Go Back   HeliFreak > R/C Helicopter Support > Hirobo Nitro Helicopters > Hirobo Electric Helicopters
Hirobo Electric Helicopters Hirobo Lepton EX, Quark and other Electric Helicopters
Old 08-22-2006, 12:27 PM   #41 (permalink)
Where did you get the 19T pinion?
Alex
alexsand17 is offline        Reply With Quote Quick reply to this message
Old 08-22-2006, 08:26 PM   #42 (permalink)
Alex
Kövi was kind enough to send me one. It is the brass pinion that he was talking about in the eariler posts.
Alvin
eheliflyer is offline        Reply With Quote Quick reply to this message
Old 08-22-2006, 09:50 PM   #43 (permalink)
Team Taco VP
Yea, I just got my 19T pinion from Kövi as well! I plan to try 5S as soon as my 12T motor gets here!
THANKS Kövi!!!!!
Bob
Old 08-23-2006, 01:33 AM   #44 (permalink)
Kövi if you have any extra left could you sell me one.
Thank
Alex
Old 08-25-2006, 08:17 PM   #45 (permalink)
I spooled up my A30-12XL on 5S 3700 flightpower NF packs with the 24 tooth pinion today. 70% headspeed is 2975 rpm on the head and power is VERY good. Temps were withing reason and this is without a fan installed.
Got a fan coming for it. I am going to run it this weekend and see what king of data I can get with the FDR.
I did run this motor on 4S and it was well just ok. Tail was letting go(where it has never done that before) some and headspeed was 2600 at 95% throttle.
I will say this I do not wish to ever fly below 2800rpm for 3D.
I am not telling everyone to go run near 3000 rpm but it really kicks arse above 2800.
Jon Jennings
mudbogger2 is offline        Reply With Quote Quick reply to this message
Old 08-25-2006, 08:50 PM   #46 (permalink)
Team Taco VP
YEP! I am running 2900 myself.
I am owrried about the blades at this head speed but it is really going well so far.. I put in 5 flights last Sunday and no hint of a tial let go and I was doing so backwards inverted stuff
Jon, you still thinking your 12T is a 10T?
For some reason I cannot get a hyperion 12T now it is back ordered and has been for 3 weeks! Makes me wonder? Not sure i want to ry 5S on my 10T with the pinion Lovi sent me?
Bob
Old 08-25-2006, 09:17 PM   #47 (permalink)
I really do think my 12T is really a 10T. that is why I am asking for some data from other users. may help clear that up.
In the meantime this 12XL is really looking good.
Jon Jennings
Old 08-26-2006, 10:00 AM   #48 (permalink)
Bob, are you still running the same setup? Or have you changed the pinion for higher headspeeds,
I am also running your same setup - would curious if you changed, how has the performance changed, and flight times with batteries, motor temp., etc.
buster1 is offline        Reply With Quote Quick reply to this message
Old 08-26-2006, 11:00 AM   #49 (permalink)
Team Taco VP
Right now I am still running the same setup power wise.
I plan to try 5S soon since I have a 19T pinion now.
Bob
Old 08-26-2006, 11:19 AM   #50 (permalink)
great, I look forward to your results - if good, maybe I will give it a try,
Are you looking for some more torque and longer flight times?
Thanks,
Jeff
Old 08-26-2006, 06:09 PM   #51 (permalink)
Well I threw around my lepton on 5S 3700 flightpower with the Hacker A30-12XL.
Very powerful setup. best so far. I was running at 75% throttle and hit 3100 rpm at the beginning of the flight in a hover.
Flew 4:30 including spoolup and spooldown. Motor was 178F without a fan.
I think with a fan it will go for 6-7 minutes without getting too hot.
I used just over 2000 mah out of the pack. here is the FDR graph
temp is the battery
57 amps
Over 1000 watts
Jon Jennings
Old 08-26-2006, 06:33 PM   #52 (permalink)
Jon, at this point, do you feel the 5S setup is going to really offer any advantages over the 4S setup for aggressive 3D - still seems pretty close, but I am not experimenting with the 5S yet, so not sure from these posts what the real story is,
Thanks,
Jeff
Old 08-26-2006, 07:23 PM   #53 (permalink)
longer flight times with a little more power is going to be the benifit.
I still think more pinions are the answer but this one is getting very close. If it runs cool with a fan installed I definatley think it will be better than the 4S setups.
Jon Jennings
Old 08-27-2006, 12:20 PM   #54 (permalink)
Jon,
For a 4S setup with the stock pinions do you advise me to buy Hacker A30-10XL or 12XL, finally?
Do somebody have some news about aftermarket pinions to be available soon? Like a 20T?
Nicolas
rotodingo is offline        Reply With Quote Quick reply to this message
Old 08-27-2006, 12:33 PM   #55 (permalink)
rotodingo - for 4S you will want the 10XL.
Jon Jennings
Old 11-05-2006, 11:07 AM   #56 (permalink)
Hey Jon J., Matt and I put an on-board monitor on the Lepton 5S/12XL setup of mine with the Jazz 55 and ran some numbers. The HIGHEST amp pull (with him flying mind you) was 60 and the average was in the 30's or 20's (I have to get the graph from him).
That means, as I suspected from the outset, that we all could have saved ourselves well over a $100 and used a Jazz 40-10-24 or 32. Even though it is only rated for 50A, I watched Matt pull 86 A almost non-stop on his 55-10-32 on a 10S Logo 14 and it is only rated for 75 A - so there is a huge buffer built in I think.
Anybody tried that on 5S?
Anyway, I could also use some help as I am moving my Jazz 55 to my Trex 600 and putting the Align 75 on the Lepton with my 12XL. I would love to hear someone has that setup working well and what settings/curves they found worked.
Mike
www.MadManRC.com - Futaba 32MZ, CGY760R
Scale: Vario Bell 47G, Vario Robinson R-22
in process: MZ Bell 412 fuse with Vario Benzin mechanics 4 blade head
3D: Kraken 580 on 12S, Trex-600N
MadMan is offline        Reply With Quote Quick reply to this message
