Jeti Duplex Radio Systems Jeti Duplex Radio Systems Support |
06-18-2013, 11:21 AM | #1 (permalink) |
Mezon 120 Lite BEC or WR BEC for G500?
Next question:
Is the Mezon BEC sufficient for Goblin 500? (Hitec 7245MH cyclic - Savox 2272MG tail) Currently running a WR mini @ 7.4v. Likely going to run Mini Vbar Governor so no room for extra wires.
CN#139 GOBLIN 500- HeliJive 120, Pyro 600-12, BK Servo GOBLIN BLACK NITRO YS 96 SRX Tareq, Torq, BK |
06-18-2013, 11:30 AM | #2 (permalink) |
With servos that have a relatively low current draw I'd personally be comfortable with it. One way to find out!
Team - "Self Interests" - Flying what I want to, simply because I enjoy it! |
06-18-2013, 04:43 PM | #3 (permalink) |
If I ever get my DS-16 I will be using the 120 Lite BEC in my G500. I am very confident that it will provide ample power to the servos and RX.
SAB Goblin 500 SAB Goblin 700 Jeti DS-16 |
06-20-2013, 08:45 PM | #4 (permalink) | |
Lou
Vector 550 Quad/Octo Multirotors DJI WooKong Multirotor Controllers Twin Bergen 44 Magnum Turbines - KERO Start FBL www.circlecityhelis.com |
06-20-2013, 08:48 PM | #5 (permalink) |
The Mezon can still be used with an external gov in fast response mode. The only difference is you have to use an aftermarket phase/rpm sensor. The built in one just makes it simpler but the traditional method still works.
07-16-2013, 08:32 PM | #6 (permalink) |
i am thinking of using the rjx servos in my goby 500 \
will the bec in the 120 lite be strong enough? also in my other goby 500 i have a 90 lite and its running pretty warm..will the 120 lite run cooler or the same? |
07-16-2013, 08:38 PM | #7 (permalink) | |
The 120 should have taller cooling fins. Double check the specs to be sure. Either way, Goblins have very poor ventilation. Full size Mezons are better suited for Goblins IMHO.
07-16-2013, 11:57 PM | #8 (permalink) |
Logging shows a max Amp spike for the Mezon 120 BEC of 2.1A running Align DS515 on cyclic and BLS251 on the tail, all at 6V. Plenty happy with that.
07-17-2013, 07:10 PM | #9 (permalink) |
Bout the same on mine, Hyperion DH16s and a HBL980 @ 8V. The G500 does not really need huge current on servos, specially those at 8V.
-DX8 -MSH MiniProtos Stretched, SK720, DS95/DS95i, Hyp 4S 25C 2500mAh -MSH Protos Stretched, Brain, Hyp DS16/BLS251, 6S 3000mAh -Goblin 500, HC3SX, Hyp DH16/MKS980BL, Scorp 4015-1100 |
07-18-2013, 04:21 PM | #11 (permalink) |
Using the lite. As per my PM to you, temps haven't got above 46 C. This is using a 4020-1390 and 16T pinion at 2700 RPM. PWM seems to be in the 90s most of the time.
07-18-2013, 05:25 PM | #12 (permalink) | |
The Mezon lite and "normal" Mezon are exactly the same as far as the electronics. The only difference between them, beside the size, is the "wrapping" the lite not having a hard shell but a heat shrink and having a smaller heat sink not in its size but in its usable surface for heat dissipation because of the shrink wrap covering part of it. The lite has no RPM lead.
TDSF, TDR-II, Triabolo, 2 X TDR, Logo 700,Protos evoluzione, T-Rex 700Dominator, Drake & Raw, SpiritRS, Jeti DC-24,HW,Kosmik,Jive Pro EF MXS 3W110, Ultimate Aeroworks 20-300, DA 170, PowerBox Mercury, Q80-8M in a 91" EF Extra and MXS 104+ few jets |
07-18-2013, 05:29 PM | #13 (permalink) |
The Lite also has a weaker BEC at 8A.
07-18-2013, 05:39 PM | #14 (permalink) |
07-18-2013, 06:56 PM | #15 (permalink) |
It's a killer ESC though, I love both my 120 Lite and 130HV on my Goblins, they really work very well.
I really hope there will be a physically smaller line again, with telemetry, that I can use on 450 size helis.
07-19-2013, 09:05 PM | #16 (permalink) |
so heres the big question
with running on 6s and the same load.. will the 120 lite run cooler then the 90 lite in the same application? I would assume so but if the heat sink is similar between the 2 maybe not? |
07-19-2013, 09:10 PM | #17 (permalink) |
No tellin till you try it as these are all faitky new to the market. The 90 is rated for 12S. The 120 is not. The 120 has larger cooling fins....
07-19-2013, 10:28 PM | #18 (permalink) |
I am seeing spikes of 139A on my G500 but average draw under 50A. I don't think there'd be a significant difference in temps between the two. No 90A plus ESC should have temp issues if your correctly geared. When I was overgeared (18T, 1390kv, 2600RPM) my Koby would come down hotter than my Scorpion. As soon as I changed to the 16T it was only slightly warm.
