Old 05-06-2015, 05:23 AM   #21 (permalink)
Yep the g380 is built to be punished but I'm sure it will hurt the back pocket when I put it in.
waxman is offline        Reply With Quote Quick reply to this message
Old 05-06-2015, 07:25 PM   #22 (permalink)
Sure will.. mate had his ESC give doing an inverted low smack.. bent head/plate all that great stuff... $140 later...
still he hammers on it, and it takes it.. I fear that unless one of those updates to the power train (which looks like to be happening to the MAX) people will start moving away..
which means cheap parts for me!
Manyc is offline        Reply With Quote Quick reply to this message
Old 05-07-2015, 06:23 AM   #23 (permalink)
I beat on my g380 probably a little to low at times so I'm sure I will find out soon enough. Blades, boom and canopy and your already up to $200 in Australia. Then you start adding all of the little $5 to $20 parts. But at the end of the day it's a 2.5k heli, so if you estimate a crash will cost between 10 to 20% of the total cost of most helis the g380 is always going to be an expensive 450.
Old 05-07-2015, 10:20 AM   #24 (permalink)
Essential? A solid pinion, either warp or lynx, depending on the motor you want to run. I like the Lynx tail box, because it's butter smooth. With that said, my stock one ran fine, I just had to spend some time smoothing things out and fitting parts to get it as smooth as I like. The lynx tail case took no fiddling.
I've had aluminum pulleys and bearing blocks since I bought it, but I don't think essential is the right word for those.
Stretch kit on the other hand...flies SO much better than 325s. I couldn't go back
Old 05-16-2015, 04:24 PM   #25 (permalink)
I only upgrade the Lynx Pinion, 3rd bearing support and the upper bearing block. I've found that if you have a bad crash, the stock plastic bearing blocks can break and in the process crack the CF frames.
B450x, Chase360, Warp360, mini Protos stretched, Protos 500 stretched, NX4 gasser, Goblin 500 x 2, Century E640 stretched, MD7 and MD8.
distructor is offline        Reply With Quote Quick reply to this message
Old 05-17-2015, 02:21 PM   #26 (permalink)
You could replace the pinion belt tensioner when the stock one eventually melts, like mine just has
http://www.msh-direct.com/products/m...tensioner.html
or you could do it before the stock version fails, saving you a crash
Blade 180CFX | 300X
MSH Mini-Protos 3S, Spirit FBL
Parkmaster 3D, Funjet, Sbach 3D, FrSky Taranis, FPV260 Quad, Pheonix Sim
stevebaker is offline        Reply With Quote Quick reply to this message
Old 05-17-2015, 05:31 PM   #27 (permalink)
or you could do it before the stock version fails, saving you a crash [emoji38]
I lucked out last year, my tensioner melted 15 ft up and I managed to auto it down to safety.
Team Lynx Heli Field Rep
XL Protos 380
Jomaba4308 is offline        Reply With Quote Quick reply to this message
Old 05-18-2015, 02:48 AM   #28 (permalink)
I tried to auto but landed in a bush! no damage though
I'm now wondering what else is on the verge of failing - wondering whether or not to change the motor pinion holder
Blade 180CFX | 300X
Old 05-18-2015, 05:47 AM   #29 (permalink)
I upgraded that part at the same time I swapped out the tensioner.
XL Protos 380
Old 05-18-2015, 08:25 AM   #30 (permalink)
What do you mean it melts?
Alex
Fleet: Miniprotos
Flock: cockatiel and congo african grey
dedados is offline        Reply With Quote Quick reply to this message
Old 05-18-2015, 09:05 AM   #31 (permalink)
The plastic melted, it got hot & soft and the belt tension pushed the pulley out sideways.
XL Protos 380
Old 05-18-2015, 09:46 AM   #32 (permalink)
The bearing inside the idler pulley freezes up, so the metal pin spins inside the plastic part melts its way out due to friction.
And you lose all power since you no longer have any belt tension on the motor.
Happened to me once, luckily I managed to auto it down more or less and had no damage apart from that.
"Beater" Mini Prôtos stretch 6S : Scorpion 2520-1360kv, Edge 353SE
"Princess" Goblin 570 stretch 12S : Xnova 4025-560kv, Cyclone 615
FrSky Taranis - Heli-X 5 - MKS, YGE, SK540 - Yamaha XJ6F
Aryemis is offline        Reply With Quote Quick reply to this message
Old 05-25-2015, 09:40 PM   #33 (permalink)
I have had 3 dozen flights on the upgraded 16t steel pinion with the stock 6s motor and it has been holding well and hasn't been locked up when checked at the end of flight. Let's see how long it lasts
Old 05-25-2015, 11:33 PM   #34 (permalink)
If it lasts more than one before locking, you're lucky. But it won't let go. It will just stay locked forever
Old 05-26-2015, 03:13 AM   #35 (permalink)
Mine failed today, upgrade time. So the cnc is all that is required to become reliable?
Old 05-26-2015, 12:43 PM   #36 (permalink)
I bet it's because of overheating.
Mine (the last 16T version) was fine for many flights now, but I'm flying at 2100. However, I just checked it again - turns out, last time I flew it locked pretty lightly, I was able to unlock it without much effort.
It locks almost every time I run it at the bench, though - no air cooling is present, the heat builds up.
In case it matters - I'm using Trinity Royal oil on it.
DX6i, Jeti DS-16
MCPX BL, Mini Protos 6S, Stingray 500, SG704, SG381, OMP M2 V2
Brain, SK 720, Spirit Pro, Brain2; HW, Kosmik
Heli-X, AccuRC, RF 7.5 Transmitter Interface Edition
madeye is offline        Reply With Quote Quick reply to this message
Old 05-26-2015, 01:18 PM   #37 (permalink)
Are you talking pinions? I've owned 3 of the new pinions. The first two I flew at 1900(3s pack on a 6s motor) and it was locked when I landed the first flight.
The other locked at 4000 rpm on a 6s pack. I won't be blowing that kind of money on another one
Old 05-26-2015, 01:24 PM   #38 (permalink)
Yep.
QC inconsistency, I'd say.
Thinking of it for a second, I wonder what kind of QC these particular parts are getting, or if they're even getting any.
If they fail that predictably, then the QC procedure should be extremely simple - make a jig with a spindle the same diameter as the motor, put it on, run it for 4 minutes, make sure it reaches the expected flight temperature, and make damn sure every one of those that are put into plastic bags and delivered to customers are *not* locking up.
Can't be that expensive to do it, can it?
DX6i, Jeti DS-16
Old 05-26-2015, 05:37 PM   #39 (permalink)
That's OK I just ordered the linx pully and bracket, and got a full set of pinions as well. In all honesty I didn't feel the 16t pinion on the stock 6s motor felt as good as the 15 and it reduced my flight times even at the same headspeed.
It still blows me away how good this heli is, I'm thinking of swapping all of the quality gear in my warp over to this heli as I like flying it more. So swap over to mks ds95/95i and msh brain, and the warp can have the 215s and kbar.
Old 05-26-2015, 05:45 PM   #40 (permalink)
And I'm thinking of retiring the Brain. Not that I don't like flying it, but now that I'm getting into more advanced stuff, I could use some bailout. Last crash (caught sun glare at the far end of inverted rainbow) cost me more than Spirit FBL costs retail.
Still can't decide whether I'll go for Spirit or BD. Anyone's got first hand experience with both? How do they compare?
DX6i, Jeti DS-16
