Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > Outrage RC
Outrage RC Outrage RC - and XP Li-Po Factory Support Forum
Old 12-18-2006, 07:22 PM   #21 (permalink)
Originally Posted by TomSardea
Hi,
What servos do we need to use w/your new design? 9650? any other options?
Thanks!!
Tom
Currently Futaba 9650 is my servo of choice I have considered others
Charley Stephens
Charley Stephens is offline        Reply With Quote Quick reply to this message
Old 12-18-2006, 07:28 PM   #22 (permalink)
Team Taco VP
BUT to get the performance on 9650's you MUST be 6V... Perfect to use the stock Align regulator!
Nice work Charlie!
Bob
Old 12-18-2006, 07:58 PM   #23 (permalink)
ok Thanks Charlie and Bob!
TomSardea is offline        Reply With Quote Quick reply to this message
Old 12-18-2006, 08:44 PM   #24 (permalink)
Is there possibly a list or measurement that you can provide for motors that won't require the canopy to be trimmed. Also what will be included with the frame and what's the target price?
Gscott is offline        Reply With Quote Quick reply to this message
Old 12-18-2006, 09:23 PM   #25 (permalink)
Hitec 5225 will be a great choice also: same size, 10 dollars cheaper, and metal gears. It's only .01 sec slower.
BoneDoc is offline        Reply With Quote Quick reply to this message
Old 12-18-2006, 10:09 PM   #26 (permalink)
Bonedoc do you mean 5245
Charley Stephens
Old 12-18-2006, 10:28 PM   #27 (permalink)
Yep..
Old 12-18-2006, 10:39 PM   #28 (permalink)
Cool I have been looking at that one. that .01 speed will not be noticed at all I may order up a set to test out
Charley Stephens
Old 12-18-2006, 10:45 PM   #29 (permalink)
If the stock 600L was approx 5mm shorter it would fit without hitting it is nearly flush now
Charley Stephens
Old 12-19-2006, 08:26 PM   #30 (permalink)
Hi Charlie,
Great job on the frame. I've been trying to dream up a way to mount the motor up and use full size servos. Do you think it is possible to so something like Gary Goodrum does on the Raptor frames. The servos are mounted on "ears" like in this photo.
I was thinking a similar thing is possible if a triangle block would be mounted on the frame at the appropriate place. I think it should work if the servos end up right next to the motor. Something like this:
Just tossing around ideas.
Ron
R.D. Heli Frames
LOGO 600 3D V-BAR HK4035-630 Power Jazz 14SA123
T-Rex 600E Z-Power 50 CC85HV 14S A123
T-Rex 600N V-BAR TT.53 Redline 3DHiflow Pipe 2SA123
rdespins is offline        Reply With Quote Quick reply to this message
Old 12-19-2006, 08:33 PM   #31 (permalink)
Why won't my images show, the've worked before.
Ron
R.D. Heli Frames
Old 12-19-2006, 08:33 PM   #32 (permalink)
Ron,
Thanks for your comments
I don't own a raptor but if my memory of one is correct the frame is much thinner (at the top) than on the 600 so adding the servo mounts to the side of the frame would put the servos out to far with the direct linkage it requires long servo arms to achieve a full pitch range so your linkage would most likely stick out past the canopy
Charley Stephens
Old 12-19-2006, 08:35 PM   #33 (permalink)
Team Taco VP
rdespin... the .jpg needs to be upper case. That is the way they are on your server.
I just fixed your post for you.
Bob
Old 12-19-2006, 08:36 PM   #34 (permalink)
Thanks Bob =)
Ron
R.D. Heli Frames
Old 12-19-2006, 09:12 PM   #35 (permalink)
Another idea I've seen on another heli, is a mounting system for the servos that clamp around the mainshaft, between the middle and upper bearings. I can't find the exact photo to show it built up but here it is disassembled. I know this is getting deep into a redesign, but it's a nice system if implemented correctly.
Ron
R.D. Heli Frames
Old 12-20-2006, 12:05 AM   #36 (permalink)
Team Taco CEO
I was able to fit standard size servos on my frame design.
fireup is offline        Reply With Quote Quick reply to this message
Old 12-20-2006, 12:18 AM   #37 (permalink)
Cool looking frame. Nice head. What does it weigh in at ?
A Helicopter, Brushless Motor, Esc, Battery, Servos, RX
Ticidytoc is offline        Reply With Quote Quick reply to this message
Old 12-20-2006, 12:42 AM   #38 (permalink)
Team Taco CEO
Ya, it's a little heavier. about 7 lb. flying weight, without the canopy.
My next version will be a one piece design (Left/Right) and use less aluminum.
Old 12-20-2006, 02:13 AM   #39 (permalink)
Team Taco VP
Hey fireup... about time you showed up here and posted
I have flown this heli and it flew well... The head was a little slower than a Trex head but worked well.
Bob
Old 12-20-2006, 02:40 AM   #40 (permalink)
Team Taco CEO
Finless, you got to fly it again. I made quite a few changes sense that first day. It's just as fast as stock Trex now, but still fly a little different though.
I use the longer ball link on the flybar, shorten the lever on the blade grips and decrease the expo. Remeber we had to increase swash travel to 98. I only need about 65 now to get full travel.
I want Ian to fly it to see what it can do and where else I can tune.
This frame can already fit the 8s setup and my ESC is also HV model, so I can't wait to get my hands on a 1910/1Y motor.
