Go Back   HeliFreak > R/C Helicopters > 3D Printing
3D Printing Discuss 3D printed items and 3D printers as they relate to RC
Old 12-06-2012, 08:45 PM   #1 (permalink)
Default How many people 3D print stuff for their helis?
Like the title says, how many people 3D print stuff for their helis? The reason I ask is I just bought a 3D printer and hope to make some helis
Cheers
jolyboy is offline        Reply With Quote Quick reply to this message
Old 12-06-2012, 09:31 PM   #2 (permalink)
Sounds interesting... What printer did you get? A friend of mine in the dental lab biz has one... I would love to play with it some time...
badfrog is offline        Reply With Quote Quick reply to this message
Old 01-22-2013, 12:24 AM   #3 (permalink)
What kind of material can these printers cut?
tbird187 is offline        Reply With Quote Quick reply to this message
Old 01-23-2013, 08:57 PM   #4 (permalink)
Hey sorry for the late reply. I got an Ultimaker - here is the DD tail I made for my 450 with it:
And the 3D printer software with the layers ready to print:
tbird - It doesnt "cut" material, thats what CNC routers do. 3D printers like mine deposit hot plastic layer by layer. It can do most thermoplastics, but PLA and ABS are the most common. Commercial 3D printers can print metals like titanium
Old 01-23-2013, 09:50 PM   #5 (permalink)
Looks good.
How is the strength compared to molded parts?
fastflyer20 is offline        Reply With Quote Quick reply to this message
Old 01-24-2013, 12:24 AM   #6 (permalink)
I'd say about 80% of the strength, I always try to over-engineer my parts a little. Its excellent for parts like brackets and mounts, but bad to use it for mechanical parts like rotor parts etc. That said I regularly hear of people 3D printing main gears with success.
Old 01-27-2013, 03:26 PM   #7 (permalink)
Count me as one! I have a Titan from stratasys and print 100% of my designs before making any chips or waterjetting any CF.
Flynz4me is offline        Reply With Quote Quick reply to this message
Old 02-03-2013, 07:41 PM   #8 (permalink)
Hey, that is a very nice part. I am surprised at the quality.
What software are you using?
eRaptor is offline        Reply With Quote Quick reply to this message
Old 02-04-2013, 02:39 PM   #9 (permalink)
Thanks I use cura because It combines all the steps into one package
Old 02-04-2013, 03:18 PM   #10 (permalink)
Joliboy,
What is the ballpark cost to get set up to print parts?
Old 02-04-2013, 06:11 PM   #11 (permalink)
Jolyboy,
Thanks for the reply. Does Cura allow you to create the 3D model in the first place, or do you use another software to generate the model and the STL files?
Old 02-04-2013, 06:44 PM   #12 (permalink)
No, cura slices the 3d model for the printer. Use software like sketchup to make your model , and send it across to cura for printing
Old 02-16-2013, 04:37 PM   #13 (permalink)
I have access to a dimension 3d printer at my university and have ben brainstorming a few ideas of some things i wouldn't mind printing. It has the ability to print 8x8x12 i believe. If anyone has any ideas let me know.
-Stephen
Nano CPX, Align 250 SE, Tarot 450 V2 FBL, Specktrum DX6i
eder0022 is offline        Reply With Quote Quick reply to this message
Old 03-03-2013, 11:31 PM   #14 (permalink)
so far the only thing i've printed are stab's and fin's, although, i built a 3axis table from solid extruded aluminium, and made it so i could put different "heads" or "tools" on it, most of the time, i have a 3/4 hp porter cable router on it for cutting small aluminum stuff and CF, i have succesfully copied my frame sides tho, i cut them out of 2.0mm CF sheet from http://dragonplate.com/ecart/product...ID=3768&cID=71 not cost effective, but was more for a proof of concept, i have taken several hard, really hard hits, and have only one stress crack and its on a corner and not a hole, overall that stuff is way harder than stock and better for my "learning curve" lol
jdfelosi is offline        Reply With Quote Quick reply to this message
Old 03-03-2013, 11:35 PM   #15 (permalink)
Originally Posted by badfrog View Post
Joliboy,
cheapest i've seen a "decent" 3dprinter put together for was around $300 USD, i would upgrade a few things and spend around $375ish and have a way better machine that your not gonna have to "tweak" for a month just to get it to print a cup or something, stick with widely used electronics and the frame doesn't matter a whole lot, one key thing is don't skimp on the guide rods "shiny" and go with ballscrews or acme rod instead of plain threaded rod.
Google Prusa Mendel Max, you can change the y-axis setup on that type of build and use it for more than 3d printing, since the frame is so rigid, it has the ability to hold a small router or dremel type tool and do light cutting/milling.
Old 08-10-2015, 09:01 PM   #16 (permalink)
I have a few things i've made for my heli's, quad and planes
some of them I have posted to thingaverse.com and some I have not
4 x Rush 750/stretched V-bar KDE 700XF-495 HV servos Greys reactor CC 160-HV
Trex 600EFL V2 V-Bar ds610 ds650 CC bec/pro Scorpion 130a HV KDE 600XF-530
450L KDE 1750 cc50 4xDS215MG k-bar
X-8 FPV Wing, TBS Discovery FPV, TBS Caipirinha FPV
satgod is offline        Reply With Quote Quick reply to this message
Old 08-23-2015, 04:03 PM   #17 (permalink)
I've made brackets for mounting electronics, sats and antennas. For scratch built park-flier airplanes, I make a lot more.
B450x, Chase360, Warp360, mini Protos stretched, Protos 500 stretched, NX4 gasser, Goblin 500 x 2, Century E640 stretched, MD7 and MD8.
distructor is offline        Reply With Quote Quick reply to this message
Old 10-27-2015, 04:06 PM   #18 (permalink)
I used to run a Dimension machine and two Fortus 400 machines. We printed everything in ABS plastic. We used them to print the patterns for some of our cast parts. Cost A LOT less than having a pattern made by a pattern shop. Those machines could make completely usable parts. Strong enough to be used as blade grips on a 450 size or smaller heli. Wish I still had access to them.
Blade 300X, Blade 130X Red Bull Edition, Blade Inductrix, Quanum Nova CX-20
Assocracer is offline        Reply With Quote Quick reply to this message
Old 11-05-2015, 01:58 AM   #19 (permalink)
I've got a Prusa I3. Been printing some quad parts, but nothing for the helis yet. Currently building this: http://www.thingiverse.com/thing:629338
mCPX | 180 CFX | T-rex 450 se v2 | Phantom 2 + HD-3D | DX6i | TH9X/OpenTX
HSBallina is offline        Reply With Quote Quick reply to this message
Old 11-09-2015, 06:58 PM   #20 (permalink)
I've not printed anything major but find 3d printing useful for small things like tailrod guides, antenna guides, and other non-precision fittings.
