Mikado Logo Helicopters Mikado Logo Helicopters Discussion |
06-19-2011, 05:48 PM | #41 (permalink) | |
Killer Kane Kustoms airbrushing RC Helicopters="One is too many, and 100 is never enough!" ディーゼル発電 Last edited by Diesel; 06-19-2011 at 11:51 PM.. |
06-20-2011, 12:06 AM | #43 (permalink) |
After I disassembled the tail case to epoxy the bearings in I started fiddling around and found something interesting. I have read in the different forums that the Mikado belt guide on the tail is sufficient to keep the belt in place. Buuuut I got looking around in my shop and wouldn't you know it, the Protos 500 belt guides are an exact fit for the tail hub. I mean, you gotta get rid of the outer flange on the guides but other than that they are perfect for the job. Check it out:
Here we have the slightly modified belt guide off the protos-the bearing below it is the original bearing from the Mikado belt guide: Now check this out. here is the original bearing supplied by Mikado for the belt guide: Now it gets even crazier. Here is the hub measurement: Now check this out. Here is the Protos guide measurement CRAZY RIGHT?!?! Now after all that I still dont have the balls to install it. I mean, it would work awesome! Anyways,this is something I do to all my helis. I scribe marks on the tail boom so I can have a quick reference to make sure there hasn't been any movement that would cause belt slop. Just for peace of mind. Oh, and I learned a long time ago that the vertical fin isn't always the best reference to make sure your tail shaft is 90 degrees to the main shaft. Instead I use a square and make sure the tail blades are parallel to the main shaft=works great! Man, I better get to bed! Later fellas!
Killer Kane Kustoms airbrushing RC Helicopters="One is too many, and 100 is never enough!" ディーゼル発電 Last edited by Diesel; 06-21-2011 at 10:17 AM.. |
06-20-2011, 09:40 AM | #45 (permalink) | |
Aaa bwahahahahaa!I nearly busted my gut when I read that
Down boy, down!! keeping the beast at bay huh?! Ha ha. Thats awesome! Quote:
Spec wise it would work perfect, but I have always been a chicken to add hardware that ive made to a heli. I think i'll put it in tonight and snap some pics of the mod. I dub thee-the "Diesel mod" ha ha haa!
Killer Kane Kustoms airbrushing RC Helicopters="One is too many, and 100 is never enough!" ディーゼル発電 |
06-20-2011, 09:56 AM | #46 (permalink) |
flight report ?
Synergy e7, Vbar, HeliJive 120, Hacker 12L, JR 8917 HV, BLS251 Logo 400, Vbar, Jive 60+lv, S9650, BLS251, Pyro 600-09 TRex 450 Sport, MiniVbar, 5065MG, DS420, 450MX |
06-20-2011, 10:11 AM | #47 (permalink) |
I WISH!! After all the money I sunk in this beast I forgot to get the EC5 connectors for the esc!! DOH!! My LHS is aweful too. I told them to order a load of the EC5 connectors and I would buy them all. They ordered one set!! Then they marked it up 5 bucks! I gave up on them and ordered it from ReadyHeli yesterday. Im glad I did too, cause the black 700E Align soft carry cases were back in stock-FINALLY! Got my sticky paws on one of them finally .
Im worse than my wife-I get on the web to order a 7 dollar part and always end up getting $100+ worth of goodies. Darn Readyheli and their "spend $100 and get free shipping" !! Should be doing a maiden this next weekend-work willing!
Killer Kane Kustoms airbrushing RC Helicopters="One is too many, and 100 is never enough!" ディーゼル発電 Last edited by Diesel; 06-20-2011 at 11:24 AM.. |
06-20-2011, 11:10 AM | #48 (permalink) |
Yeah, I also try and support the lhs but 99% of the time its just easier to order it online...as they normally have to order it themselves anyways....sales tax on big ticket items is also hard to swallow.
06-20-2011, 06:33 PM | #49 (permalink) |
For those that find this info useless than you can stop reading now. For the rest of us that like jacking around with mods on our helis keep reading
Alright fellas. Ive done a TON of fiddling around with my belt guide mod and have come to a conclusion. Unless you have parts lying around from a Protos and an EFlite CP Pro than there is probably an easier alternative out there. But man is this solid and there is NO way in hell the belt will hop the tracks with this!!! For those that are familiar with the Protos guide pulleys they will know that in its original application it takes on A-LOT more pressure/speed than in this application. I feel confident they will do just fine. So, for those that are interested here is what I did: Needed materials: Axial 2x6mm spacers=you will need 2 packs of them (total=12) E Flite EFLH1183 or the entire blade grip assembly EFLH1171=the problem is, is that all you need are the 4 step/cone washers out of these kits. E Flite EFLH1144 =head dampening shims for fine tuning the position of the guide MSH Protos part#MSH51034 Now the reason for most of this BS is just to get the guide centered and keep the bearings from thrusting when you crank down on the bolt. My initial test was a failure. I got the guide centered but when I tightened down the bolt and nut it thrust the bearings in the plastic guide housing together. Sooo I chucked those in the trash and started over. The issue is the space/void in the plastic housing between the bearings. When tightened down it will thrust the inner race of the bearing causing binding. So what I did to curb this is use 2 of the step/cone washers with the step facing the bearing and inserted a .055mm washer from my Protos belt guide kit in between the step washers. More importantly you need about a .050mm washer in between the bearings. Then you use the other 2 step washers on the outside of the Protos modified belt guide. This is all sandwiched between a slew of Axial spacers,Protos 0.60mm belt guide washers,and the E Flite head dampening shims (used to get the guide EXACTLY centered on the tail hub). In hind sight I would say this probably seems to reek of OCD. I can already see many of you shaking your heads right now . Ha ha. I cant help it, its just the way I am ANyways here are the pics-hope ANY of this is making sense. The Axial spacers: This is the Protos guide spacer that comes with the guide pulley kit #MSH51034 With all the spacers,guide, etc. this is the space I am trying to fill Here is the E Flite head dampening shim Here I am greasing the bearings that will go into the guide plastic housing Here is the step washer that comes with the E Flite grip assembly,this ensures that there will ONLY be pressure on the inner race and not the shield of the bearing Here is what is sandwiched in between the 2 bearings of the plastic guide housing. 2 step washers facing outward and a 0.55mm washer in between them. If you can round up a 0.50 spacer that would be even better! First I cleaned one of the bearings and used a small dab of CA on the outer race to lock it to the guide housing making sure none of the ca got into the bearing. Then I installed the step washer (step facing outward),followed by the 0.55 spacer and the other step washer (also facing outward). Then I cleaned the other bearing and swiped a dab of CA on it and sandwiched it all together. This is the finished product: Here I tested it by putting the stank on the nut and bolt and making sure there was no binding on the bearings. Smooth as butta!! Here it is installed and tested: Safe to say,there will be NO belt jumping on my machine The other thing I like about this mod is that there is almost no force on the bearing/guide. Less drag on the power train and less wear on the belt.
