Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > E-Sky Helicopters > Belt CP
Belt CP E-Sky Belt CP
Old 03-07-2013, 06:54 PM   #1 (permalink)
Default PL6 charging station
In the meantime I have finished a nice little side project: my PL6 charging station
First, got me 2 HP DPS-600PB 12V 47A server power supplies, $50 for both including shipping in the US from some surplus PC outfit selling through Amazon.
Second, a nice sturdy, and non-conductive $50 toolbox from a local Home Depot:
Third, a quarter of a full 8'x4' sheet of 3/4" thick plywood, plus some screws, washers, latches, mosquito screen, let's call it another $50.
Jerry
jperkosk is offline        Reply With Quote Quick reply to this message
Old 03-07-2013, 07:11 PM   #2 (permalink)
Since there is a potential safety issue with grounding (server PSUs have negative DC terminal connected to the case) I went with the totally insulated concept and did away with the grounding altogether, same way some commercial power supplies are designed when they're missing the grounding plug.
So first, I built an inverted mounting deck for the power supplies. They are electrically insulated with 19mm thick plywood:
AC power side. Both PSUs connected in parallel through the power switch, all grounding completely removed:
DC output side. PSUs connected in series, output wires ending with EC5 connector:
It's important to keep the ends unobstructed for the cooling air flow.
Jerry
Old 03-07-2013, 07:20 PM   #3 (permalink)
Next, drilled some ventilation holes at the ends of the toolbox:
Used mosquito screen and hot glue to protect them on the outside:
On the AC side mounted a PC power supply socket:
Jerry
Old 03-07-2013, 07:31 PM   #4 (permalink)
The power switch on the deck connects to the socket on the side of the toolbox:
And the whole assembly drops into the toolbox. Please note the side handles, they are pull handles on HP PSs that I removed and installed on the sides of the deck for easy dropping-in and pulling out:
The door latches keep the deck locked in place and a couple of strategically placed bits provide for a snug fit for a PL6 charger:
Jerry
Old 03-07-2013, 07:35 PM   #5 (permalink)
Field testing yesterday:
Almost forgot: I needed another $600 bit from a local Home Depot
Jerry
Old 03-08-2013, 12:28 AM   #6 (permalink)
very nice Jerry
| Kraken 700 : Neo | Atom 6HV : Evo | Raw 580 : Neo | vbct |
ragge1 is online now        Reply With Quote Quick reply to this message
Old 03-08-2013, 04:05 AM   #7 (permalink)
Good work Jerry. Only as to be expected from you. What can you achieve with that then. Keep yourself flying at the club all day?
Cheers
Sutty
Regards, Sutty
Old 03-08-2013, 07:07 AM   #8 (permalink)
Top notch Simple but extremely effective
Helis: Belt-CP, Mini Titan, EXI 450, HK250-GT, HK500-GT, HK600-GT, mSR (all modified/customised). Quads: Q4, nQX, HK250, Custom built 560 Deadcat camera platform. Some planks. DX6i & DX9. And a boat & some HK surface controller thingy.
CyprusDave is offline        Reply With Quote Quick reply to this message
Old 03-08-2013, 08:23 AM   #9 (permalink)
Thanks, guys. I have big packs for the hexa and 6HV, and up until now every time I was flying more than 2 flights I had to wait for the packs to charge. With this station I will be able to charge 2 flight packs in parallel @2C and even 3C, meaning almost no waiting time
Jerry
Old 03-08-2013, 08:34 AM   #10 (permalink)
Nice build Jerry! Inspiration to get mine finished ready for summer!
COPTERBOY DX6i, mSR (SOLD), BeltCP (SOLD), mCPx w solid boom and Rakon Heli Head
T-Rex450V2 w.PRO head, Scorp-8 & 45A V2 ESC, CSM4200/S9257, 3xHS65MG
E-Flite CX2 - All Microheli/Extreme CNC CF Upgrades
TRex600N, Kasama Head, OS50SX
copterboy is offline        Reply With Quote Quick reply to this message
Old 03-08-2013, 04:14 PM   #11 (permalink)
Fantastic Jerry ! This is the stuff that makes me drool, but you guessed that already.
