Belt CP E-Sky Belt CP
Old 04-08-2010, 05:33 AM   #1 (permalink)
Default HK600GT review/build
This is one of the cheapest heli's I ever build and reading about this heli in the Hobby King's reviews didn't gave me a lot of confidence but hey you never know how it turns out. As there was no manual included I used the T-rex 600 GF manual to get some guidelines
I will skip the "opening of the box" ect. and go directly to the build.
The frame:
Top servo link was missing
frame deformed due to bad fit on the bottom plate ( now this is a bad start )
So I redid the frame to fit the bottom plastic plate/bracket, all mounted and locktide screws ,belt placed, I used the shaft to center the bearings in the frame .One screw was missing of a canope mounting ( again something missing pfff ) luckily I have all sorts of screws and found a servo link to replace th missing one (still have to mount it)
Skids, anti rotation bracket, tail boom, rudder servo mount and tail rod guides mounted and no problems ( well, well, well ).
The size is beginning to dawn on me
Mounted the tail on the boom, the screws are a bit dodgy ( use very good tools and there will be no problems ) then I noticed somthing, the belt is scraping the bottom of the tail casing ( not very good I think )
Now this is bad machining the bottom half moon is off center
My eye fel on this little discrepency on the tail shaft this is a 2mm out of 90° angle on this small amount of distance
( this I am going to leave alone )
Of to my workshop to repair the tail casing
Filed the belt space out left the bad tail shaft angle as is
The new belt passage enough space now
Tail, struts and main gear mounted was a bit wobbly but hey I used to work on Belt cp's so I bend the gear straight ( no problems )
By comparison with my wife's bike, man this thing is big
Tried to mount the servo's but the where hitting each other ( problems, problems )
The original servo mounts that I will use
In combination with the mounts of the HK, I drilled out the left side ones , then I realized I have not enough mounts for the pitch and rudder servo ( damn )
so I made some more out some left ovet aluminium strip
A perfect fit
ID:	149992   Click image for larger version
ID:	149993   Click image for larger version
ID:	149994   Click image for larger version
ID:	149995   Click image for larger version
ID:	150001   Click image for larger version
ID:	150002   Click image for larger version
ID:	150003   Click image for larger version
ID:	150004   Click image for larger version
ID:	150006   Click image for larger version
ID:	150007   Click image for larger version
ID:	150008   Click image for larger version
ID:	150009   Click image for larger version
Anything that flies
Ber60 is offline        Reply With Quote Quick reply to this message
Old 04-08-2010, 06:23 AM   #2 (permalink)
Excellent clear and precise report so far. I had been looking forward to it and you haven't disappointed. I await the remainder with baited breath. I know you have come across a few glitches, but you have dealt with them in your stride, as I guess many could, and for the price, perhaps it is acceptable. I guess further proof might be needed in terms of durability, bearing failures etc.
I am not used to the size of my 600 yet, and as you know it still scares me. How I would feel if I thought some of the components might be of suspect quality I have no idea, but I know that you will spot and correct most if not all issues in this regard.
If you think it is big now, just wait until you spin it up. I'm looking forward to that too.
Cheers
Sut
Regards, Sutty
sutty is online now        Reply With Quote Quick reply to this message
Old 04-08-2010, 06:28 AM   #3 (permalink)
The flybar cage bent 1mm due to not enough spacers in the flybar control arm
It started to bind
I grinded down my own 1mm spacers to fit in the cavity of the flybar control rod,
yes there are spacers in the arm
A view of my 1mm spacers made to fit
The spacers mounted in the fybar control arm
I had a gut feeling the radius arm of the washout assy is a mirrored mistake because the ball-link entry is reversed but redbird300 told me it was a common use in some heli's
Started to setup the head and noticed when leveling the washout arms the plastic servo ball-links where 5mm to short ( at the bottom of the pic)
I started to experiment with the main shaft, cut it 8mm from the top and drilled a new hole for the top Jesus bolt but found it to short, so of to the LHS for align links ( longer than HK links) and main shaft.
