Old 01-16-2015, 07:23 PM   #1 (permalink)
Default perfect regulator kit
the kits from perfect regulator worth the money?
rosebomb is offline        Reply With Quote Quick reply to this message
Old 01-16-2015, 08:48 PM   #2 (permalink)
I only have experience with the micro kits and I was pleased with what I got for the money. What size are you looking at?
George - Goblin700(iKon2), Trex550e(iKon), Oxy3(microiKon), Taranis
gstoneberg is offline        Reply With Quote Quick reply to this message
Old 01-16-2015, 09:28 PM   #3 (permalink)
Same here, but I used one of their big blade kits. They now offer a (limited) choice of led colors you can choose from, too.
180CFX, Trex 550E (night), Goblin 570, Goblin 630C, DX8
Skidpad is offline        Reply With Quote Quick reply to this message
Old 01-19-2015, 07:21 PM   #4 (permalink)
looking for my 450x and 180. i have started playing with lights but my skill level is not up to blades yet. i still have a ways to go on power system and mounting.
Old 01-19-2015, 10:24 PM   #5 (permalink)
Since you're looking at a setup fot the 180, here's a video I shot tonight of the perfectregulators blades and canopt/tail kits on an mcpx-bl. You would use the same micro kit for the 180cfx and this will let you see what you would get. I should have charged the lipos on the blades before the last flight. They were dim but I didn't have any trouble seeing them. Did have some trouble flying though. The first flight took place between sunset and dark, and the second flight was about an hour later. You get about 4 flights per charge on the blades and I had flown 2 flights the previous night.
BL night flights 1-19-15 (4 min 33 sec)
George
Old 01-21-2015, 09:41 PM   #6 (permalink)
sold!!!!
Old 06-25-2015, 02:00 PM   #7 (permalink)
Perfect Regulators mini night blade kits - suck
Short battery life - 10 -12 minutes per charge
lipo batteries that only charge to 3.9 volts
intermittent switches
Worst problem
Phone number listed is invalid
E-mail responses from me have been blocked by their server
Initial response time was good - as soon as I had a problem I was cut off from communicating with them
Use there products at your own peril !!!!!
FASTER is offline        Reply With Quote Quick reply to this message
Old 06-26-2015, 01:42 PM   #8 (permalink)
I just bought a set of the V2 perfect Regulator blade kits and so far they look good. Still have to solder the connections as well as Get a LED strip set for the tail boom and fuselage. Blades are pretty bright with 3 LED's top and bottom. Went with Green top and White bottom LED's. Not sure what flight times will be will need to do some timer testing with them.
Gabriel Sandoval "NitroGabe"
soXos USA Flight Team, Team JR PROPO
Team Scorpion, Team YS engines USA
Bavarian Demon Flight Team #HIGHONHELIS
DUCDOC is offline        Reply With Quote Quick reply to this message
Old 09-01-2015, 11:32 PM   #9 (permalink)
Worst problem
I had a similar problem with them. They claim there is a 1 year warranty on their be but good luck if you have a problem.
frankiexp2 is offline        Reply With Quote Quick reply to this message
Old 09-08-2015, 10:05 PM   #10 (permalink)
Those problems are with the micro kits right? I haven't seen any issues with the bigger blade kits. Batteries are 120mah with Jst. Should be easy enough to find something compatible if the battery dies?
I'm wondering if these kits are a better first timer night blade that the $200 offerings with LEDS built in
Old 09-11-2015, 04:37 AM   #11 (permalink)
One of these kits are what I used on some cheap HK 600 blades as my entrance into the night flying world - worked great, and for a little over $100, I had night main blades. IMHO, these kits are a great way to get started in night flying - especially now that you have a (limited) choice of colors with them.
If you already have blades, making your own night blades is by far the cheapest way to go, but also the more research and labor intensive.
I've since converted a Trex 550 to a night bird, and am using off-the-shelf RotorTech night blades, but plan to make my own at some point.
Old 09-11-2015, 08:55 PM   #12 (permalink)
I made my own night blades for the Trex550 I have. I haven't found large heat shrink to hold the lipos down, but other than that they're done. I have about $30 in them so far including the blades.
Old 09-29-2015, 08:47 AM   #13 (permalink)
I used "self fusing silicone tape" on my lipos for the 550 works great.
Your is my Bread and Butter.
Compass Field Rep/KBDD Team pilot/Experiencrc.com
sewerfly is offline        Reply With Quote Quick reply to this message
Old 09-29-2015, 03:44 PM   #14 (permalink)
Fast Lad in the UK has 50/70/90mm from Quantum, most probably you can find in the US too
http://www.fast-lad.co.uk/store/adva...shrink&x=0&y=0
Oxy 2X-VertWarp 360Blade 450XBlade 450X NightflyerGoblin 500 ♦ 2 X mCPX v2 ♦ night fly mQXLadyMQXnano QXnano QX FPVInductrixDX8 G1
Coco66 is offline        Reply With Quote Quick reply to this message
Old 09-29-2015, 06:35 PM   #15 (permalink)
Thanks guys. I'll give one of those a try.
Old 10-20-2015, 09:23 PM   #16 (permalink)
Amain has it too, but I'd have to verify the size with my extra pieces: http://www.amainhobbies.com/rc-cars-...-rce2322/p5546
Old 01-14-2016, 05:54 PM   #17 (permalink)
I figured I would give perfect regulators night kits for 250 - 360 blade sizes a shot back in August of 2015, so placed an order. They billed me, but order still just shows pending as of today Jan 14, 2016. I have e-mailed them a lot, and tried to call, but only got 2 messages back saying they are on back order. So I will not do business with them again.
Matt Cramer
Lynx Heli Innovations & Oxy Field Rep / BK Servo Team / Team iKON
OXY 2 / OXY 3/ OXY 4 / OXY 4 max / OXY 5 / OXY 5 MEG Chronos 700 / Blackout mods G700XZ gasser all flown by DX9 / Ikon 2 FBL units
crma0101 is offline        Reply With Quote Quick reply to this message