Killer Kane Kustoms airbrushing RC Helicopters="One is too many, and 100 is never enough!" ディーゼル発電 Last edited by Diesel; 06-21-2011 at 10:09 AM.. |
06-20-2011, 06:41 PM | #50 (permalink) |
a couple of us use this and it works well too.
06-20-2011, 06:59 PM | #51 (permalink) |
Ahh yes. This was the original fix before the Mikado belt guide came about isnt it? Very nice, and a lot easier than my mod! I had contemplated using this mod, but it was just too easy. Ha haa.
06-20-2011, 11:22 PM | #52 (permalink) |
O.k., I dug up one set of male EC5 connectors and 2 sets of female connectors. Soldering 8 gauge wire aint no joke!! All I need is one more male connector and then I will program it. Soon---very soon
Oh, I messed with the static wire a bit more and was able to get 0.3 ohms. Almost there-I can taste the voltage already Mounted the batteries in the frame to check the clearances and my straps. Man, talk about a tight fit!! 2 22.2v 5000mah batteries will fit though.
06-21-2011, 08:58 AM | #54 (permalink) |
Looks good Diesel Do you get continuity with that plastic bushing around the tail idler bearing? Looks like the perfect size...may have to pick one of those up. I have been running mine with two of the stock size idler bearings in the front hole. Also instead of having to use electrical tape to hold the ground wire across the frame you can sneak it behind the aileron servo and run it back across the rx tray and right down to the boom pin screw. This way you dont have to worry about the tape ever coming off and the wire getting into your main gear.
Your going to be amazed at how much quieter and graceful the 600SE is than the 700. Its a thing of beauty
06-21-2011, 09:48 AM | #55 (permalink) | |
Yea-no doubt!! Im thinking of investing in some lighter packs soon.Any recommendations???
06-21-2011, 05:29 PM | #57 (permalink) | |||
Sorry, I've been in radio silence mode here because I've been having problems posting here. I just figured out that HeliFreak is kind of down (it won't respond) every day around 11:00 pm PDT! Anyway...
BTW, I'd love to try the 4530 in the 600SE, but at 540kv I'd have to keep the throttle % too low in a 12S config. Quote:
Anyway, if you're getting packs just for this bird, then I'd say most people are flying with 4000 to 4500 mAh packs to keep the bird light. As torro mentioned, he uses 4500 -- but in a 10S config. "Light flies right." I use Hyperion EX (45/90C) 4200 mAh and TP G4 (45/90C) 4400 mAh packs on the 12S 600SE. The TP G6s weren't out yet when I got the G4s. I use Hyperion EX 4200 and TP G4 5000 mAh on the 10S (low-headspeed) 600SE. |
06-21-2011, 06:02 PM | #58 (permalink) |
Diesel, you probably already caught this but on your pics you posted your elevator servo was not secured in with the top two screws. Wouldn't want to hear about a bad maiden especially after all the time you've been waiting for those EC5s.
Mikado Model Helicopters Edge Blades |
06-21-2011, 10:31 PM | #59 (permalink) | |
Now for MR Electric sheep. First, how in the heck did you get your hands on a TDR?!?! Thats not easy to come by in the state. Believe me-ive looked. That is too cool about the motor heat sink!! Thanks a ton for the battery suggestions. I do believe I will fall in love with this bird enough to justify its own batteries. Um yea, most definitely Oh, did you ever get that tilt-a-whirl heli stand?? Now for an embarrassing moment. Keep in mind that I have never messed with the V Bar governor and for some reason beyond my recollection I did not see the MrMel video about how to set up for the V Bar governor. Sooo I was watching them tonight and then a little light bulb went on-I never ordered the hyperion phase sensor!! Double DOH!!! So I ordered one just as fast as my mouse could click from readyheli. I am a TOTAL newb when it comes to the V Bar and I just got my feet wet with the mini V in my 700E. Bear with me fellas,i'm getting there.
06-22-2011, 12:30 AM | #60 (permalink) |
We are at about the same stage of building. I will be doing the maiden on my 600SE in a couple of days
Full size vbar pro with homespun Bluetooth unit Pyro 700-45 with counter bearing Spectrum telemetry using DX8 - have this on my trex 450 and it is GREAT JIVE 120 HV ESC BLS 451 cyclic servos BLS 251 tail servo Scott Gray Reactor 2X power bus 12S Just finished wiring up some packs and getting a few charge/discharge cycles through them now Looking forward to your posts and maiden flight report |
