Go Back   HeliFreak > R/C Electronics Support > DJI Heli Autopilot System(Naza-H/WooKong-H/Ace One)
DJI Heli Autopilot System(Naza-H/WooKong-H/Ace One) DJI Heli Autopilot System(Naza-H/WooKong-H/Ace One) Factory Support Forum
Old 03-06-2013, 08:34 PM   #1 (permalink)
Default NAZA-H nodding in ATTI mode
Hi,
I noticed that my 450 heli with naza-h is pitching up and down in atti & gps mode. First I tough the autopilot gain is too high. When I degrease the gain, this behavior is still there except that the frequency is lower. Down to the minimum gain(40%) it will pitch up & down slowly. When I move forward it is not noticeable but once I stop it will come back.
As far as I can see from my eyes, this heli doesnt has any vibration & blade tracking has been done. Is the any setting to make this behavior go away or at lease to minimize it? This heli is fitted with dfc head & I found out that the rubber dampers in the head aren't actually rubber, they feel more like hard plastics. Could this be the reason? Thanks.
superwhite is offline        Reply With Quote Quick reply to this message
Old 03-07-2013, 05:03 AM   #2 (permalink)
What cyclic servos are you using? They may be too slow to react quick enough.
Valkman is offline        Reply With Quote Quick reply to this message
Old 03-07-2013, 06:16 AM   #3 (permalink)
I'm using Corona Digital Servo 2.2kg / 12.5g / .11sec from hobbyking. In manual mode it doesn't act like that, only in atti mode & gps mode.
Old 03-07-2013, 09:40 AM   #4 (permalink)
In ATTI and GPS is when the FC is controlling the heli. The FC requires a higher level of control than you on the sticks. Buy some high quality servos if you want to use a FC that is capable of a high level of control. If not, then the Naza H is probably not the FC for you.
AMA #844172 DJI S1000 Lightbridge Zen for 5D, S900 LB Zen for BMPCC, DJI Phantom 2 Vision +, P2Z2 with Data Link, P2Z3 with LB DJI Forum Support
Tahoe Ed is offline        Reply With Quote Quick reply to this message
Old 03-07-2013, 10:02 AM   #5 (permalink)
Do you think Align DS415M servos are acceptable for the job? Below are the spec -
●Stall torque:2.0kg.cm(4.8V)
2.4kg.cm(6.0V)
●Motion speed:0.1sec/60°(4.8V)
0.08sec/60°(6.0V)
●Rating voltageC 4.8-6.0V
●Temperature range:-20°C~+60°C
●Dimension:22.9 x 12 x 25.8mm
●Weight:13.9g
●1520μs standard band
With corona servos I just use 5v from the ESC because I'm not too confident the servos can take 6v. I think changing the servo also will give me the benefit of the included DJI BEC at 5.8v.
Old 03-07-2013, 03:53 PM   #6 (permalink)
I don't fly a 450. So I cannot comment on these particular servos performance. All I can say get the best servos that you can afford for using a FBL controller that is capable of GPS and ATTI.
Old 03-11-2013, 08:53 AM   #7 (permalink)
Default solved
Just want to update on my problem. So, i replaced the cyclic servos with align ds415m & rudder servo with ds425m. I installed dji bec & use 5.8v. Now the heli just fly perfect.
Old 03-11-2013, 09:30 PM   #8 (permalink)
Great!
