Go Back   HeliFreak > R/C Electronics Support > Scorpion ESC and Motor Support
Scorpion ESC and Motor Support Scorpion Power Systems ESC and Motor Factory Support Forum
Old 11-16-2015, 09:34 AM   #1 (permalink)
Default Motor Selection Question
I started a thread over in the Low Head Speed Helicopter subforum and haven't had any response so I thought I post the question again here:
Can someone please help me understand what happens when a motor Kv rating is decreased and everything else stays the same EXCEPT for the gearing to keep headspeed at the same rpm?
For an example, let's assume we start with:
450 size heli with 325mm blades
3S 35C Lipo battery
Scorpion HKII-2221-8 motor with 3595 rpm/volt
Assuming 90% efficiency, a 13.60:1 gear ratio @ 80% throttle = ~2100 rotor rpm.
If we change out the motor to a Scorpion HKII-2221-12 which has only 2580 rpm/volt and also adjust the gearing to 9.71:1, then at 80% throttle we should get roughly the same rotor rpm.
Besides the ability to achieve lower headspeed with the lower Kv motor, what else would I gain or lose by doing this? Should flight time be longer, shorter, or the same?
In case any of this is important, here are complete specs for the two motors:
HKII-2221-8
Stator Diameter: 22.0 mm (0.87 in)
Stator Thickness: 21.0 mm (0.83 in)
No. of Stator Arms: 9
Magnet Poles: 6
Motor Wind: 8 Turn Delta
Motor Wire: 16-Strand 0.21mm
Motor Kv: 3595 RPM per Volt
No-Load Current (Io): 2.31 Amps @ 10 volts
Motor Resistance (Rm): 0.024 Ohms
Max Continuous Current: 45 Amps
Max Continuous Power: 475 Watts
Weight: 81 Grams (2.86 oz)
Outside Diameter: 27.9 mm (1.098 in)
Shaft Diameter: 3.17 mm (0.125 in)
Body Length: 38.3 mm (1.508 in)
Overall Shaft Length: 58.7 mm (2.311 in)
Max LiPo Cell: 3s
Motor Timing: 5deg
Drive Frequency: 8kHz
HKII-2221-12
Magnet Poles: 6
Motor Wind: 12 Turn Delta
Motor Wire: 12-Strand 0.21mm
Motor Kv: 2580 RPM / Volt
No-Load Current (Io): 1.50 Amps @ 10 volts
Motor Resistance (Rm): 0.038 Ohms
Max Continuous Current: 38 Amps
Max Continuous Power: 530 Watts
Weight: 81 Grams (2.86oz)
Max Lipo Cell: 4s
Motor Timing : 5deg
Thanks in advance,
John
Gyropilot is online now        Reply With Quote Quick reply to this message
Old 11-16-2015, 10:03 PM   #2 (permalink)
Hi.
See the max continuous watt rate, - you will get more power out of it. But you will lose flight time :-)
If its flown on the same voltage
RasmusDK is offline        Reply With Quote Quick reply to this message
Old 11-16-2015, 10:06 PM   #3 (permalink)
Originally Posted by RasmusDK View Post
...you will lose flight time...
Thanks!
