Old 06-15-2008, 02:15 AM   #21 (permalink)
I have couple of questions hope you can help me out. Got my TP-610C today but still need input and output wires to try it. Have a 12v DC power supply. So, my questions are:
1) How long will it take to charge my 11.1v 2200mah 20c 3s1p LIPO? I should only use the maximum of 2.2a to charge it, right? What about charging my 2s 7.4v 1000mah 15c LIPO, charge it at 1c, right?
2) What is the difference between 100% and Fast Charge option?
3) "Li/A1 InitCharge Timeout" What it is and how minute I should set it to?
4) "Input Power Option" Should I just leave it at 12v?
5) When come to discharge, how much "a" I should use?
6) What happen if one of my LIPO only left 2.6v+- on each cell? I just plug it in and the charger will take care of it?
7) What should I do if each of my LIPO cell isn't even? some 3.3v, some 3.6v, some 3.5v? Just plug it in and the charger will do the rest?
Sorry, I know I have lots of question. I'm always lost when comes to gadget.
kianhon is offline        Reply With Quote Quick reply to this message
Old 06-15-2008, 08:52 AM   #22 (permalink)
Right, C = 2.20
C = 1.00
Fast charge will not balance your pack as much, saves 5 -15 mins depending on the pack.
Keep it to a minimum (5 minutes?). This part of the charge cycle is used to determine the state of the battery.
This is mostly used for charging off your car's battery (not recommended) so that you can still start your car at the end of the day and drive home. I set mine at 11 V.
Lipos should not normally be discharged through the charger ...this feature is most useful for nicad / nimhs. Maybe if you have a charged pack but can't fly for a week... using the max discharge rate should not be an issue for any lipo.
It will try, that's where the init charge time comes into play. You may have to retry the charge or increase the init charge time depending on the depth of discharge.
Yes, it will balance it at the end of the charge.
marchambault is offline        Reply With Quote Quick reply to this message
Old 06-15-2008, 06:09 PM   #23 (permalink)
Thank you very much for replying. It really helps a lot.
Old 06-15-2008, 08:35 PM   #24 (permalink)
One more thing, how much should I put for the Lipo/A 123 Dchg Option? This option means the maximum volt to be discharge from the charger?
How much "V" can I drain my Lipo everytime I fly? From what I heard, 3.0v should be the minimum "v" to b left on the Lipo, right? or needs higher?
Old 06-15-2008, 11:23 PM   #25 (permalink)
3.0V is the min per cell under load. Under no-load (or light load as in the case of discharging with the TP-610) your packs should be kept above 3.5V. But there really isn't any point of discharging that low. If you have a charged pack you want to store, might as well discharge it to 3.85V / cell.
Old 06-16-2008, 01:38 AM   #26 (permalink)
Ok thnx, got it now. Will not drain my Lipo down below 3.5v each cell every time I fly. Thnx for the help
Old 06-19-2008, 12:50 AM   #27 (permalink)
One of my Lipo 7.4v 850mah isn't charge to full capacity. When done charging, the charger indicates only 553mah. What's wrong? Lipo gone? Or charger setting incorrect? This problem didn't occur to other Lipo when I charge them.
Old 06-19-2008, 02:18 AM   #28 (permalink)
Oh wait, no. Another 2 of my Lipo did the same thing. 11.1v 2200mah isn't showing 2200mah after the charger charged it. The charger showed 1300mah..What happen? It wasn't like that before, I didn;t change anything on the charger since.
Old 06-19-2008, 09:08 AM   #29 (permalink)
what is your pack voltage at the beginning and end of the charge cycle? Was the charge termination normal or did you get an error message (F-CG). How long was the pack charging for?
Old 06-19-2008, 03:31 PM   #30 (permalink)
It only charged for about 30mins (usually take an hr to complete), no error message. The charging Voltage for 11.1v 2200mah was 11.53v. Is it because I did not drain too much of the Lipo?, I alwiz left 3.7v+- for each cell after a flight. Since I did not drain too much so it only charge whatever capacity had been used?
Old 06-19-2008, 10:16 PM   #31 (permalink)
Was 11.53V at the beginning or end of the charge cycle? The charge cycle should finish with the battery at 12.62 volts.
Old 07-03-2008, 04:22 AM   #32 (permalink)
What should I do if it don't? My 7.4v 850mah 12c Lipo have the same problem, all three of them isn;t charge to 850mah. The ending charge "V" is 8.4v
Old 07-03-2008, 09:14 AM   #33 (permalink)
8.4V is a fully charged 2 cell lipo. It's normal not to put back the full capacity (850 mah) back into the cell.... ideally, you would put back in max 80% of the capacity... so it looks like you're doing a good job of not over-discharging your lipos.
Old 07-03-2008, 01:03 PM   #34 (permalink)
So I guess that is why my 11.1v 2200mah Lipo did not charge to 2200mah. Thank you very much for the response
Old 07-03-2008, 01:17 PM   #35 (permalink)
Default How many
Can this charger charge more than 1 battery at a time ?
godspeed128 is offline        Reply With Quote Quick reply to this message
Old 07-13-2008, 02:35 AM   #36 (permalink)
Read page two of this thread
Old 07-13-2008, 02:54 AM   #37 (permalink)
I'm using Thunder power TP-610C and Turnigy Accucel 6 chargers.
Can I charge 2 packs with each charger with those connectors listed below?
Plug 2 Lipo with "1st Pic" and follow with plugging each lipo balancing tap to "2nd Pic" then plug to the charger's 6s balancer? I'll ignore the dean in "2nd Pic"?
If yes then how many "C" and lipo cell I should select in my charger?, I'm using only 11.1v 3s1p 2200mah 20c lipo.
ID:	54694   Click image for larger version
Old 07-19-2008, 07:24 PM   #38 (permalink)
Ok, another noob here. My LHS recommended a TP 4200 mah 7.4v 15c Lipo as a reciever pack for my trex 600n. The sticker says "Charge as 2 cell or may cause fire". I just purchased a TP-610c and would like to confirm the max charge rate. Would it be 2.1?
chewmh53 is offline        Reply With Quote Quick reply to this message
Old 07-20-2008, 11:45 PM   #39 (permalink)
You could charge it at 4.2 Amps, unless it says anything other than charge at 1C on the pack... 4200 mah = 4.2 A 1 x Capacity (1C) = 4.2 Amps (charge rate).
Old 07-21-2008, 08:53 PM   #40 (permalink)
Thanks for the info. Because it is a 4 cell pack and says to charge as a 2 cell was a little confusing.
Thanks again!
