Go Back   HeliFreak > R/C Helicopter Support > 500 Class Electric Helicopters > 500 Pro Class Electric Helicopters
500 Pro Class Electric Helicopters 500 Pro Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 02-18-2015, 09:40 PM   #1 (permalink)
Default Main bearing blocks
anyone know the correct orientation of the main shaft bearing blocks on the 500 Pro DFC?
I have mine mounted print side up on both upper and lower blocks, but wondered if the bottom might need to be print side down???
Blade: Nano QX, SR, 230s, 400 3D
Walkera: V120D02s
Align: 450L Dominator, 450 Pro DFC,
500 Pro DFC
nighttrain06 is offline        Reply With Quote Quick reply to this message
Old 02-19-2015, 12:32 AM   #2 (permalink)
For anyone interested I found the correct orientation, along with the help of a good guy named Dave!
The Main shaft bearing blocks go as follows:
Top Block Print faces down...you should not see the "Align" print on the top bearing block!!!
Bottom Block: Print faces up, in other words you should be able to look down from the top and see the Print "Align" on the bottom block....
This is critical!! I know....i had them wrong, and the bearing came out of the top block, and also the one way bearing collar moved out on my main gear....this caused huge pitch problems because the shaft and head were now able to move up and down....I crashed because of this....actually pounded the thing into the ground skids down....was lucky though...broken skids, blades scuffed up was only damage....
Rodney
Walkera: V120D02s
500 Pro DFC
Old 02-19-2015, 02:04 AM   #3 (permalink)
Page 7 of the manual shows this. It shows a picture and even says Laser Engraving Face Inside and points to both bearing blocks
Nigel.
A few little tiddlers ..SR, 300X, TRex 500E Pro with DFC, Trex 700DFC..... and quite a few Planks and Tanks !
nbells is offline        Reply With Quote Quick reply to this message
Old 02-19-2015, 10:11 AM   #4 (permalink)
Post
Yes sir is does! My mistake was I purchased a frame tail that was used, and built it from there.....the bearing blocks were already installed in the frame...
.....and the age old lesson about assume is learnt again by me.....
Walkera: V120D02s
500 Pro DFC
Old 02-20-2015, 01:02 AM   #5 (permalink)
Absolutely no probs. Its actually refreshing to see someone finding out themselves and then passing on the info they found. So good on ya !
Let us know how the maiden flight goes
Nigel.
Old 02-20-2015, 02:26 AM   #6 (permalink)
I try and learn everything possible about my helis, love putting them together!
This thing flew solid as a rock about 5 times before the bearing backed out....I guess when I flicked on idol1 it put more stress on it, and it slid out....I should have known also because I had a hard time shimming it up right so that the gears aligned....this was my second hint I believe that something was not right! Hehe The third hint being it slamming into the ground was too late I reckon.......;-).........
Oh well I know now....Oh also something strange....I was talking to another guy about this...and he says that every align 500 he has seen has the little tabs on the sides of the bearing blocks in order to install them correctly...also the slots in the frame for the tabs....
Mine has neither, could this be a very early version of the 500 Pro DFC?? Has me wondering if I need bearings or bearing blocks for it that I may have a hard time finding them......
Walkera: V120D02s
500 Pro DFC
Old 02-22-2015, 08:43 AM   #7 (permalink)
I don't remember there being tabs on my 500s bearing blocks. Maybe he was talking about the boom block?
CrashNburn420 is offline        Reply With Quote Quick reply to this message
Old 02-22-2015, 11:02 AM   #8 (permalink)
The stock bearing blocks on my 500 ESP had tabs.
*Spartan Vortex VX1e*
Old 02-23-2015, 01:01 AM   #9 (permalink)
The Pro has never had "tabs" or slots in the frame, it uses the method as noted in the manual. It was the early 500 version that used that idea, I think !
I have now changed over to the KDE bearing blocks as they support the main shaft alot better that the stock items.
Nigel.
Old 02-24-2015, 06:38 PM   #10 (permalink)
Default Bearing Block...
Ya i had a screw Break off in one of my Blocks the other day
And so i ordered the Helioption one piece bearing block with bearings and Thrust Bearings...
and man it is soooo smooth
I really like it and i also have one on my Rex 600 Pro DFC...
Fly Safe & God Bless
holytrex is offline        Reply With Quote Quick reply to this message
