Old 02-20-2015, 01:39 PM   #1 (permalink)
Talking What are your flight times?
What are they? good to include HS, batts, motor, pinion, blade size and esc.
Batt: 2200 3s turnigy (old)
HS: 1800~ dunno, depends on batt voltage
Motor: scropion 2221 1630kv
Pinion: lynx solid 13tooth
Blades: 325mm edge
esc: CC ice lite 50
Flight time - 7mins to 3.80v per cell
Batt: 1250 6s gens ace
HS: 2850 CC gov
Blades: 325mm edge
esc: CC ice lite 50
Flight time - 6mins to 3.77v per cell
Lets see!
Alex
Fleet: Miniprotos
Flock: cockatiel and congo african grey
dedados is offline        Reply With Quote Quick reply to this message
Old 02-21-2015, 12:04 PM   #2 (permalink)
1250mah Pulse 6s battery
3000-3200
350mm Zeals
MSH 1300 kv Motor with 14t pinion (used to run 16t)
Right around 4 minutes for me
Old 02-22-2015, 10:13 AM   #3 (permalink)
Mini Protos lightweight
batt: 2200 3s turnigy 40C
HS: ~2600 - 2800
Motor: scropion 2221 2580kv
Pinion: 15t
Blades: 325mm sab
esc: YGE 60
Flight time ~ 5mins to 3.75v per cell
Mini Protos stretch 3S
batt: 2650 3s zippy 45C
HS: ~2600 - 2800
Pinion: 15t
Blades: 353mm edge
esc: YGE 60
Flying style "soft" 3D
2x MCPX I Gaui »X1« I 2x Mini Protos I Protos I DX8
dr dremel is offline        Reply With Quote Quick reply to this message
Old 02-22-2015, 03:07 PM   #4 (permalink)
Mini prôtos stretch 6S
Lipo : Dinogy 6S 1300 65C
HS : 3000-3400
Motor: Scorpion 2520-1360kv
Pinion: 16t (warp pinion)
Blades: Rjx 360mm vector
ESC: YGE 60
Flight time : 3mins to 3.73v per cell (~20%)
Big air/3D
I'm probably going to try running a smaller pinion to run 3000rpm with a little more flight time, also a more efficient Xnova 2618-1350.
Atm, flight time doesn't really change between 3000 and 3400rpm, but 3400rpm is too fast for me.
"Beater" Mini Prôtos stretch 6S : Scorpion 2520-1360kv, Edge 353SE
"Princess" Goblin 570 stretch 12S : Xnova 4025-560kv, Cyclone 615
FrSky Taranis - Heli-X 5 - MKS, YGE, SK540 - Yamaha XJ6F
Aryemis is offline        Reply With Quote Quick reply to this message
Old 02-23-2015, 09:56 PM   #5 (permalink)
3s Nano-Tech A-spec 65c
YEP 40A
Stock Scorpion 3s motor
15t pinion
SAB 350mm blades
3100 rpm = 4 min flight
2500 rpm = 7 min flight
Team Lynx Heli Field Rep
XL Protos 380
Jomaba4308 is offline        Reply With Quote Quick reply to this message
Old 04-01-2015, 07:12 AM   #6 (permalink)
6S Stretch kit, HW 50A V3 instead of YGE
350mm Radix blades
2100RPM
longest flight - 9:36
normally - 8...8:30
1000mAh per telemetry is the signal to land, normally end at 1060-1080mAh
DX6i, Jeti DS-16
MCPX BL, Mini Protos 6S, Stingray 500, SG704, SG381, OMP M2 V2
Brain, SK 720, Spirit Pro, Brain2; HW, Kosmik
Heli-X, AccuRC, RF 7.5 Transmitter Interface Edition
madeye is offline        Reply With Quote Quick reply to this message
Old 04-01-2015, 08:19 AM   #7 (permalink)
2200 3S Turnigy and Gens Ace, 5 minutes of "enthusiastic sports" flying, usually leaves batteries at about 3.75 volts
Old 04-17-2015, 04:09 AM   #8 (permalink)
For some reason I can't edit my first post so an update:
HS: 2800 CC gov
Blades: 325mm edge
esc: CC ice lite 50
Flight time - 4mins to 3.83v~ per cell Sport Flying in the garden
4mins to 3.79v~ per cell 3D
BTW I charge to 4.17v per cell to increase life of the batter+faster charge
Alex
Fleet: Miniprotos
Old 04-21-2015, 05:57 PM   #9 (permalink)
Two identical models, one standard, one low-head.
335mm blades,
3S scorp motor
15T pinion
Various 3s2200mAh Turnigy packs, 30C to 45C (no nano-tech, they all died)
4:20 flight time 3D. Does bog slightly sometimes but fine for me.
MSH miniPRÔTOS & PRÔTOS 500 a better way to fly
GAUI
Hurricane 425 night rig & 550 the monster
sp00fman is offline        Reply With Quote Quick reply to this message
Old 05-02-2015, 11:19 AM   #10 (permalink)
Update because of new motor.
HS: 2850 CC gov
Motor: stock 6S
Pinion: lynx solid 15tooth
Blades: 325mm edge
esc: CC ice lite 50
4mins to 3.76v~ per cell HARD 3D
Alex
Fleet: Miniprotos
Old 05-02-2015, 11:22 AM   #11 (permalink)
YEP 40A
15t pinion
SAB 350mm blades
Those are excellent flight times! What is the voltage at the end of the flight? I am surprised that you get the same amount of time as me with 3S, 350 blades and higher HS
Do you run a larger lipo?
Alex
Fleet: Miniprotos
Old 05-02-2015, 11:38 AM   #12 (permalink)
I use 2200 packs, average is about 3.7 per cell and 20-30% capacity left according to my hitec cell checker.
XL Protos 380
