Old 04-22-2014, 07:58 PM   #61 (permalink)
Yes! I would definitely buy a solid (no OWB) 14t pinion and 13t pinion for my 6s mini if someone made one.
Protos Max Leggero 700, Logo 600SE, Blade 230s
DX9
flint723 is offline        Reply With Quote Quick reply to this message
Old 04-24-2014, 02:14 PM   #62 (permalink)
5 seconds into my second flight on my brand new pinion and it broke, thats 2 pinions in a week, wth is going on my first pinion lasted nearly 2 years and was crashed numerous times,
Anthony
raw 500, xl power nimbus 550,Tron 5.8 heritage, Tron Dnamic, cgy760-r, futaba
anthony1 is online now        Reply With Quote Quick reply to this message
Old 04-24-2014, 03:01 PM   #63 (permalink)
the one good thing is that the pinion isn't cracked but the owb isn't holding , is there a better owb that i can substitute with this one?
Anthony
Old 04-24-2014, 03:08 PM   #64 (permalink)
The t-rex 250 OWB fits apparently, no clue how to get it in though, I have a HK250 OWB sitting around, but haven't gotten around to trying to fit it in a pinion yet.
"Beater" Mini Prôtos stretch 6S : Scorpion 2520-1360kv, Edge 353SE
"Princess" Goblin 570 stretch 12S : Xnova 4025-560kv, Cyclone 615
FrSky Taranis - Heli-X 5 - MKS, YGE, SK540 - Yamaha XJ6F
Aryemis is offline        Reply With Quote Quick reply to this message
Old 04-24-2014, 03:12 PM   #65 (permalink)
I would think the 250 OWB would just not be strong enough to hold up to far more mass but hard to tell till it is tried. I will try the warp pinion tonight.
Fooferdoggie is offline        Reply With Quote Quick reply to this message
Old 04-24-2014, 03:13 PM   #66 (permalink)
Default Re: these pinions are really starting to suck.
Mate of mine has actually swapped them out... he is going to do it for me as well once I can get a new pinion..
He uses a press... the same one they use to swap out motor shafts
Citizen#024
Manyc is offline        Reply With Quote Quick reply to this message
Old 04-24-2014, 04:47 PM   #67 (permalink)
If it's the same physical size as the stock one, I don't see why it wouldn't.
Honestly, I'm ready to abandon the whole idea of the OWB in the pinion. I think it's a really dumb idea, I always have. <shrug>
Oh, and of course when I got my order together at Helidirect, they are out of stock on the damn 15T pinions anyway!
Chris Boultinghouse
JustPlaneChris is offline        Reply With Quote Quick reply to this message
Old 04-24-2014, 06:02 PM   #68 (permalink)
I posted this in the lynx forum as well:
I would really like to see Dylan's pinion from Astroid designs materialize and at least get tested. We have tried and cannot find anyone that can/will machine it.
https://www.helifreak.com/showthread.php?...pinions&page=2
Post 21, I believe.
It seems to be a great idea....
MSH-Direct is offline        Reply With Quote Quick reply to this message
Old 04-25-2014, 03:04 AM   #69 (permalink)
Post 21, I believe.
+1, this looks like a possible solution. But as you said, proof is in the pudding.
2x MCPX I Gaui »X1« I 2x Mini Protos I Protos I DX8
dr dremel is offline        Reply With Quote Quick reply to this message
Old 04-25-2014, 08:27 AM   #70 (permalink)
I'd love to see either Dylan's design or a solid pinion with a "normal" OWB in the main gear. Yes, I realize we'd lose the driven tail in autos, but I would much rather have a reliable flight than tail control in an auto. Besides, the Mini is only slightly better at autos than a manhole cover anyway!
Chris Boultinghouse
Old 04-25-2014, 10:28 AM   #71 (permalink)
Default these pinions are really starting to suck.
With the tight belt radius around the pulley it really causes a lot if drag. So a main gear OWB would give a lot more free wheeling. Well got the gear and did a test flight and so quiet no bearing noise from a bad pinion or the little bearing for the motor shat. The belt came off but not sure if I goofed or the belt stretched as it was really loose when I got it back on. The belt us soft compared to a new one.
Old 04-25-2014, 12:43 PM   #72 (permalink)
got two flights in much better. no more pinion slipping and hopefully I will start trusting this bird.
Old 04-25-2014, 01:32 PM   #73 (permalink)
Foofer
Is that a warp pinion or Dylan's ?
We are taking about the one on the left and I can assume that's the one u are testing !
Vbar Cont/Dx9 Align 600XN my first Nitro ! Original Goblin 500 stretched/Lynxed out Oxy2 now stretched and a few micros
Lynx Heli/Team pilot
thanasi is offline        Reply With Quote Quick reply to this message
Old 04-25-2014, 02:24 PM   #74 (permalink)
that's the warp pinion on a 3.17 shaft. wanted to go for 4mm but I could not find the shaft and pinion all in one spot and I was too broke to buy both.
Old 04-25-2014, 05:37 PM   #75 (permalink)
Kk let us know
Just started my build today, I'll be up in a week or so
I'm going to savour it lol
Old 04-25-2014, 05:56 PM   #76 (permalink)
Originally Posted by thanasi View Post
Kk let us know
Let you know what? it works flies well.
Old 04-25-2014, 06:26 PM   #77 (permalink)
I did mean long term
Old 04-25-2014, 06:53 PM   #78 (permalink)
Foofer
What holds the pinion on? Did you have to file a flat on the motor shaft for a grub screw?
Mini Protos 3x HS5065mg, AR7200BX, JR290
Trex 500ESP Robird, Oxy 2, OXY 3, Oxy 4 All on Dx8G2
AMA 732104
MiataJohn is offline        Reply With Quote Quick reply to this message
Old 04-25-2014, 07:09 PM   #79 (permalink)
Originally Posted by MiataJohn View Post
Foofer
right flat spot and setscrew like most normal pinions.
Old 04-26-2014, 01:24 AM   #80 (permalink)
I have three part single flight pinions for the first asker.