What the ... the align shaft's jesus bold sits already +/-2mm lower no need to cut down the shaft to make the links fit
So with the longer links and the shorter align shaft everything falls in to place, servo arms and links all at 90° all the way up to the washout arms
The whole head is setup and by -12° collective the anti-rotation pins are still half way down in the washout base mounted the tail servo, paddles and blades and the heli whas almost mechanically finnished ( I am still waiting on a delayed motor ).
I can get +/-12° of collective and +/-8° of cyclic not bad it you ask me
I enjoyed the build of this heli and found only a few problems that were easy to solve.
A good value for money imho
Up to the electronics but I wont post about that
Just for your eyes onle
Enjoy the thread
Erwin
ID:	150033   Click image for larger version
ID:	150034   Click image for larger version
ID:	150035   Click image for larger version
ID:	150036   Click image for larger version
ID:	150038   Click image for larger version
ID:	150039   Click image for larger version
ID:	150040   Click image for larger version
ID:	150041   Click image for larger version
Anything that flies
Old 04-08-2010, 06:43 AM   #4 (permalink)
Sorry Erwin, I didn't mean to jump in, in the middle of your post. Didn't know another was to follow. Just went on my lunch, and saw the first post, and figured that was were you were up to so far. I guess my comments about value for money, you agree with as I now see your comments at the end.
Now I guess we all look forward to the maiden video.
Regards, Sutty
Old 04-08-2010, 06:47 AM   #5 (permalink)
Excellent report Erwin ! And a very critical, careful and inventive building job ! Well done. I knew I had to leave the building part to you, lol.
Bad news about the motor I ordered though: it's not in stock yet, and even not mentioned on the website anymore. Need to contact these guys I guess for an alternative, but will need another pinion also if the kV value is different (and it probably will).I'll see what I can do, I really want us to get the bird in the air in a few weeks.
I would be glad to do the setup of the electronics, shouldn't take long as you are preparing everything so perfectly.
Logo 800 - TDR 14S - TDR 12S - Logo 500SE - Logo 400 - Furion 450 6S mini-V - 300X - 150S - mCPX - Schluter Bell Huey Cobra '74 - Aura 4 hotliner - F27D Evo
redbird300 is offline        Reply With Quote Quick reply to this message
Old 04-08-2010, 07:06 AM   #6 (permalink)
No worries Sutty, the second part I had to redo 3 times bacause of my dumb fingers I lost it 3 times
Anything that flies
Old 04-08-2010, 07:11 AM   #7 (permalink)
Ok, I will get the electronics in the bird and await the motor and turn it over to you, can't wait to see this bird airborn
Oh thanks Sutty , Raf for the nice comments
Anything that flies
Old 04-08-2010, 10:48 AM   #8 (permalink)
Interesting report, Erwin. Looks like you still get what you pay for. An experienced builder, like yourself, who recognises the problems can easily overcome them, but a novice builder a on a budget, well, good luck.
Really looking forward to the flight report!
Avant Aurora 90n
HC500
HDX450sev4
Trex250se
msr
Tomstoy is offline        Reply With Quote Quick reply to this message
Old 04-08-2010, 12:48 PM   #9 (permalink)
Great work Erwin, I always look forward to seeing your projects
- Jack
Cranky old fart and charter member of ESO
Lots of Helis
mnwizard is offline        Reply With Quote Quick reply to this message
Old 04-08-2010, 02:36 PM   #10 (permalink)
Erwin, your building skills are really up there. What do you need a kit for anyway ? I bet you could make the entire heli yourself from stuff you´d find in your neighbours garbage can
Seriously. This looks like a nice kit for someone with experience and patience to make everything right. A beginner would probably kill himself with it, though.
Thanks for sharing your build with us, and please find enclosed a bunch of punctuation marks you can toss around in your next post.
