Old 04-10-2012, 12:43 PM   #1 (permalink)
Default Hot YGE
I have a YGE 60 in my stretched 500 and after a 4 min flight the esc is showing 156' F??? The outside temp was 57' F
I am using a 13T pinion 6 cell 3300 packs with a 2550 head speed with sport flying I know the scorpion motors will run hot on this heli but how hot is normal for the esc?
flyfishsick is offline        Reply With Quote Quick reply to this message
Old 04-10-2012, 01:38 PM   #2 (permalink)
Mine also gets very hot, and we aren't even in the summer...
THe 80A didn't get as close in temperature.
MSH Prôtos CF FBL Stretch
E-flite HABU 32, Parkzone HABU 2
Ikarus F3A
Multiplex Parkmaster 3D
whisperdancer is offline        Reply With Quote Quick reply to this message
Old 04-10-2012, 03:58 PM   #3 (permalink)
Just did one more flight outside temp 57F 2550 head speed 4 min of sport flying loops and rolls!! This time the esc hit 181' F !!!!
This is with the air temp at 57' F !!! What will happen when it gets hot out???
Is this normal?
Old 04-10-2012, 04:29 PM   #4 (permalink)
Is this normal?
What are you measuring your temp with? Is it accurate? Also, what motor are you using and what is the PWM and timing you have the ESC set for?
MSH Protos 500, SAB 630
alexf1852 is offline        Reply With Quote Quick reply to this message
Old 04-10-2012, 04:37 PM   #5 (permalink)
Stock motor ( scorpion 880 ) stock setting on esc ( came with the protos kit ). Using the dx8 temp telemetry off the esc plate.
Just made up a heat sink I hope this helps
Old 04-10-2012, 05:37 PM   #6 (permalink)
OK much better with the heat sink!! Same 4 min flight with 2550 head speed esc was 104' F.
People where not kidding about the motor and esc temps. ( motor was 173' F measured with a IR gun )
I think it's all the drag with the belt? Maybe I have it to tight? It should get interesting when it gets hot out!!!!
Old 04-10-2012, 07:24 PM   #7 (permalink)
Do try a looser belt, but that said, 170F for a motor is not really an issue, its well below thermal specs for a scorpion motor.
I noticed with the mini protos that the heli works just fine with the belt on the loose side, compared to how i would set a more conventional belt, especially at the motor end. Not sure its the same on the 500 though.
-DX8
desertstalker is offline        Reply With Quote Quick reply to this message
Old 04-12-2012, 11:37 AM   #8 (permalink)
My YGE 60 barely gets warm even after even my hardest flights. My MSH Scorpion 3026-880 motor gets hot but not my YGE 60, and I'm using a 16T pinion. There must be something wrong with your setup. I use Auto timing and 12KHz PWM rate.
Oxy2 210 | Oxy3 285 | Oxy4 380 | Logo 480XX | 600SX | 650SX | 690SX | 700 | 700XX | VControl
mahbouni is offline        Reply With Quote Quick reply to this message
Old 04-12-2012, 01:31 PM   #9 (permalink)
Mine was like that in the normal Protos, but with the stretch is a different story. I also run low TH curves, so it doesn't help a bit.
Ikarus F3A
Old 04-12-2012, 05:36 PM   #10 (permalink)
Oh I didn't read that the OP had the stretch blades. Hmmm, I was turning 470mm blades @ 2800rpm on my LAHeli Sniper2. It was all fine during the winter and spring but when a 28C summer day came along I twice managed to thermally shut down my Kontronik Jazz 80-6-18. I then ordered a YGE 120 and never had another problem. A YGE 100 would have done the job but the 120 is the same weight and doesn't cost a lot more.
