Go Back   HeliFreak > R/C Electronics Support > Scorpion ESC and Motor Support
Scorpion ESC and Motor Support Scorpion Power Systems ESC and Motor Factory Support Forum
Old 12-21-2012, 05:17 PM   #61 (permalink)
Talking
Originally Posted by gixster View Post
Iam in the middle of putting one on my trex 550 dfc.
I am currently running the beastx AR7200BX.
the backup guard works as advertised, the switch is instantaneous and the beastx does NOT reset.
Nice, thanks for the demo! This thing is high on my list now.
Libtekguy is offline        Reply With Quote Quick reply to this message
Old 01-22-2013, 01:15 AM   #62 (permalink)
Can you use the backup guard with a 6.6 life pack?
hoggy is offline        Reply With Quote Quick reply to this message
Old 01-22-2013, 01:32 AM   #63 (permalink)
Default Re: Scorpion Backup Guard
yes it will only discharge if it sense below 5volts.
Sent from my phone using Tapatalk2...otherwise i would of sent it from my home PC.
you should look into it...........
crf69 is offline        Reply With Quote Quick reply to this message
Old 02-04-2013, 05:25 PM   #64 (permalink)
will this unit work safely with a gryphon hyper hv bec quasar gar-7075 lmt thats running off the main packs 12s
thanks liam
goblin 700- goblin 500 - logo 700 -logo 550 - gaui nx4
Blade mcpx bl and 130x
liam-b is offline        Reply With Quote Quick reply to this message
Old 02-04-2013, 06:40 PM   #65 (permalink)
yes.
Old 02-23-2013, 01:18 AM   #66 (permalink)
I have one of this thing.. But i'm nog sure off using it with the kontronik helijive 120hv. What do i have to do for that. Bec 6v?
Thanks for the help
tf-zuid is offline        Reply With Quote Quick reply to this message
Old 02-23-2013, 02:08 AM   #67 (permalink)
I have one of that thing. But i dont know gor sure if i can use it with a kontronick helijive 12
Old 02-23-2013, 02:35 PM   #68 (permalink)
Default Sv: Scorpion Backup Guard
Hi
You can use it with what ever you want. Both inbuild bec, or seperate power. But its mostly ment to esc's with inbuild bec..
It only takes over when the other power system fails, and voltage drops. Its a oneway backup, so power can't go in, only out
Best regards
RasmusDK is offline        Reply With Quote Quick reply to this message
Old 03-11-2013, 04:24 PM   #69 (permalink)
Default Goblin 770
Guys,
I have a new Goblin 770 which is running a Kontronic Kosmic 160 and JR 8717 HV servos. My thought was that this device can plug straight into my V-Bar and should the ESC or a battery burn up in flight that this device would power the Vbar and the servos for enough time to auto the heli back to the gound. Am I correct that this is how the Scorpion Backup Gaurd works? Is there enought power at 5 volts to operate the servos through an autorotation?
Thanks for your insight.
Andre
Goblin 770, TREX 700N, TREX 550, TREX 450, Blade 130X
AndreKoren is offline        Reply With Quote Quick reply to this message
Old 03-12-2013, 02:54 AM   #70 (permalink)
Originally Posted by AndreKoren View Post
Guys,
Andre
Hi Andre.
Yes, you are correct.
It's more than enough
Best regards
Sendt fra min HTC Desire med Tapatalk2
Old 04-04-2013, 11:59 AM   #71 (permalink)
Anybody have any more info on this claim that the Back Up Guard should not be used with switching BEC's?? See here:
https://www.helifreak.com/showthread.php?t=516471
krefi is offline        Reply With Quote Quick reply to this message
Old 04-04-2013, 03:22 PM   #72 (permalink)
I haven't read the other thread.
But I uses backup guard in both bec and opto esc. And it works fine.
Scorpion backup guard is a oneway , it only takes over when voltage drops. So I can't see why it should do any damage or so to a esc?
Old 04-04-2013, 04:07 PM   #73 (permalink)
Hey guys so I recieved my scorpion backup guard and was testing it on my Goblin 770. I want to let you know my experience and results. First let me say the product in is very nice in design and would be a great addition to most helicopters that don't run HV servos. Frst let me tell you what I'm running.
Goblin 770
Pyro 800-40 Motor
Kontronic Kosmic 160HV ESC
JR8717HV x3 Collective
Futaba BLS256HV Tail
Fullsize V-Bar
After charging the Backup Guard I installed it on the helicopter and pluged the one way servo cord into a free slot on the back of the V-bar. I powered up the helicopter with my main packs and then turned on the backup guard as instructed. I checked that I had a steady red light indicating that the sysytem was working and had sufficient charge (it was at 100%). I then proceeded to test the backup guard by unplugging the main packs and sure enough the system remained powered. The problem is that the 5 volt 10 amp output of the backup guard is not enough to power the JR8717HV servos properly so you end up with lock up in the servos as you try to move them in full up or down.
That being said I would love one of these on a smaller Heli that is not running HV servos. I also hope that scropion comes out with a HV version of this as it would be a great security measure allowing you to perfrom an auto-rotation back to safety in the event a main pack fails or an esc burns up.
Andre
Old 04-04-2013, 09:54 PM   #74 (permalink)
my backup gaurd powers all my helis no issue. even fast stick pumps.
gob7 with MKS 950/980 normally 2s direct
Gaui X5 with ds615/Mks 980 normally internal yge90lv bec
E5 with Torques.Wr super bec
7Hv with Mks 665/669 Wr super Bec.
All with Ar7200 and sats.
Old 04-04-2013, 10:27 PM   #75 (permalink)
Default Scorpion Backup Guard
I think it's a vbar issue, I had the ar7200bx on the 550 and everything worked great, when I went to vbar , if i make quick movements it stops or gets real choppy and hesitates . Everything but the gyro stayed the same
Synergy E7SE / Synergy E5s / Blade 180 CFX
IX12, DX6, Real flight 8, ACCURC
gixster is offline        Reply With Quote Quick reply to this message
Old 04-04-2013, 11:38 PM   #76 (permalink)
I forgot to mention that I spoke with Inovative Designs the US distributor for Scorpion Products and they confirmed that the Backup Guard will not properly power all HV full size servos like the JR8717HV which is on my G770. They even mentioned that a HV version of the Backup Guard may be on the horizon.
Old 04-06-2013, 11:41 AM   #77 (permalink)
Blade Forum Support
Here is how I sm charging my backup.
I got the charge lead for the mini striker And took the smaller plug off and I'm using the pins.
Be blessed
Isasc
Sent from my Galaxy Nexus using Tapatalk 2
Jesus Rep Its all Good,Its all GOD
FPV Everything Now
GOD BLESS
tntburnett is offline        Reply With Quote Quick reply to this message
Old 04-12-2013, 12:49 PM   #78 (permalink)
I have mine mounted now on my 550. I wanted to be able to remove it easily one so I could store it with my other LiPos and to make charging easier because the charge leads are so short. I removed a little of the shrink wrap and removed the power wires. Then took a deans mini, sanded it down a little on the back side and soldered it in place. Bingo works great and is easy to remove.
CFHeli1 is offline        Reply With Quote Quick reply to this message
Old 04-12-2013, 01:19 PM   #79 (permalink)
Blade Forum Support
You can barely see where its at on my 700e
Be blessed
Isaac
FPV Everything Now
GOD BLESS
Old 06-23-2013, 11:04 PM   #80 (permalink)
anybody use the Scorpion backup guard with an Align 70 amp esc? just wondering if theres any problems with that setup? Ill be using this in an airplane.
wedoitall is offline        Reply With Quote Quick reply to this message
