Night Flying Night Flying Helis Info |
09-07-2010, 04:58 PM | #1 (permalink) |
MS Composit LiXX charger substitute
Ok... Finally go the MS Composit tail blades.... The voltage off of these things is kinda wierd... less than 2 volts..... Didn't realize they required a special charger "MS-00108". That nobody seems to have in stock on this side of the atlantic....
Is anyone charging these with any sucess with a lipo charger? And does anyone know how big the cell is in the blade? My Hyperion duo II does a great job with my Torsion night blades..... Blue Skies, John
Gaui X7, X5, NX4, X42, X3 Gaui USA, Empire Hobby, JR Americas, Cyclone Blades, MKS Servos USA, OptiPower Batteries,YS Engines, PowerMaster Fuels Last edited by Pinion; 09-07-2010 at 05:03 PM.. Reason: correct title |
09-07-2010, 07:28 PM | #2 (permalink) |
Unless things have changed recently - the battery in the blade is ~ a 25 mAh single cell Li-Po.
Fact that's it's a lithium cell and most likely either Li-Po or Li-Ion - cell voltage is 3.7V Nominal - 4.2V max. The MS-0108 is a fixed 4.2 volt output - capable of around 22mA (well- that's the current measured when charging a partially charged blade). If you have a Li-PO charger that will go to 1-cell and drop to ~ 50mA (charge two blades in parallel - hence ~ 25 mA per cell) - should be good to go. My experience with the MS Composit tail blades and using my Triton charger in the above config - the blades will be charged to ~ 80 to 90% capacity. If I allow the MS 0108 charger to "sit" all day on the blades (recall the charger is fixed to 4.20v) - the blades get just a bit more run time as the battery gets fully topped-off.
That rug really tied the room together...did it not? |
09-11-2010, 10:40 AM | #3 (permalink) |
HS1301
You can use the Align HS1301 (325 & 425 Carbon Night Blade Charger) for charging the MS Composit Night Tail Blades.
09-12-2010, 07:46 PM | #4 (permalink) |
thanks guys....... got them charged using the Align charger
John
Gaui X7, X5, NX4, X42, X3 Gaui USA, Empire Hobby, JR Americas, Cyclone Blades, MKS Servos USA, OptiPower Batteries,YS Engines, PowerMaster Fuels |
04-15-2011, 08:04 PM | #5 (permalink) |
I Just received the mscomposit tail blade from my LHS and I notice that the battery is totally dry, neither with the Align or my Bantam or Triton chargers I can charge the tail blades...when I give a try the tail blade battery comes too hot
10-05-2013, 07:30 PM | #6 (permalink) | |
I did it like this person said
Im happy |
