Old 12-06-2008, 11:35 AM   #21 (permalink)
The Capi
Nice job so far Mercuriell. One thing that should be noted on the tail is that there are special screws that hold the tail grip assembly to the hub, they are not standard screws. I'm not sure if the new kits have these included or if you still have to send away to MA to get them. There have been several cases of the tail assembly failing when running our crazy high HS.
P.S. I love the rodent friendly build series
Old 12-06-2008, 03:30 PM   #22 (permalink)
Thanks HFG - I am aware of the bolt issue - my local distributor wasn't sure if the new bolts were included - the new ball links were - I will send an email to MA to see if there is any way to check.
Norah has been busy during the build with QA and seems reasonably happy so far - she sends her best wishes to all her fans
John
Old 12-06-2008, 04:16 PM   #23 (permalink)
The Capi
You might always want to consider replacing those wimpy servo horns, other users have found that they flex alot in flight (i'm a diehard 65MG user).
Old 12-06-2008, 04:35 PM   #24 (permalink)
yeah, you sure dont want your heli feeling like its controlled by rubber servo horns.....
Vbar Trex 700, Vbar Protos 500, Vbar Logo400 Trex 450 Pro
mapleleafs is offline        Reply With Quote Quick reply to this message
Old 12-06-2008, 04:40 PM   #25 (permalink)
HI Mercuriell
Norah is cool-how long has she been around?
The build looks good and I especially like the way the tail servo is done
Might be good to get another 450 size and the Furion looks pretty good as do the Beam and Rave for that matter.
Take care and have fun
Frank
Gaui Hrricane 550 Century 600A JR servos 401 Gyro JR 3400G tail servo JR X9303 radio CC85HV Esc
Trex600E Spektrum 7 Channel Hitec MG servos 401 Gyro Hyperion tail servo Stock Align electronics
jaof
frankreh@rogers.com is offline        Reply With Quote Quick reply to this message
Old 12-06-2008, 05:01 PM   #26 (permalink)
Agreed - but I think for doing a build video that it's best to build and test stock items first before adding the bling - that's why it's good to the 'Freaks to chip in their 2 cents worth
Norah's been around since my Logo 500 build - she loves the Logos best - have to say a nice fat brown Rattus Vulgaris is the BEST pet !!!
John
Old 12-08-2008, 08:07 AM   #27 (permalink)
gwk
John, Very nice build series as always! Hmmm....now I'm going to have to get one of these
gwk is offline        Reply With Quote Quick reply to this message
Old 12-10-2008, 03:51 PM   #28 (permalink)
Working up the rotor head we have:
Washout and Mixer Arms - 17MB wmv
Grips and Head Assembly - 18MB wmv
No great dramas here - getting good at green Loctiting though
PS Check your head brass spacers (130-112) width - see photo - if they are 2.15mm thick sand them down on some wet and dry paper on a flat surface to get them to 2mm - otherwise they preload the radial bearings and cause notchiness - Thanks to HFG for the heads up
John
Old 12-11-2008, 03:21 PM   #29 (permalink)
The Capi
You should be able to crank down on the spindle bolts and the grips will be suppppppper loose. If you cannot do this then you have one of the early kits where the brash spacer wasnt the proper size. You can buy a new one or do what i did and sanded it down to the required 4mm (4mm is from memory, not sure what it is exactly). Took me about 20secs to hand sand the spacer down.
Old 12-12-2008, 05:28 AM   #30 (permalink)
Following up on HFGs advice I broke down the main grips (you have to take off the CF balde holders to get the bearings out) and measured the brass spacer between the outer radial bearing and the inner thrust race - 2.15mm - I sanded both sides down to 2mm and Voila - problem solved - able to torque up the head axle screws without notching or binding - thanks HFG !
Later kits apparently have addressed this problem so either measure them up or have a trial assembly
John
Old 12-13-2008, 07:58 AM   #31 (permalink)
Thanks HFG/John. I also had to do this same thing with mine.
Also... for what ever reason the 2 brass axel washers were different thicknesses so had to order new ones (part number 130-113).
"One person's anecdotal experience about anything in life does not make it fact for everyone else"
Stolen from user "Xrayted"
mlucia is offline        Reply With Quote Quick reply to this message
Old 12-14-2008, 06:07 AM   #32 (permalink)
Up goes flybar assembly and head installation and that's all the mechanics done !!
Just have to video the electrics install in the completed heli and maybe some footage of the flight test - actually maidened her today - final setup took all of 10 mins and didn'nt need to adjust for tracking - got 12° +/- collective with 60% swash AFR on pitch and set up throttle curves 85-70-85 on idle1 and 100-85-100 on idle2 using an ALign 60A ESC. This heli flies likes it's on rails and my Stratus flying mate Ben and myself both agree it has a feel of the bigger MinAir helis - only needed a click or two of trim and is the nicest 450 by far I have seen or flown. This heli is definitely a keeper
I'll do a video overview of the electrics install - not sure whether to do a setup vid as I guess most builders will be experienced and the MinAir booklet is very comprehensive on this. I'll post a flight vid though
MA Furion - flybar assembly and head installation - 45MB wmv
John
Old 12-14-2008, 12:59 PM   #33 (permalink)
I'm considering this to replace my 450SE. So far none of the other 450's have enticed me enough to make it worthwhile. Looking forward to the feedback.
Oxy2 210 | Oxy3 285 | Oxy4 380 | Logo 480XX | 600SX | 650SX | 690SX | 700 | 700XX | VControl
mahbouni is offline        Reply With Quote Quick reply to this message
Old 12-14-2008, 09:16 PM   #34 (permalink)
A quick run over what and where I installed for electrics - just a flight video to come now !
MA Furion - Electrics overview 23MB wmv
John
Old 12-14-2008, 09:52 PM   #35 (permalink)
The Capi
Great job Merc..... but OMG that wiring Actually i found it kinda tricky to wire this heli. This is my current iteration.
ID:	72496   Click image for larger version
Old 12-14-2008, 11:55 PM   #36 (permalink)
Actually I was quite pleased with my wiring and Norah liked it
ID:	72534   Click image for larger version
John
Old 12-15-2008, 01:11 AM   #37 (permalink)
Beautiful Jon!
Just a guy and his heli....
LITHIUMSTATIC is offline        Reply With Quote Quick reply to this message
Old 12-15-2008, 11:04 AM   #38 (permalink)
Team Taco VP
CARUMBA HFG..... That ESC is gigantic! I tried to use that on my Beam and shelved it because of the size...
Bob
Old 12-15-2008, 11:21 AM   #39 (permalink)
The Capi
Bob small price to pay for a 3700 HS The 45A scorpion ESC isnt much smaller and i had this handy.
Old 12-15-2008, 11:24 AM   #40 (permalink)
Yep... Capi, it's like the hot chic with the big ugly nose.
