Walkera Helicopters Walkera Helicopter Support |
04-12-2010, 09:24 AM | #1 (permalink) |
60#B Main Gear replacement? too expensive!
The main gear for the Walkera 60#B comes together with the one way bearing, etc,, and it cost $ 17.00 at wowhobbies. (Part number HM-60#B-Z-18 )
Does anybody knows how to get a replacement for only the plastic part (the actual gear)?. Every crash, even the lightest one, destroys it and I have to replace the whole thing. Maybe there is a main gear from another heli that fits in,, like Blade 400 etc. Please help Manny
Manny MA Furion 450, Mikado Mini V-Bar, Scorpion 2221-8, 13T, CC Ice Lite 75A, --- Walkera 60#B, Stock Motor, Stock Servos, Stock Blades and Futaba GY520 (yes!) Spektrum DX7se. And, CRAVING for a HENSELEIT TDR!!!! |
04-12-2010, 09:48 AM | #2 (permalink) |
I feel your pain! I had the same issue... after enough crashes, the 60#B was just too expensive to maintain. I was never able to find just the gear.
04-12-2010, 10:24 AM | #3 (permalink) |
Yes man, this is killing me. 17 bucks min on each crash.
I wont mind modifying the whole thing only If I can get this Main Gear cost go down a little. I hope someone come up with an idea. I dont have a Blade 400 handy so I check,,, I wonder about it because some of the parts of the B400 fits into the 60#B.
04-12-2010, 10:27 PM | #4 (permalink) | |
I've done crude version in my 4G6's tail to avoid stripping the tail gear using simple plastic to white glue clutch and it works. For something like the main gear, I would expect a more complex mod due to the much higher kinetic energy involved. Do not be tempted to do the clutch between the motor shaft(because it may seem very simpple) and pinion because the tiny size could potentially result to overheating during crash and cause fire. |
04-12-2010, 11:07 PM | #5 (permalink) |
:-) Timewerx is a little too technical for my level. Im going to see if paying attention to the stock 60#B gear I can figure something out, using the same clutch, but with a different plastic main disc. Im going to order main gear from some different manufacturers and see what happen. Ill order from the Blade 400, and I have from the Furion 450,, I wonder if I should order from T-REX 450 or some other.
Any recommendation? Thanks Manny
04-13-2010, 07:13 AM | #6 (permalink) |
Not the answer you want to hear, but you may actually want to consider cutting your losses and getting a 450 clone. you can use all the Walkera electronics (except for the servos which are total junk).
04-13-2010, 07:59 AM | #7 (permalink) |
Yes, thats what Im thinking.
I dont know if I will be able to sell the H60B, I have about $200 in unused parts as well. I have enough electronics (ESC, Motor, RX, Servos, etc) to build a T-REX 450, but I have to get rid of one to get the other one. I like how the 60B flies, is only that is too stupidily expensive. I have a Furion 450 also, it doesnt get more expensive than that on a 450, but it is not "silly-expensive" like the Walkera. I wonder how much I could get for it.
04-13-2010, 09:20 AM | #8 (permalink) | |
Walkera also tend to have cheap RTF price tag of their helis but stupendously expensive on maintenance. Sounds like a trap! |
04-13-2010, 10:30 AM | #9 (permalink) |
Yep... I would not buy a "large" Walkera ever again. Their price strategy actually works on their smaller helis (4G6, CB100, etc.)... The helis are cheap to purchase, and the parts are "expensive", but you also don't need to replace parts with every crash. I would say that I only break somthing on my 4G6 or 4#3B once every five crashes, so I don't mind paying a bit more for parts, because many times you don't need spend anything from a crash, so it balances out in the end.
04-13-2010, 12:11 PM | #10 (permalink) |
Agree.
I used to have a Walkera UFLY (fixed pitch but shaft driven tail) and it was kind of cool, but I wish I bought a CP from the beggining. I have the H60B for trying new stuff and later do on the Furion 450. I have enough spare electronics to build a T-REX 450, but I though it was going to be more expensive to fly than the 60B , I think im wrong. Now, what do I do with the 60B and the parts? :-) I just dont want to dump it (eventhough it might deserve it) :-)
04-15-2010, 11:18 AM | #11 (permalink) |
Busted another main gear.
I feel like crying,, $ 17.00 This time was the upper frame,, it was cracked a little so it allowed play from the motor pinion to the main gear,,. When I pushed real hard it stripped the plastic gear. Snif snif.
04-15-2010, 11:25 PM | #12 (permalink) | |
There comes a time that you have to throw a certain heli in the garbage. I think this time is here for you! Don't be sad, it'll only be for the better!
Some people have a problem for every solution... |
