Old 03-03-2014, 07:54 PM   #1 (permalink)
Default OS 105HZ-R Gov not working
I just switched up from a 91hzr to a 105hzr, the governor was working fine with the spektrum bckpkate sensor, all I did was switch out engines. The governor will not engage, the engine will not get up to hs, it just buzzes the engine at low headspeed.
I tried disconecting the sensor from fbl unit n use throttle curvs, that works so i think its the gov or sensor, any ideas how to fix this?
trollycamber is offline        Reply With Quote Quick reply to this message
Old 03-04-2014, 06:22 PM   #2 (permalink)
What fbl controller are you using ?
MSH mini-p VBar ,G380, Goblin 500, TREX 600N LE VBar, Trex 700N 91hz FB, Whiplash 105HZR VBAR, Nitro Citizen 414
mr008 is offline        Reply With Quote Quick reply to this message
Old 03-04-2014, 09:11 PM   #3 (permalink)
Vortex
Old 03-05-2014, 04:22 AM   #4 (permalink)
You probably need to pull the sensor a bit back. I saw someone had about 1-1.5mm washers between the backplate and the sensor mounting tab and when I asked why I was told the sensor needed to come back to read properly. It is a known problem and if you search for it you will find a more detailed answer than mine.
-Angelos
SPARTANRC - R&D
Angelos is offline        Reply With Quote Quick reply to this message
Old 03-05-2014, 02:24 PM   #5 (permalink)
I tried that, used 1mm shims. I ordered a new sensor Spektrum sensor. It may have been heat from having it up against backplate???? i'll try anything.
I just grinded away the Futaba sensor holder, its much closer to the crank pin. May get better readings.
Old 03-06-2014, 05:01 PM   #6 (permalink)
My Spektrum sensor on my OS105 HZ-R is paper thickness away from the backplate, and it works perfectly (V-Bar)
TDRx2, Synergy N7/E7se/N5cTT, Align 450L/550/700e/700n, Gaui NX7/NX4, , Goblin 700/Black Nitro, Futaba 18MZ/ V-Control All on V-Bar's and S-Bus. #0095
rctintin is offline        Reply With Quote Quick reply to this message
Old 03-06-2014, 11:52 PM   #7 (permalink)
Thanks rctintin
Does the OS 105HZ-R use a metal crank that magnets are not attracted to?
The sensor is picking up my steel tools and they shut the sensor on and off, I still do not get a good reading from the crank pin. I will change out sensor IF Post office delivers this week.
Old 03-07-2014, 09:12 AM   #8 (permalink)
You could try pulling the backplate off and manually move the sensor towards the crank to see if you can get it to toggle? That might at least tell you if it's a sensor issue or a distance between the crank and sensor issue.
Team Synergy Field Rep, Rail Blades
Rodney Kirstine is offline        Reply With Quote Quick reply to this message
Old 03-15-2014, 02:03 PM   #9 (permalink)
Ok, so I pulled the Vortex and installed an iKon, the old sensor worked with it. I put the Vortex back on, this time with the new spektrum sensor. It did not change anything, the sensor reading blips for split-second as the crank pin goes by the sensor, it doesn't stay on for one revolution or stay off for one revolution. The heli spools up but the governor will not engage.
Old 03-15-2014, 02:18 PM   #10 (permalink)
Does your sensor have the digits 616 anywhere on its front face? In fact can you take a photo of it and post it here please.
EDIT: Also, what is the exact Spektrum part number (SMP????) of the new sensor you ordered. Please only tell me if listed on the paperwork. Don't try and guess it from the web as I think there are at least two that look the same but work different.
SPARTANRC - R&D
Old 03-15-2014, 11:58 PM   #11 (permalink)
I have the 617
This the old one;
This is the new one on the heli, Its not a good pick but it says 617 on it. 7000XAC, 617, 1237.
ID:	494790   Click image for larger version
Old 03-16-2014, 06:04 AM   #12 (permalink)
I figured it out...
The 616 sensor requires a minimum of 3.5V to operate (according to official spec from the chip manufacturer) whilst the 617 requires 4.5V. They will often operate with lower voltages too but they performance may start to be affected. Certainly it is not recommended to do so.
The Vortex provides regulated 3.6V to the RPM sensor which has been fine for every governor sensor in existence until this 617 just surfaced. Providing regulated power to the sensor is much better as it has clean voltage unaffected by digital servo noise etc which sometimes affect it.
For the best possible results I think the 616 sensor is the way to go although I realise it may be hard to find one especially if Spektrum have mixed production runs on recently switched to the 617.
Alternatively try connecting your 617 sensor as shown on the photo and see if that makes it work. Basically instead of taking regulated power from the Vortex we take unregulated from the main power bus. You can use either the DataPod or RX middle pin for a quick test.
-Angelos
SPARTANRC - R&D
