Go Back   HeliFreak > R/C Helicopter Support > Mikado Logo Helicopters > Mikado Logo 700 Xxtreme
Mikado Logo 700 Xxtreme Mikado Logo 700 Xxtreme Helicopters Discussion
Old 01-01-2013, 07:27 PM   #81 (permalink)
I honestly don't think it matters. If I can ever get my hands on some more a TDR comes with couple of pieces of a teflon-like heat shrink that is slick not grippy like regular heat shrink. It shrinks down super tight to the tail rotor pushrod and that part is what slides through the pushrod guides on a TDR. It would work perfect on a L500-L800 tail rotor push rod and maybe even the L400 I forget the tail rotor pushrod diameter on it.
That is what I need on mine. It works fine with two supports and there is no friction, but the TDR is like buuuuuutter!
Norman Ross Jr.
Norman Ross Jr.
Mikado USA -- Insane Canopy -- Scorpion Motors
futurase is offline        Reply With Quote Quick reply to this message
Old 01-01-2013, 10:21 PM   #82 (permalink)
I used that on my Logo 500. Thanks for reminding me - I'll add that to the 700 as well.
Mathias
Lynx Oxy 3 | JR XG14
Mathias is offline        Reply With Quote Quick reply to this message
Old 01-01-2013, 11:02 PM   #83 (permalink)
any idea what it is ? link ?
I'd like some also.
My 800 rod is partially sanded down and is a bit smaller in diameter after 60 flights
Martin
Logo XXtreme 800 8917 / 256HV VBC
rcmarty is offline        Reply With Quote Quick reply to this message
Old 01-01-2013, 11:30 PM   #84 (permalink)
Originally Posted by futurase View Post
.....a TDR comes with couple of pieces of a teflon-like heat shrink that is slick not grippy like regular heat shrink. It shrinks down super tight to the tail rotor pushrod and that part is what slides through the pushrod guides on a TDR. It would work perfect on a L500-L800 tail rotor push rod and maybe even the L400 I forget the tail rotor pushrod diameter on it.
Synergy helis come with something like that: http://www.fblrotors.com/Tail-Push-R...eve_p_158.html
panz is offline        Reply With Quote Quick reply to this message
Old 01-01-2013, 11:33 PM   #85 (permalink)
That looks like the stuff Panz posted...
Norman Ross Jr.
Old 01-02-2013, 04:05 AM   #86 (permalink)
Originally Posted by dahld View Post
FWIW, we never glued the TT bearings to the tube. Just taped the bearing and it's holder in in its proper place on the tube by wrapping tape on both sides, and then installing it in the tube.
Kyle flew A LOT of flights on his Logo 700's in 2012 (flew today as well), and never had an issue with the tube not being glued to the bearings.
It can't hurt of course, unless you get glue in the bearings...which is why we tried it without, and never looked back.
(-: Dave
Could use heatshrink either side of bearing?
stocksy27 is offline        Reply With Quote Quick reply to this message
Old 01-02-2013, 08:40 AM   #87 (permalink)
Yea, that's it. I got mine from ReadyHeli years back. Try searching for "teflon heat shrink tubing".
Mathias
Old 01-02-2013, 06:46 PM   #88 (permalink)
Originally Posted by taoY View Post
Please report back. I have a bag that fits TDR but too short for Logo700. Logo 700 is longer than TDR.
Got the bag today. Yup - today! It has taken forever to get it. Both FedEx and the national postal service took their time...
As I promised, here are some details. It does fit. Actually it fits perfect - maybe even a little too perfect, as the L700X filled the whole thing with no room to spare. If you decide to get one - let's just hope there's no big production tolerances. I don't believe so, though.
That being said, the quality is excellent - really top notch. The outer fabric seems very solid, while as the inner padding is pretty soft. Nice design too.
ID:	380014   Click image for larger version
ID:	380015   Click image for larger version
ID:	380016   Click image for larger version
ID:	380017   Click image for larger version
ID:	380019   Click image for larger version
Mathias
Old 01-02-2013, 07:00 PM   #89 (permalink)
Thanks, Mathias. Nice to know it fits.
HD750, TDR II, TDR, Logo 700, Logo 700 XXtreme, Logo 550SX V2
taoY is offline        Reply With Quote Quick reply to this message
Old 01-07-2013, 04:33 PM   #90 (permalink)
Cool like the bag indeed!!!
Old 01-20-2013, 05:30 PM   #91 (permalink)
Why does the manual show female bullet connectors for the motor side of the ESC motor connections? I assume this is an error and male bullets go on the motor side as usual?
rexxigpilot is offline        Reply With Quote Quick reply to this message
Old 01-20-2013, 06:01 PM   #92 (permalink)
I'm with you. The male side of the connectors traditionally go on the motor side. All ours are set-up that way. I guess it's and error, although since it ultimately doesn't matter, I guess it's not "technically" incorrect But certainly not the standard.
(-: Dave
dahld is offline        Reply With Quote Quick reply to this message
Old 01-21-2013, 07:25 AM   #93 (permalink)
Thanks Dave. I just wanted to make sure there was no reason Mikado showed it that way.
Old 01-26-2013, 08:59 AM   #94 (permalink)
Originally Posted by Mathias View Post
Yes, it should be 14mm. I have a 14mm swashplate leveler from Fast Lad Performance. I do also have the RDLohr 14mm swash leveler, but I really don't like the wobbly design of it, as you would have to be very precise when installing it. I do have the RC Logger 2 too. It has a 13m swashplate leveler, and I am wondering if it might work on the L700.
Hope that helps.
Originally Posted by taosgraveyard View Post
Ditto on the lohr leveler, could not get it to slough the same way twice... Tossed it I the junk bin. Bought the one from fast lad,
Really sorry you weren't happy with my tool. Once you install it and give it a turn to level it, then turn the main shaft and make sure it is level, manually level it if need be turning the main shaft to verify it is perfectly leveled. Once it is level, you can now use it to level your swash. I added the main shaft turning part to the instructions since I had a few people who were having a hard time getting repeatability. If that doesn't work out for you, please let me know and I'll take care of you.
I just used the 12 mm version on my new Rush and it worked great.
Rick
Helifreak, the place to be!
rdlohr is online now        Reply With Quote Quick reply to this message
Old 02-07-2013, 07:55 AM   #95 (permalink)
I have been using Rick's tools on all my 7 helis with perfect results and could not have been happier. Just follow the instructions and you are set to go.
_____________
abanihani is offline        Reply With Quote Quick reply to this message
Old 05-20-2013, 06:24 PM   #96 (permalink)
Rick
A while ago, Rick sent me a prototype for a new under swash leveling tool to try. Free of charge!
The new leveler features a clip-on piece, which makes the leveler a lot more rigid compared to the previous design. See attached pictures.
Thank you, Rick!
Best regards,
ID:	421842   Click image for larger version
ID:	421843   Click image for larger version
Mathias
Old 05-20-2013, 06:33 PM   #97 (permalink)
Thank you, Rick!
Best regards,
My pleasure. I strive to take care of my customers. I had fun toying with a different design.
People have been happy with the original design once they realize how it used so I haven't even advertised that one. Thanks for posting.
Rick