If you are out of commas aswell, get some from here
MSH Protos, Gaui X5, Oxy4, Oxy2
RC Heli Lounge on Discord : https://discord.gg/92HmhxWK
Tjomp is offline        Reply With Quote Quick reply to this message
Old 04-08-2010, 05:22 PM   #11 (permalink)
Fantastic work as always Erwin Would you permit me to publish this report onto my blog? as your work of course. i think many people will benifit from your insight here a stark warning to the masses who think these are good helis!
Alex
MY BLOG Stop by say hi :-)
500 ESP: Ely Q Comp: "Kasama'd Trex 600N:
lex7919 is offline        Reply With Quote Quick reply to this message
Old 04-08-2010, 05:36 PM   #12 (permalink)
He's probably making a torque tube conversion for the tail out of those punctuation marks right now.....although exclamation marks would have helped with the gears at the end!
Seriously, impressive thread. I had toyed with the idea of a "cheap" route into a bigger heli having been happy with the HKH 450s I had. But this has shown quite clearly that the cheap clone route doesn't translate quite so directly for the less experienced builder!
450 Bell 222, 450 Jet Ranger, HBFP Redbee Extreme, 500 size Blackhawk MH-60, 600 EP Spitfire, Sebart 342 30e, Davy Systems Flybaby, ST Models FW190, Micro SU26 & GWS P38. DX7s
Luke Warmwater is offline        Reply With Quote Quick reply to this message
Old 04-08-2010, 05:37 PM   #13 (permalink)
Loved the write up and photography Erwin- fantastic work mate
Must admit, some of the manufacturing errors were shocking- even for a cheap kit!!
Look forward to the flight report.
450 PRO, 500 ESP
Due to economic circumstances, the light at the end of the tunnel has been turned off until further notice.
lankey is offline        Reply With Quote Quick reply to this message
Old 04-08-2010, 06:58 PM   #14 (permalink)
Thank you and feel free to do so Alex
Anything that flies
Old 04-08-2010, 07:07 PM   #15 (permalink)
Thanks guy's for the nice comments and I agree, like many of you found, that this is not a heli for beginners
Anything that flies
Old 04-08-2010, 08:19 PM   #16 (permalink)
Exceptionally well done Erwin. No this kit isn't for beginners, HK's target was people who already owned a large bird like this and had spare electronics. Though the moment it was announced and released, every HK fanboy, cheapo, or guy on a budget or out for a project went on a HK-spree and got one.
Did you happen to find the main gear center offset by 2mm? Some people reported that was a big bug, other than that and the pins and a few broken bottom trays everything you discovered is new news.
B2TheEYo is offline        Reply With Quote Quick reply to this message
Old 04-09-2010, 03:38 AM   #17 (permalink)
The main gear has a small wobble and a center offset of perhaps 0.5 mm, I found it a good main gear the same for the auto rotation gear
Anything that flies
Old 04-10-2010, 02:02 PM   #18 (permalink)
Erwin, An excellent review Really useful to have a master builder like yourself go over one of these with a fine tooth comb
Looking forward to it getting airborne and some videos of RAF putting it through it's paces too!
T-Rex 500 µBeast, 450 Pro (soon to be µBeast) & a Compass 6HV
And a P51D plank......SSssssshhhhhhh!
BMFA & RCHA Member
[B][COLOR="Blue"]
psilo is offline        Reply With Quote Quick reply to this message
Old 05-01-2010, 05:46 PM   #19 (permalink)
Hello,
This is my first post on this forum and i'm very glad to being here.
I just received my new HK600GT but the electronics are still deficiency.
I think this topic will be a valuable guide for me when i start to build my 600GT.
Thanks.
Azalin is offline        Reply With Quote Quick reply to this message
Old 05-01-2010, 05:57 PM   #20 (permalink)
Hi Azalyn, wecome to the forum.
- Jack
Lots of Helis
