Old 12-09-2009, 03:44 PM   #1 (permalink)
Default 13 and 14-T Pinion
Okay, I've read as much as I can stand and I'm still confused about the motor shaft. On the stock motor, do you have to modify the motor shaft to accommodate the 13 or 14-T pinion?
On the MSH website, they have a CAD drawing showing you what is needed. But they do not mention it this is for the stock motor or something else. For the life of me I can't understand why you would need to do this.
Anyone have the definitive answer and an explanation?
My kit is a new Carbon kit...not to be opened till Christmas.
BTW: If your looking for a carbon kit, they have about 8 or 9 of them here:http://www.rchover.com/category-s/644.htm
Align 600CF; Align 250 Super Combo; MSH Prôtos CF
Tough supporting a large "growing" family
Roger_15 is offline        Reply With Quote Quick reply to this message
Old 12-09-2009, 03:56 PM   #2 (permalink)
The old MSH motors had a longer shaft that wouldn't work with the smaller pinions. So you had to cut it. The NEW MSH motors now come with a shortened shaft. If the kit was ordered recently it has the short shaft.
Steve
Trex 450 Pro
= MSH Prôtos = Logo 600
CatchmyCorsair is offline        Reply With Quote Quick reply to this message
Old 12-09-2009, 08:40 PM   #3 (permalink)
So does that mean the new kits don't need the motor adaptor MSH51098 (for 13/14T Pinion) and these pinions will fit on the adaptor that comes with the kit?
http://www.readyheli.com/MSH51098_Mo...p/msh51098.htm
I also bought an early Xmas present, but i had a little peek in the box already.
OSOFAM is offline        Reply With Quote Quick reply to this message
Old 12-09-2009, 08:47 PM   #4 (permalink)
I am pretty sure that you have to use the adapter for the 13/14 tooth pinions as they are a smaller diameter. You just don't have to shorten the shaft.
Please don't confuse my experience with pessimism!
Protos 500, HCP100S, Raptor 50, many more!
babyuh1 is offline        Reply With Quote Quick reply to this message
Old 12-09-2009, 09:05 PM   #5 (permalink)
Correct, sort of. The 13/14T requires the short motor shaft.
The motor adapter for the 13/14T is different than the 15T. Both adapters will work on the short motor shaft.
Steve
Trex 450 Pro
Old 12-10-2009, 02:17 AM   #6 (permalink)
Thanks for the help CatchmyCorsair. And thanks to you all for asking the better questions. I don't do hard 3D so I wanted to try for longer flight times.
Thanks OSOFAM for the part number. That helped me to verify the info. BTW: I have handled the box but the little seal is still intact. She's still pure.
Old 12-10-2009, 03:49 AM   #7 (permalink)
wot
If it helps i wanted to use the 13t pinion on my "early motor" with long shaft.
I did not want to shorten the shaft so i got the short shaft replacement.It was easy to do.remove fan,4 screws.Remove two set screws that hold shaft then use a metal rod to knock the shaft out,no real force needed.The new shaft comes with a eclip for the shaft NOT like the original.put eclip on then slide back in armature and case.make sure shaft is back against washer an can then tignten grubs.
wot is offline        Reply With Quote Quick reply to this message