I just remember that I still have a few used 2000 Watt 12 Volt server PSU's, bought them extremely cheap a year ago or so, but they are still in the box. Waiting for a charger that would use that kind of power, and I'd need stronger circuits in the house...
Logo 800 - TDR 14S - TDR 12S - Logo 500SE - Logo 400 - Furion 450 6S mini-V - 300X - 150S - mCPX - Schluter Bell Huey Cobra '74 - Aura 4 hotliner - F27D Evo
redbird300 is offline        Reply With Quote Quick reply to this message
Old 03-08-2013, 05:06 PM   #12 (permalink)
Nice kit....but wouldn't it be cheaper to buy more batteries?
....I'll get my coat.....
450 Bell 222, 450 Jet Ranger, HBFP Redbee Extreme, 500 size Blackhawk MH-60, 600 EP Spitfire, Sebart 342 30e, Davy Systems Flybaby, ST Models FW190, Micro SU26 & GWS P38. DX7s
Luke Warmwater is offline        Reply With Quote Quick reply to this message
Old 03-08-2013, 06:01 PM   #13 (permalink)
@Raf: haven't told the whole story, these PSUs give me an even 1000W @ 25.2V (25.2V*40A=1008W), as by default they generate 12.6V (adjustable from about 11.5V to 12.8V by external pot, but for 12.6V I didn't have to do a thing ). Perfect match for 1000W 40A PL6, and only very slightly underpowered for 1344W 50A PL8 (they would produce just under 1200W). Also, they have automatic power factor compensation, meaning VA=W, so no problem with running low loads or running from the generator. All for $50 a pair!!!
@Luke: +1000 Actually I'm beginning to believe it would have been much cheaper not to have done any of this, beginning with getting to know you guys, and especially Tom who sets a morally and financially destructive example
Jerry
Old 03-09-2013, 02:02 AM   #14 (permalink)
Hehe.....my tongue was firmly in my cheeky Jerry. I know that buying batteries would solve the "problem", but you wouldn't have "done anything".
There's a guy on the HBFP forum, who is spending loads of time and money converting a 450 CP into a fixed pitch....because he can.
Old 03-09-2013, 05:21 AM   #15 (permalink)
Plus there is another aspect to it: battery life. My standard procedure is to fully charge all my Lipos upon returning from the day of flying and store them in the sealed plastic containers in the fridge. That way when I decide to run out to the field I just grab a couple of containers appropriate to the birds I'm taking and I'm all set.
But there is this controversy about storing Lipos fully charged. I did some reading on it and it's still not totally clear, I feel like being back in my old country: whenever you put a 3 Polish guys together to discuss a subject you'll get minimum 4 different opinions
My latest opinion is that storing in the fridge definitely helps, as it slows all the chemical processes down, but I'm probably still having some deterioration of the packs due to storing them fully charged, albeit slower. Recently noticed that some 3s packs for a 300 felt a bit underpowered after a year of non-use. So with this charging station I'll be able to change my routine: store the batteries at storage level, then run to the field and quickly charge them there before flying. Well, I'll probably start doing it for large (and expensive) packs only . And possibly store them at 4.1V rather than 3.8-3.85V, read somewhere that most deterioration to the pack in storage is above 4.1V level.
Jerry
Old 03-11-2013, 03:16 PM   #16 (permalink)
I knew I still had a picture of them somewehere, they would make a nice 36 Volts PSU.
Old 03-11-2013, 03:47 PM   #17 (permalink)
Can't see the specs due to the low pic resolution, what are they?
Jerry
Old 03-11-2013, 04:18 PM   #18 (permalink)
12.2V/164A each.
Old 03-11-2013, 05:20 PM   #19 (permalink)
Wow, you'll need a wheeled 10HP engined generator for 3 of these
Jerry
