   #76 (permalink)
that was a good idea using cutting board to level your heli
got to do that with my 6HV for better leveling for the rescue calibrating setup ( vbar NEO )
Old 09-12-2015, 11:23 AM   #77 (permalink)
That's a slick idea Rich, now going to steal it from u 😂
Old 09-12-2015, 12:15 PM   #78 (permalink)
The Airetic
You actually need three adjustment points on the leveling table to do it right. If you only use two, the back half of the leveling table is slaved to the angle of the table it is sitting on. You only have adjustment of what would be the "elevator" of the heli.
If you use three, you have full adjustment in all directions. Or more specifically, "elevator" and "aileron". You can actually make the table truly level.
A while back, Nelsonisms and I made a few of these tables. Here is the thread about them if you are looking for some ideas.
https://www.helifreak.com/showthread...leveling+table
Free Agent....With standalone opinions.
KiloXray is offline        Reply With Quote Quick reply to this message
Old 09-12-2015, 04:42 PM   #79 (permalink)
Yes I have 3, but for the 380 to raise up high enough I had to take one out to drop it the one side low enough and yet have the side to side adjustment.
I was able to get it 100% level doing this.
All my other birds, all 3 adjustable legs can stay in. I have to see about longer adjustable legs for doing the 380 do to it's big rake stance even before the Lynx skids.
These tables sure are better than paper and CD cases. A lot faster set up also.
I just used a Walmart plastic cutting board and 3 adjustable table legs.
Drilled 3 holes the legs arm tight in but slide up and down threw. The used fender washers and nuts on underside to hold the height.
I have crown nuts for on top when I do smaller birds to use as them as thumb screws to turn the legs to adjust.
These tables have been around here and there since fly bar but Nelsonisms and KiloXray revived them. They are where I first seen them and started researching different styles and whys to build them.
I can not take credit for the idea. Many people before me have done it.
Old 09-13-2015, 02:41 PM   #80 (permalink)
Little breezy today but we had fun up until my TX started to yell at me "Low Battery" lol (yes I have the Lipo already)
Tammy had some great flights on her LEAP 3D. Her Hyper needs tuning, so didn't get that in air. Lift off we seen the issues. She gets better every flight.
Matthew Cramer flew the snot out of his OXY's again and he is getting the X3 tuned in for his style flying. (Instead of it being set up for my style.)
380 flew smooth but needs some gain tuning. Blade 360 needs some more checking. Even tuned, perfect CG and vib free it had tail drop like it is still tail heavy. We suspect the stab getting pushed down from main blade wash. Took the stab off at home and see what that does. Over all great time at the field today.
Goblin 380 first flight and flight tuning (7 min 7 sec)
