Old 04-11-2015, 11:39 AM   #1 (permalink)
Default 300x slow servos
Ok just installed a micro beastx on a 300x. Did all the programing according to blade manual. Problem is servos really slow go into position and correct direction just very slow when swash returning to level. Is like they are in slow motion using dsm2 reciever. Beastx set on standard reciever. Tail servo seems fine moves fast but swashplate servos dont. Any suggestions has cause two mishaps already. Thanks
Jim
hoguej115 is offline        Reply With Quote Quick reply to this message
Old 04-11-2015, 11:48 AM   #2 (permalink)
Jim
Theyr'e always slow on bench
vronny is offline        Reply With Quote Quick reply to this message
Old 04-11-2015, 11:55 AM   #3 (permalink)
What do u mean they are always slow on the bench. Problem is I got into short hover heli started to drift forward barley touched the stick to back it up and it barried the talirotor into the ground never got a chance to recover went so fast. I have a 450 and 500 3d that I fly and a 130x non do what this is doing.
Old 04-11-2015, 12:04 PM   #4 (permalink)
This comment makes me think your Gyro compensation direction is incorrect; when you tilt the heli forward, the swash should tilt aft, and vice versa. Tilt left, swash should go right, and vice versa. If you barely touch aft stick and it buried itself, it is likely that this compensation is backwards and is adding to your input. Check it.
Slow servos... Yes, they will be slow on the bench, and this is entirely dependant upon your setup. If you are using one of the pre-programmed modes (Normal, Sport, etc), then the swash won't move quickly on the bench. If you are using Transmitter mode and rates/endpoints greater than 100%, then you can have a much more lively swash on the bench (and in the air).
Check your compensations, and let us know what Beastx mode you're flying in
180CFX, Trex 550E (night), Goblin 570, Goblin 630C, DX8
Skidpad is offline        Reply With Quote Quick reply to this message
Old 04-11-2015, 04:14 PM   #5 (permalink)
Ok went through the whole set up and changed the configuration from what the Blade 300x manual had finally got a good stable hover test so not sure why the micro beastx is different from the beastx but that one setting but it was so am glad it did work. Thanks for the inputs.
